Question about Samsung CLX 3160fn All-In-One Printer
CLX - 3160FN
Trying to copy and I keep getting the error message that the scanner is locked.....
  • srlee Apr 16, 2008
    Can not copy error scanner is locked? Please help!
Look under the flatbed (do not take anything apart) just look where the paper comes out when you print...you will see a green switch on the left, push or pull it, this is the scanner lock...I am guessing it is for transportation purposes...I had the same problem and this was the fix...Good luck
Posted on Apr 16, 2008
Samsung CLX-3160N Document jam Scanner Error
the printer samsung clx 3160nprinter to check the any papper part .to clear the papper jam then will be the adf scaner sencer hang.so you can change the adf paper senser or correct fix the senserliver. best wishes
Apr 05, 2013 | Samsung CLX 3160fn All-In-One Printer
My scanner locked clx -3160fn
There is a green tab located in the paper output section of the printer. If you side your hand below the keypad on the left side you will feel the tab sticking down. Pull the tab towards the front of the printer to unlock the scanner. Then press the Stop/Clear button to clear the scanner lock message. Hope this helps you.
Nov 23, 2010 | Samsung CLX-3160 All-In-One Laser Printer
I have a samsung clx-3160fn printer I replacEd blk toner and it keeps sayn invalid toner .... I even refilled old toner and same error... Invalid toner
I have the same problem in a CLP-300. I have tested 3 diferent aftermarket chips from different manufacturers and always the same message: "invalid black toner" and the black toner light keeps red
Sep 21, 2010 | Samsung CLX 3160fn All-In-One Printer
The printer will not print I receive an error message
undr the scanner the is a lock.Unlock it...it looks like a switch.The scanner does not righ the home position
May 29, 2010 | Samsung CLX 3160fn All-In-One Printer
How you unlock the scannerof the samsung CLX 3160fn
The lock is the light green, slide the lock towards the front to unlock the scanner.
Mar 20, 2010 | Samsung CLX 3160fn All-In-One Printer
Error message "scanner locked" on clx-3160fn
common problem with these printers,need to replace flatbed scanner.this is where you copy and send documents.
Jul 15, 2009 | Samsung CLX 3160fn All-In-One Printer
Re Samsung CLX-3160FN & Transfer Belt Error
Take out the Imaging unit ,transfer belt and fix it properly.
Also take care that you will keep the printer on even surface.
IF nothing is solving the problem then you need to replace the transfer belt as a final solution.
Jun 18, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3175FN Scanning Error
I think the laser part should be unplug in Data cable and power then plug again ..
Jan 15, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3170 scanner locked
Many scanners contain a scanning head lock to keep the scanning head from moving during shipping. This may still be still be in the lock position. All scanners are different but check the documentation on how to remove the head lock.
Dec 25, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN prints and copies fine but can't scan
This may be obvious, but there's a "scanner lock" on this machine. It ships locked, and you need to unlock it when you receive it. Look up under where the paper comes out when you print, and on the left there's a little green switch. Make sure it's pulled towards you (you can see it also through the glass on the scanner bed).
Jan 04, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX 3160fn All-In-One Printer Logo
109 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
