Question about Philips Magnavox 51MP392H Rear Projection Television
Hey I have a sylvania lcd t.v. / dvd combo , where can I get the main power board ?
  • Philips Master
  • 8,617 Answers
You will have to list the model number and I may be able to locate one for you.
Posted on Apr 08, 2008
Power supply or main board ? RCA flat screen
At a guess, main board. I agree if power supply board is bad, you won't get DVD working.
Dec 31, 2015 | RCA 26LA30RQD 26 LCD TVDVD Combo
SYLVANIA TV COMBO
Hello
The laser pickup unit of your combo's DVD player is damaged. Replace it with samy type and number. Replace the strip wire too, which connects the laser pickup unit to main board.
Feb 13, 2012 | Televison & Video
Sylvania LD320SSX 32-Inch 720p LCD HDTV/DVD Combo fails to turn on(power light flashes green, turns solid green 10-15 minutes then red). Leading up to this condition it would take several attempts to turn...
You checked for bad capacitors, but did you check for bad soldier joints?
I would start there. Also, be prepared to replace the Power Supply Board.
Aug 30, 2011 | Sylvania LD320SSX LCD TV
We have a Toshiba Model 37LX96 LCD/DVD Combo Can't turn on, after a recent power outage There is power going to the unit, but it will not turn on using the remote or using the "power"...
Common problem with the main board. Only happens after losing main power, not just turning the TV off.
I found that blowing hot air with a heat gun down the vents above the DVD player (don't melt the plastic housing) will warm the main board up enough to get the TV powered up again.
You'll be good to go until the next power outage then back to the heat gun.
Also the spec sheet indicates max humidity at 80% so keep the TV in a space with lower humidity.
The Toshiba 37LX96 is a quality TV, not a throw away if you can keep it running.
Schmidty
Aug 25, 2011 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
Need code for dish network remote for Sylvania LD320SSX
hi! i have here a couple of codes for your sylvania TV, just try them, 1004, 1007, 1018, 1027, 1047, 1056, 1057, 1059, 1060, 1061, 1103, 1124, 1145, 1150, 1153, 1279, 1296, 1387, 1464, 1483. this is for sylvania HDTV 1046, 1465. this is for the tv/dvd combo 1150, 2092, 1464, 2408, 1465, 2260. this is for the TV/DVD/VCR combo 1027, 2064, 3105, 1124, 2078, 3088, 1296, 2213, 3147. this is for the TV/VCR combo 1145, 3095. hope this helps!!!! goodluck!!!
May 16, 2010 | Sylvania LD320SSX LCD TV
BLACK LINES ON PICTURE
could be capacitors are problem, hope you have checked al the input cables. need servicing and resoldering on main board...
Oct 21, 2009 | Sylvania LD-320SS8 32 in. LCD TV/DVD Combo
My sylvania tv dvd combo is ejecting the dvds out
Ur injection button function is stuck or malfunction,return it for warenty repair,tries this couple time see if this is the prob.for certian.tries it with other dvd disks.
Aug 13, 2009 | Sylvania LD195SL8 19 in. LCD TV/DVD Combo
I turn the tv and inside star a shortcut with smoke
Ur tv circuit board is burn or ur power board is dead. Make sure ur TV worth repairing it cost alot money for this prob.U know little about
Electronic u can check if there no burn in the circuit board check the plug go to the power u can buy that board in the net might work might not.Could burn alot of things in power surge.
Aug 12, 2009 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
Sylvania 37-Inch LCD/DVD combo HDTV remote code for Scientific Atlanta 8003
You can find the sylvania 37" LCD/DVD COMBO at Sam's club for 597.00 it is a special item for sams club. If you go to sams club on line you cna locate what sams club has this tv in stock but hurry they are going fast and there model number is LD370SC8. I am not sure where you are located but please start your search now and if you do not have a sams culb card you can get the lowest priced membership possible and due to the low cost the price of a membership is worth it.
I hope I have helped?
Noreen
Sep 09, 2008 | Televison & Video
Philips Magnavox 51MP392H Rear Projection Television Logo
16 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
