Water Level sensor is not functioning properly. May need cleaning or replacement. Seeking service manual.
  • 343 Answers
The water level sensor tube may be blocked. Try blowing through it from the sensor end. If it's clear, get a tube and blow into the sensor and see if that effects the machine.....Try googling the brand and model of the machine. Most important to have brand and model number when seeking information
Posted on Jun 16, 2010
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
Will not make ice. Low water level light stays on when it is full of water.
Maybe water level sensor not functioning properly.
Or maybe need cleaning.
What is the model and brand of the machine?
Jun 08, 2015 | Kitchen Appliances - Others
I have a Samsung front load washing machine wf328aaw/xaa. the washer stops when it gets to the drain function. The drain pump motor is not getting the 120 to run the motor. I removed and tested the
There is a water level sensor that could inhibit the operation of the pump if it is indicating that the water level is low. There is also a small relay in the control panel (on the control circuit card), which may have dirty contacts. That is the contacts are not closing properly. Unfortunately, this relay is not readily accessible to consumers and even quite difficult to service for the professionals. I posted a description of the repair or cleaning of the contacts on the question placed by another user "My Drain Pump Doesn't Work"
Oct 19, 2014 | Samsung WF328AAW Front Load Washer
Service light on Honeywell humidifier
Sounds like a Water Level Sensor problem. Read the service manual, pages 51 and 53.
http://www.forwardthinking.honeywell.com/related_links/humidification/69_2285.pdf
Unplug the power cord. Turn OFF water. Remove the Water Level Sensor - One screw holds down the spring clip. Remove water scale in the compartment and on the Sensor. Test Sensor with an ohm meter. If OK, reassemble and try again. If bad, replace the sensor.
If you have heavy scale buildup in the sensor compartment, you need better water filtration. Your problems are just starting. This system can be very difficult to clean thoroughly.
Nov 15, 2012 | Honeywell Truesteam HM512W1005...
1. I need a service manual 2. how do you raise the water level of the machine
The water level sensor is a pressure switch and there is setting to which as the water gathers into the TUB the pressure exerted on the diaprgram within the pressure switch will correspond and determine the point of switching. So to increase the level within ( make sure that the switch is working as a damaged pressure switch will REQUIRE more water pressure to switch -- faulty diaphragm.)
To increase the level you can set the diaphragm controller to a higer setting-- this provision is seen on most pressure switches so that a higher pressure is needed to switch on thereby the water level goes higher.
Jul 31, 2011 | LG WM3885HCCA Washer
My humidifier all of a sudden just stopped working. Can you tell me of any common issues and their remedies for this humidifier ?
From the troubleshooting section of the manual (http://www.crane-usa.com/manuals/HumidifierManual2008.pdf):
Problem Humidifier power light is staying red and not turning green Humidifier is working than stops: ? Solution Ensure that water level sensor is assembled properly. ? Clean water float ? Call service center and request replacement water float ? If humidifier does not work at all: ? Ensure it is properly plugged into a power outlet. ? Check that the switch is in the ON position. ? If Power On indicator light does not come on, bring to authorized service station.
Nov 01, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
The red ligt on with water inside
FROM TROUBLESHOOTING SECTION OF MANUAL:
Humidifier power light is staying red and not turning green Humidifier is working than stops: ? Ensure that water level sensor is assembled properly. ? Clean water float ? Call service center and request replacement water float
Jan 23, 2009 | Crane Frog EE-3191 1 Gallon Humidifier
No water vapor coming out
You might need to check either the water level sensor or make sure that there aren't any deposits on the nebulizer. I just posted the following sections from the manual for another problem:
According to the Crane's Troubleshooting section:
The power light is green but there is no mist being emitted:
- Check that there is water in the tank.
- Check for possible lime deposits on the water level sensor or the nebulizer.
- Make sure that nothing blocks the vapor output slots.
- Check that the fan vent on bottom of humidifier is not blocked.
- Empty the humidifier and rinse the water basin with cool tap water and allow to dry for 15 to 30 min.
Humidifier power light is staying red and not turning green. Or, Humidifier is working then stops:
- Ensure that water level sensor is assembled properly. (I scanned a page from the manual that shows how to dismantle and reassemble the sensor: here)
- Clean water float.
- Call service center and request replacement water float.
Barring that, here is the service center contact info:
Dart Warehouse Corporation
Tel: 1-888-599-0952 (Business hours Mon-Fri 9:00 am - 4:00 pm Ct)
Website: http://www.crane-usa.com
1835 Ferry Road
Naperville, Illinois 60563
Jan 19, 2008 | Crane Pig Humidifier
Fan runs but no moisture
According to the manual, there may be a problem with your water level sensor. According to the manual:
I scanned in the page from the manual that shows how to dismantle, clean, and reassemble the water level sensor here.
If that doesn't work, you can try contacting the manufacturer:
Tel: 1-888-599-0992 (Mon-Fri 9:00 AM - 4:00 PM Central)
1835 Ferry Road
Dec 09, 2007 | Crane Frog EE-3191 1 Gallon Humidifier
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
