Question about Philips Magnavox 42MF521D/37 Television
Everyone was out of the room when the TV actually went off. When we came back in we tried turning it off and on, leaving it off for a while, taking the back off and having someone we know replace the resistors?(look like double A batteries soldered onto power board) Now when we plug it in there is no picture and the tv is making a chirping noise. I have read that it might be a convergence problem and there are kits for that, but do not want to spend more money on this thing if that is not really the problem.
  • bobbiejoh May 31, 2010
    I have looked to see what the inverter board is and now am more confused than ever. Apparently there are several types???
    Can anyone give a step by step troubleshoot for dummys? I know less than nothing about electronics.
    Thanks
  • 15,935 Answers
Please verify the exact model # of the set.
Thanks!!
Posted on May 31, 2010
    The model number is 42MF531D/37
    Not sure why, but when I type that in to FixYa it always changes it by one number.
    Thanks!
  • 666 Answers
No convergence kit is not going to solve your problem this is another circuit having an issue firing on
hope this helps
Robb
  • 10,515 Answers
Well friend chirps come from the primary side of the power supply normally you may have had a serge of some kind and it blew the power supply. or chirps also come from the inverter board, this when coils short out.
This is not a Convergence Problem.
The unit is worth Fixing as Either board would cost you around $150.
with your problem check the 24v line make sure power supply is supplying the inverter if it is rule out inverter then listen to pin point the noise. i would use cold spray on the components to find the problem.
Now you would ask COLD SPRAY?
I would explain you.
well you may not need it if you open the set and listen to the chirp. But if you can't pinpoint it the spray changes the temperature to the failing part and once the spray hits it, it should alter the chirp. you should not have any problems because you can here your problem, it's either your power supply board or inverter. just open set listen and pinpoint problem that's, simple well.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
My tv won't work after I shut it off using the remote throught the cable box
You need to turn on the cable box again. Make sure to select the right source again for your tv.
Jan 11, 2014 | Seiki 32" LED HDTV SE322FS - CAM CONSUMER...
My sony trinitron is blinking red and won't turn on
THIS IS NORMALY CAPACITORS IN THE POWER SUPPLY THAT NEED REPLACING
Jun 25, 2013 | Sony FD Trinitron WEGA KV-34HS510 34" TV
I was watching a DVD and I paused it to turn to TV and I turned it off on TV mode, when I went back to my room the tv was making a low screetching sound so I went to turn it on and it won't, I changed the...
Tries tv unplug,replug it back like an hour later.See,if that solved ur problems.If still have the same problems.The power supply board have the problems the causes,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 06, 2010 | Sylvania LD195EMX 19 in. TV
I went into the other room and when I came back into the room where the tv is it was off and now I cant turn it on. When I turn the power on the red button turns green a couple times and then then back to...
Can't really tell without a model number or manual or anything but I bet the bulb went out when you were in the other room and needs to be replaced. If it's out of warranty a new bulb will probably run a couple hundred dollars.
Sep 17, 2009 | Televison & Video
No picture 2 days ago power went out thru out the neighborhood, once power came back TV worked great. today, go to power on TV, here it clicking, but no picture... cable box working, cable working in 2nd...
It sounds like there`s a sort on the secondaries of the power supply. Before the power went off, did you ever turn the tv off by unplugging it?? In other words, did you turn the power off completely to the set or leaving it in standby?? if you always left it in stby, it will be the capacitors in the power supply, they dry out if the power is always on, so they will need replacing. If you did turn off the power, then I think you`ll find that the power cut had nothing to do with the fault you`ve got now, it will be the Line Output Stage which has failed or gone short circuit. Ian
Aug 05, 2009 | Sony Televison & Video
Menu on a Philips-32PF7320A-37B
try leaving the TV unplugged overnight (at least 8 hours). this should reset televison to origional defaut settings. If you are using a remote, you should use new batteries or put it in another room and use menu buttons on the tv itself it is equiped.
Mar 31, 2009 | Philips 32PF5320 32 in. HD-Ready LCD...
STATUS LIGHT YELLOW, LAMP LIGHT GREEN: TV TURNS OFF.
have you checked the air filter located on the side of the unit? Also can you hear the fan start as soon as you plug the set in?
Apr 09, 2008 | Mitsubishi WD-52631 52" Projection HDTV
How to unlock my jensen tv
we the same problem, our tv went blue with a blue pad lock in the upper left had corner.. we couldnt figure out how to get it off.. we even went to go and price tvs today... after looking for the tv manual and not being able to locate it, we decided to google jensen tvs and came up with this site... so thanks whom ever you are who said to hold down the display for 5 seconds and our tv was back!! thanks to whom ever u are with the last 2 suggestions!!!
Dec 10, 2007 | Jensen TS2750J TV
TV or Satellite Box Problem?
Do you have a VCR or DVD recorder? If yes, set it to record what you are watching. After a "blackout" rewind the tape and review it. If there is a blackout on the tape, the problem is the sallite box, if not, it is the TV! QED
May 23, 2007 | Sound Ideas Twentieth Century Fox -...
Red Screen
Sounds like the red color tube is goeing bad you wil hafto call in a tech to conferm it Sony is noted for tubes goeing bad, in the future leave sony alone
Sep 24, 2006 | Sony KP-57HW40 57" Rear Projection...
Philips Magnavox 42MF521D/37 Television Logo
161 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
