Question about Canon imageRUNNER 400S Copier
Front door already closed m/c please closed front door
    Problem Solver:
  • 16 Answers
Hai,
check front cover left side clay plate position. its make a full pressure in the main door switch. if proper it is ok.
check front cover switch mechanisum and wires connection also.
best of luck
Posted on May 31, 2010
Front cover is on alarm even the front cover is already closed. how can i reset the alarm.
Hello, Did the technician ask about any error codes in display?
For Example the number 2 from the center picture on display ( the picture of machine) or by pressing and holding the * (star) key on number pad show 2 numbers with the second being 817 in the red number area?
When the door is closed there is a one inch thin piece that gets inserted into a slot that activates a switch proving the door is closed..
There several resets you can try - holding down reset while powering on machine, Holding down just the "print position" left and right arrow keys (not the center) . and powering on equipment then typing "94" and then press start key. Note press clear if any numbers show up before hand.
If no results the part on door has broken or the switch is out of position to activate correctly,
Please tell any codes and we can go from there. TY
Jan 29, 2015 | Riso RZ220 MASTER UNIT - ONE ROLL PACK
GP215 Canon Photocopier says close front door when its closed!
THIS PROBLEM DUE TO YOUR COMPOSITE POWER SUPPLY PROBLEM
Nov 28, 2013 | Office Equipment & Supplies
Close front door message when front door is already closed
I am having the same problem... did you manage to resolve it? Let me know
May 16, 2013 | Saeco Xelsis Digital ID Automatic Espresso...
Washer leaking from bottom when first turned on and tub filling, already checked inlet valves/tubes in back-no problems. Already drained filter and filter tube, did not resolve
Did you check your bellows for tears.That is the rubber that attaches tub to front of washer. the part that the door closes on. check in and around for tears in it ...Good luck if i helped you please vote ..thank you
Feb 01, 2011 | LG WM-2277HW Front Load Washer
Freezer Door will not stay closed, opens about a half inch after removing pressure.
You can try and adjust the front legs of the frig raising the front about one or two inches. This will but more pressure on the door seal.
Sometimes if you slam the frig door the freezer door will try and open. Tilting the frig back will help solve this problem.
Dec 31, 2009 | Kenmore Refrigerators
Front door latch on astro won't allow door to close
use a large screwdriver,tire iron or a wooden spoon[?] inserted into the 'hole'between the latch levers,where the post should be.lift door latch as if to open door,pull/pry latch 'ears' open.if they don't stay in place when opened fully,latch may be broken.
Oct 10, 2009 | 1988 Chevrolet Astro Cargo
I have a canon ir 400 the machine shows close the front cover but it is already close?what is the problem?
Try to open and closed the front door several times,If the left cover and the front door are closed properly and still showing "close front door" most
probably the internal contact of door switch are not good , door switch replacement is needed
Jul 06, 2009 | Canon imageRUNNER 400S Copier
"Close the front cover" sign even the door is closed already
On Canon copiers the close front door can be caused by other doors besides the front door.Try the fuser door an the left and the vertical transport door.Good Luck
Mar 27, 2009 | Canon imageRUNNER 400S Copier
Message says "unlock door", but the door is already unlocked.
redo the self clean, something got stuck... also, dont use the selfclean again, use easy off overnight, self cleaning sucks and uses lots of $$$$$$$.
Feb 13, 2009 | Kenmore 75620 / 75621 / 75622 / 75624 Gas...
Saying to close door and we already have
When you shut the door , do it very firmly until you can hear the latch click, if it still will not start, then you could have a faulty door lock or a communication problem between boards.
Plz rate my solution.Thanks.
Dec 23, 2008 | Hotpoint Aquarius WD640 Front Load...
Canon imageRUNNER 400S Copier Logo
112 people viewed this question
old marine
old marine
