Question about Kenmore HE2 Plus Front Load Washer
Washer doesnot complete the cycle with sign F33
  • 15,935 Answers
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
CLICK HERE
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa&^%$
Posted on Mar 04, 2011
My washer quit in the last cycle and had a code of F33.
Hi again,
Whirlpool's F21 decodes as 'control unit failure' which definitely means a service call and is probably tied in with the F33. Sorry ;-0( Good luck, John C
Jun 18, 2011 | Washing Machines
F33 flashing during cycle I have a kenmore HE2
CLICK HERE
Feb 13, 2011 | Kenmore HE2 Plus Front Load Washer
I have a kenmore HE2 plus with error code F33 and F21. Washer is not fully spinning out and remains full of water at times and other times it does. What are the error codes and can it be fixed. Needs...
CLICK HERE
Thanks for using FixYa&^%%$
Jan 08, 2011 | Kenmore HE2 Plus Front Load Washer
I can't find the instruction sheet
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts. If you look on the right hand side, you should see a link to their manuals site.
Also see the following Sears Answer site where you can get PDF versions of the instruction manual.
http://www.managemyhome.com/
May 30, 2010 | Kenmore HE2 Plus Front Load Washer
HDW 1011WG machine showing a F33 fault
The error F33 means Pump Drive System Error occurs when the connection between pump and the Central Control Unit(CCU) is lost.
Follow these steps.
1. Unplug washer or disconnect power.
2. Check wire harness connections to the pump and Central Control Unit(CCU).
3. Plug in washer or reconnect power.
4. Verify CCU operation by running a Diagnostic Test or any cycle.
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F33 AND 5D
5d possible causes * If too much detergent was used -Run the unit thrugh a RING/SPIN cycle. -Run a NORMAL cycle with out adding detergent. PROCEDURE * This should clear the unit of execess detergent. 1.- Check the draing hose and male sre it is not plugged or ****. 2 Unplug washer or disconnect power. 3.-Check wires harness connections to the drain pump, pressure switch, and center Cotrol Unit (CCU). 4.- Check/clean drain pump filter of foreign objects. 5-Plug in washer or reconect power. 6.- Check draing pump. 7.- Check the pressure switch. 8.- Verify CCU operation bu running a Diagnostic Test or any cycle. F33 MUST be fix by a technition Service ONLY am sorry about this inconvenient. "Was this helpful?"
May 11, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore elite he3t model 4596640 year 2005 f33 code
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2009 | Kenmore Elite 45986 Front Load Washer
Error code f33
Jan 25, 2009 | Kenmore HE2 Plus Front Load Washer
Error Code F33 after new bellow put in. How can I fix it?
Just fixed my F33 error code for GHW9400. This code is for the pressure switch HOSE. Mine had a small pin hole. Cost:: the dealer gave me a free new hose. Remove the top and back. In the top right hand corner (at the back of machine) you will see a small hose attached to the pressure switch box. It is small black& 3/8" and about 2 1/2 ft long coming out of the bottom.. Mine was not attached with anything. Pull off at the top and bottom. Look for even the tiniest hole. Hose probably can't cost a couple of dollers.
Replace and just finished my first error free load. It may be causing your leak too.
Jan 10, 2009 | Whirlpool GHW9400 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
80 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
