Question about HP Pavilion dv4000 Notebook
Does the hp dv4000 laptop have an ide or a sata hard drive? i just purchased on ebay and it only has a 20 gb hard drive and i want to add at least a 160gb one, but i don't know wether to buy an ide or a sata drive?
  • 6,831 Answers
Hello
The notebook you purchased uses a IDE Storage controller.
Kind regards
Andrea
Posted on May 31, 2010
Turn into usb drive
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.09 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
How to recover data from a partion of a WD 160 GB HDD approx. 70 GB
http://www.ebay.com.au/itm/120738767650?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 AU $8.40 Buy it Now + postage AU $0.96 you could get this on Ebay if you dont have an account you will need to create one https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo Add Email adress Add Bank Acc Add Credit Card also add your postal adress also add a paypal account On Ebay summary page you will see on left a paypal link When you get to the paypal login page at the bottom you will see new to paypal sign up tab Paypal to create an account Paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress be very specific when you type in the search Always ask questions ? Before you make a purchase and keep the email /s for security reasons if the item arrives and its not as described. You will even see the pictures of your item so you cant make a mistake and get them home delivered. or you might be able to find one closer for local pick up
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4 USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit AU $7.46 free postage worldwide You would have to remove the hard drive and use a usb sata ide kit you will then have to connect it to your computer using a usb port Once connected to another computer to a usb port and power supply you should get a message found new hardware and it should install the drivers it should show on your computer or you might have to install it manually click start click on computer to open you should see this drive If you dont. Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a Yellow Question / Exclamation Mark? ! or a Red X you will need to update/reinstall drivers right click to reinstall drivers. If you can see your usb drive but its not working ports (com&lpt) right click update driver Once you see this drive just click on it to open and copy all or any data you want and save it to another usb drive
hope this helps
Jan 07, 2013 | Western Digital Essential NetCenter...
Hi, Is the standard hard drive in this notebook a SATA or IDE drive. Part no. is 383486-001. Thanks
It is IDE. 383486-001HP 80GB Ultra ATA/100 EIDE hard drive - 4,200 RPM, 2.5-inch width, 9.5mm height
Hope this helps,www.PuterCare.com
Jul 08, 2010 | HP Pavilion dv4000 Notebook
Can I swap the hard drive in my hp dv8000 into my hp dv 4305?
Both laptops? It depends if they are both SATA or both IDE drives. MY dv8000 has SATA hard drives. So you should be able to...as long as the connections are the same.
Jun 12, 2010 | HP Pavilion dv4000 Notebook
Is there any sata slot available on HP Pavillion dv4000 laptop, i mean can i install a sata hard disk in my hp Pavillion dv4000 laptop?
hi this depends on the age if it is older than 3 1/2 year old approx, then you maybe able to put one in, other than that the easiest way to find out is to take the old one out, just look at the back end where it connects to the board, if it has pins in the back its ide if it has just a line of contacts then its sata...hope this helps
Jun 05, 2010 | HP Pavilion dv4000 Notebook
Need to install a new hard drive on a HP Pavilion 6736..Is there a upper limit to the hard drive capacity ?..The original disk is only 20 GB..Thanks
in most PCs the MB and cables inside will have provision to add
2 HDDs
2 Drives (CD or DVD)
1 floppy drive(now it's obsolete)
in a IDE system the data cables inside will be aprox 3 inch wide and the MB will have 2 IDE slots to fix the cables....
in a SATA system the data cables inside will be aprox 1 inch wide and the MB will have 4 SATA slots to fix the cables....from 2 HDD and 2 Disk Drives....
you should know how to install a new HD and make it primary or slave depending on which HD has your OS...
google and find more details on that...
May 04, 2010 | HP Pavilion 6736 PC Desktop
Is a MAXTOR N256 20 GB HARD DRIVE HD model #92048D8 compatible with laptops? It's an IDE
I would say yes. Most IDE hard drives are compatible, all that's needed is the laptop to hard drive adapter. They come in various flavors.... ide to sata (with power converter), ide to usb, ide to ide (44 pin female to 40 pin male), take your pick. :)
Sep 14, 2009 | Maxtor Hard Drive
Replacement drive for HP DV5000
As per HP, the maximum capacity of Hard Drive shipped with dv5000 series Notebook is 100 GB 5400 RPM SATA Hard Drive.
The Specifications of the Hard Drive compatible with your Notebook are SATA 5,400RPM, 2.5in width, 9.5mm height.
However, you can install a maximum of 160 GB SATA Hard Drive in your Notebook.
You can purchase the reqired Hard Drive for your Notebook from the link below :
http://bixnet.com/12insanohadr.html
Find the requied instructions to remove and replace the Hard Drive in the Notebook from the Manual of the Link below :
http://h10032.www1.hp.com/ctg/Manual/c00700932.pdf
Please go through page number 98 of 260 in the Manual to find the required instructions.
Hope this helps....
Nov 29, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
360 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
