Question about RCA D52120 52" Rear Projection Television
Won't turn on no power to light anything. Power to flyback. stumped! HOT maybe caps??
  • RCA Master
  • 1,527 Answers
Hello have you check the glass fuse inside the power supply if ok then it could be the lineoutput transistor .when you change the fuse make sure you use the same rated. the value will be on the end of the fuse good luck
regards
shaun
Posted on May 31, 2010
My Philips 51PP9200D/37 tv won't turn on. The lighted power button stays lite but nothing else happens. Could this be the Flyback transformer?
It could but it could be about 50 other things as well. You have a voltmeter, and know how to use it? going to need a service manual as well.
Dec 19, 2012 | Philips 51PP9200D Television
My picture just faded out now the power light just blinks on and off but on picture or sound I turn it on and on/off lite blinks on and then off on then off again and stays off
The deflection board is the most likliest cause. The flyback and Hot plus the power caps all on the deflection board are famous for having issues. Often its best to replace the deflection board. Your model uses the PSB-260 deflection board which is available from www.tvrepairworld.com
Jul 11, 2011 | RCA R52WH73 Projection Television
Sony KV25X5D CRT TV. When turned on the screen remains black, no sound. Red led flashes 2 times.
Service manual: http://raoul.foucault.free.fr/docs/SONY%20KV-25X5.pdf
This ia an old CRT TV, THERE IS NO POWER SUPPLY BOARD BY ITSELF that you can buy! I sure like to see this 'POWER SUPPLY BOARD' from TVPARTSANDMANUALS.COM!
The main board has power supply, controller, Flyback xformer, etc.
You need to do in-depth troubleshooting, check the H.O.T, Flyback xformer, caps, etc.
Dec 13, 2010 | Televison & Video
My RCA - R52WH74 television will not turn on.
You need to replace the flyback and the H.O.T. transistor. the 270125 flyback with H.O.T. repair kit from www.tvrepairworld.com should fix that issue. The kit also contains the CD with detailed instructions
Jan 06, 2010 | RCA R52WM24 52" HDTV Projection Television
SONY TV KP-46WT510
the problem of your tv is the flyback...the power is fluctuating that makes the power light flicks on and off continuously.change the flyback,the flyback is apart that have a cap and connected to the tube...
Oct 01, 2008 | Televison & Video
When engine is turned on, brake lights STAY ON continuously. Have replaced brake switch twice, adjusted plunger, replaced brake booster, calipers, master cyclinder, brake hoses, and bleed brakes. This is...
if brake are only staying on with key on it would have to be in turn signal switchsomehow feeding thru since t/s work off of ignition power and brake lights are powered all the time. check and see iof your turn flasher is hot and maybe un plug it.
Aug 22, 2008 | Chevrolet S 10 Cars & Trucks
Flyback board for RCAd52w20
a bad flyback will inhibit the protection circuit. This sounds like what's happening.
Aug 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 51F510 screen wont turn on
lighting can effect anything and everything, call insurance and get replacement value for set.
Nov 16, 2007 | Hitachi 51F500 51" Rear Projection...
Black screen no sound
What is the model or chassel number it be a few thing H.O.T Resistor Caps etc..most likely horizontal output transistor.
Nov 12, 2007 | Televison & Video
RCA D52120 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
