Question about Frigidaire GLRS267ZA Side by Side Refrigerator
Water leak Fridgidaire gallery series GLRS267zaq3. When the water line is turned on to supply water to dispenser and ice maker, water leaks in the back wall and freezes over the compressor shutting down the fridge. When supply line is shut off fridge runs normally. What could be the possible problem and location of leaks. Is repair possible by novice homeowner
  • dtianen Apr 09, 2008
    Thanks, I'll check that. To be clear the when the supply line from the basement is on, suppling water to the fridge to operate the ice maker and water dispenser water is leaking from what appears to be the top behind the rear inner wall and accumulating onto the COILS and ultimately shutting down the fan and then the fridge.
    When I turned the supply line off in the basement and no water is in the fridge system the unit runs fine.
    I will check the ice maker as you described and if you can add to the solution I would appreciate it.
    Thanks
Icemaker has become extremely slow in making ice and will not keep up. It is making ice but seems to be sporadic.
Any suggestions???
Posted on Jan 15, 2009
    Novelist:
  • 184 Answers
IF THE ICE MAKER AND DISPENSER ARE BOTH OFF, THE WATER VALVE IS THE PROBLEM. THERE SHOULD ONLY BE WATER RUNNING WHEN THE ICE MAKER CALLS FOR IT, AND THAT SHOULD ONLY BE ABOUT 7 SECONDS WORTH,
(4 OUNCES).
THE ONLY THING THAT PUZZLES ME ABOUT YOUR DESCRIPTION IS THAT YOU SAY ICE FREEZES OVER THE COMPRESSOR. THE COMPRESSOR IS THE HOT ROUND OBJECT LOCATED UNDER THE REFRIGERATOR OUTSIDE THE COOLING COMPARTMNTS. FREEZING ONLY TAKES PLACE IN THE FREEZER COMPARTMENT. ARE YOU TALKING ABOUT THE EVAPORATOR COILS? IF THERE IS WATER THERE, THE ICE MAKER COULD BE STUCK IN THE FILL MODE AND THE BACK OF THE ICE MAKER FROZEN SO THE WATER CAN'T REACH THE MOLD OF THE ICE MAKER.
CHECK THE FRONT OF THE ICE MAKER BEHIND THE COVER FOR A BROKEN GEAR. IF IT HAS WRITING ON IT THAT SAYS DO NOT ROTATE MANUALLY, YOU NEED TO REPLACE THE ENTIRE MODULE ON THE FRONT OF THE ICE MAKER.
Posted on Apr 08, 2008
  • Anonymous Apr 10, 2008
    IF THE WATER IS COMING FROM BEHIND THE ICE MAKER, BE SURE THE CUP ATTACHED TO THE ICE MAKER IS NOT FROZEN UP. THERE IS A SMALL HOLE AT THE BOTTOM OF THE CUP THAT ALLOWS WATER TO ENTER THE ICE MAKER MOLD. ALSO, CHECK THE FILL TUBE THAT RESTS
    IN THE CUP. THE NEW SYSTEMS HAVE HALF A TUBE OR
    TROUGH FOR THE WATER TO RUN DOWN. BE SURE THE WATER ISN'T SPLASHING OVER THE EDGE OF THE TROUGH. IF IT IS, TRY SLIDING A PLASTIC TUBE OVER TOP OF THE OPEN TROUGH.
SOURCE:
My ice maker works but does not dispense water or ice through the door?
frozen water supply chute to icemaker, frozen water lines in door, unplug for 8 hours with doors open and this may fix your problem.
fridge may be set too cold
38 f fridge and 0 f freezer
May 03, 2015 | Frigidaire Gallery Series GLHS269ZDB 36"...
Leaking pure source 2 ice and water filter
Hi-
Three things
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
Hope this help
Thanks for using Fixya!
Jul 14, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Hi, i noticed water coming from the back of my fridgidaire fridge model ftr81sgh
sounds like a frozen water inlet to ice maker . needs too be defrosted and may need a water valve as it may not be shutting of completly .mm
Aug 10, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker does not make ice
The first thing to check is that the wire bar attached to the ice maker is not locked in the up position.
Next, check that there is water pressure at the back of the refrigerator where the water supply pipe attaches.
If there is plenty of water pressure, the most common cause is a failed solenoid valve that is just past where the supply line connects.
Please report back with what you find, OK?
Aug 05, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water leak from ice dispenser line
hi..
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
Jul 26, 2009 | GE Refrigerators
Ice smells, and tastes bad...no filter to change?
If you have a silver metal braided line to water source that is your problem. Replace mine with a braided vinyl line and it cured it. ps flush new line for about two minutes.
May 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker not making ice
We do not use our ice maker. But all of the sudden water is leaking from it. Can you tell me how to fix this? Calling a plumber wil cost a fortune.
Mar 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire GLRS267ZA Side by Side Refrigerator Logo
486 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
