Question about Seagate U6 (ST340810A) 40 GB Hard Drive
My computer displays boot disk failure . is it true that if i put the hard drive in the freezer it will work again? i view the video in youtube
  • 108 Answers
Seagate HDDs are showing problems nw a days.. ok first listen to HDD carefully if it is generating some sound.. (Tak Tak Tak.. type sound). if not try to change the HDD Cable and boot... Dont put inside freezer.. there will be water formation inside hdd which makes short circuit..
Posted on Jun 01, 2010
  • 39 Answers
That depends on what your hdd problem is. If the bearing is going out on you and the disk is generating a lot of heat, then the freezer trick might give you just enough time to get critical data copied. I've done it many times in my career both corporate & as a consultant. Always put it in a good ziploc bag when you freeze it. Watch for condensation as the drive heats up. It is best to use long data & power cables and set the drive on a solid surface OUTSIDE your PC case. If you have to do this to extract data, the next stop for this drive is a recycle bin.
  • 1 more comment
  • coz Jun 01, 2010
    Well, what is your objective? Data recovery or making the drive work again? How old is the drive?
    A boot failure can be caused by a failing hdd or due to the drive information area (factory servo written) becoming corrupt (I've seen virus cause this). If you provide as much specific info as possible, I can give you more precise recommendations.
  • coz Jun 02, 2010
    Just to make things clear:
    An old failing driver cannot be made functional by freezing. So, how old is the drive? Does it make clicking sound (it is trying to recalibrate)?
    If it's a relatively new drive and you need to get critical data off, then thermal characteristic control definitely helps.
    A relatively new drive that is mechanically good, but has logical errors will NOT benefit from freezing. Just reformat, scan for error and return to service.
    I hope this helps.
  • coz Jun 08, 2010
    If you hear it clicking, the drive is failing the initialization sequence. During this process, it needs to determine the drive characteristic by reading the factory reserved area. There are a number of possibilities why it can't read this area: 1. damaged head, 2. damaged platter, 3. corrupted reserved area.
    If you have important data to recover, you can try recovery software. The chances of recovery is not very high.
    You can send the drive to a cleanroom facility. They take the platters out and mount them on their recovery system, then read the data & save to an alternate media.
    There are low-level disk utilities that will read the reserved area & validate the data. There are also utilities like Spinrite which will scan the drive for recoverable data.
    Any of the above will cost you time and money. If you are just trying to recycle the drive, it may not be worth the effort.
    President:
  • 1,902 Answers
That is a myth and I would really recommend you to NOT try it as when it starts to dry out your electrical will get condensation in it then you will have to replace your hard drive and other parts instead of just getting a new HD
Please rate
Posted on May 31, 2010
Testimonial: "how to fix it>?????"
No Hard drive found
I am in agreement William.
What do the Radial Aluminum Electrolytic Capacitors look like?
http://capacitorlab.com/visible-failures/index.htm
http://www.youtube.com/watch?v=Lut7MX5Dd_A
http://support.asus.com/Download.aspx?SLanguage=en&m=P4SP-MX&p=1&os=
Post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | ASUS P4SP-MX Motherboard
Display PXE-E61: Media Failure, Check Cable PXE-MOF: Exiting Intel Boot Agent Will not boot to windows. I boot from the hard drive and still get an error
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Sep 25, 2012 | Gateway MX8741 Notebook
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
The computer is having trouble finding the hard disk.
The problem could be a faulty hard disk or a faulty disk controller.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jan 27, 2012 | Computers & Internet
Disk boot failure on compaq presario S7300CL
Hi friend,
The message, "Disk boot failure" often means that the OS is corrupt and needs to be re installed. Try restarting the computer twice or thrice and check whether you can log in to the system. If the same error displays again then you have to re install the OS. But re installing the OS leads to data loss from the hard disk. So at such kind of situations you need a data recovery software to recover your data back. Yodot Hard Drive Recovery is a wonderful data recovery software which performs recovery after disk boot failure.
Jan 12, 2012 | Computers & Internet
Disk boot failure insert system disk
First if your computer has a floppy drive, check to a floppy drive does not have a floppy disk in this drive.
Your computer cannot find the hard disk to boot up.
Go to your BIOS to see if the BIOS detects the hard disk, if not remove the hard disk and re-connect it again and see if it boots up.
If it still does not boot up then most likely the hard drive has failed.
To get the computer working again, install a new hard drive, install Windows and the computer's device drivers and your programs.
Dec 10, 2010 | Computers & Internet
I'm getting disk boot failure insert system disk and press enter please help
sometimes this occurs when the damage in the windows or hard disk
please put the windows cd and try to re-install the windows ,then the problem again displays you must change your hard drive.
Oct 13, 2010 | Computers & Internet
I'm receving "disk boot failure" error. Compaq wf1907 monitor
if your computer has a floppy drive and you have inserted a disk, remove the floppy disk and try booting again.
if this is not your case you can try out a couple of things
1. Check the CMOS of your computer
To do so
- Boot your computer and on the manufacturers logo window press F2 or Delete depending on your computer.
- In the bios check for the availability of a hard disk drive under the storage category if it exists look for the boot order window or menu. check i your hard disk is enabled for booting in this page.
- If all the other methods do not work and your OS is Win XP you can reinstall it in repair mode. Otherwise it would be better to visit your nearest service store.
Nov 03, 2009 | HP Compaq WF1907 Monitor
PXE-E61: media test failure check cable
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 18, 2009 | HP Pavilion dv1000 Notebook
2 hard disks
Because you have a dual boot system, you have two 'C' drives, which in fact is a good idea if you get a system failure on the drive you are using, you can select the other and still view any files on the other drive through my computer.
f using XP, right click my computer, then properties, then click advanced tab, then startup and recovery listing click settings, at the top system startup, select the default operating system, then click EDIT button, then delete the value that points to the other hard drive more than likely listed as disc1, disk 0 will be the one you have connected as master boot hard drive
Aug 29, 2008 | Microsoft Windows XP Professional With...
Disk boot failure
sounds like a hard disk drive problem. If you are comfortable with working inside your computer, you can open the case and remove the cables to the hard disk, and re-connect them again firmly.
Jul 07, 2008 | Computers & Internet
Seagate U6 (ST340810A) 40 GB Hard Drive Logo
277 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
