Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I need a manual for the salt water system
Does anyone know where I can find the manual for the Intex Automatic Salt Water system online?
  • 2,841 Answers
You can download the manual here for free. http://pr-rp.pmra-arla.gc.ca/PR_SOL/pr_web.ve1?p_ukid=5143 Have a great day.
Posted on Jun 01, 2010
Testimonial: "Wonderful, just what I needed. Thanks a lot!"
I have an Intex Ultra frame 18x48 with the salt water system, I haven't added salt in a while and keep getting a high salt alert and I add water frequently because of the evaporation (which is well water)....
When water evaporates, it leaves the salt behind. Depending on your well water, it may also already contain salt - adding yet more salt to your pool each time you top up...
Perhaps try emptying your pool (all or partially) & starting again - don't think the old trick of sticking a potato into an over-salted soup to absorb the excess (& removing it before serving, of course) will work on a pool!
Aug 06, 2013 | Intex Automatic Salt Water System for ...
How do i connect a salt water system to the pool
if you use a salt system in an above ground pool, the steel frame work will last less than 2 years before it rusts out
talk this over with the pool experts first and then have them help you with the system needed
Oct 25, 2017 | Intex Automatic Salt Water System for ...
I have acs15110 saltwater system I have added salt and tested the levels are correct, but when I put it on the cycle to make chlorine, after a few minutes it starts to beep low salt, and I know it is not...
If you allowed time for the salt to mix into the water, check your generator cell for debri inside. (do that anyways) search manufacturer web site or search online how to properly clean it out without damaging it.
Search for a manual on your generator.
May 05, 2012 | Intex Automatic Salt Water System for ...
Where do i add salt to my intex automatic salt water system
Ad salt right in the pool water. Filter and brush around to disolve. Do not try to generate chlorine for 12 hours or so.
Make sure your salt content is as close to 3000ppm as possible
Jun 16, 2011 | Intex Automatic Salt Water System for ...
My intex saltwater system green light then low salt light
You need to add salt to the water. How much depends on what size pool you have. Your owner's manual will tell you exactly how much to add when the low salt light comes on. On my Intex I would need to add 35 lbs.
May 30, 2010 | Intex Automatic Salt Water System for ...
How do you set the panel on a salt water intex pump mdl no.8110 and how much salt do use
to set the system, hold the down button until it beeps, then hold the up button until it beeps. Now the system is ready to set. Push the up button to the desired number of hours you want it to run. Now, hold the down button until it beeps, then the up button until it beeps. It should be locked and ready to start working.
Without knowing how large your pool is, I can't give you an exact amount of salt to use. If you know how many gallons your pool holds the formula is Gallons x 0.025 = pounds of salt to start up. When you need to add salt, its gallons x 0.0067 = pounds of salt to add when needed.
May 20, 2010 | Intex Automatic Salt Water System for ...
Intex automatic salt water system died can I chlorinate the salt water.
Yes you can. Liquid would mimic your salt water generator in that it will slowly raise your pH over time. Switching to tablets would do the opposite to pH.
Jun 16, 2009 | Intex Automatic Salt Water System for ...
I lost my manuel & don't know how much salt I am supposed to have in it. My pool is an Intex 16 X 48.
I checked the manual.
For an Easy Set you need 110 lbs of salt
For the Metal Frame you need 125 lbs of salt
If you go online to the IntexCorp website, you can download an additional manual for free, takes a while to do but that way you'll have all the info in case you have any more problems.
Good Luck!
Jun 15, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
1,335 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
