Question about Mamiya RB67 Pro SD Medium Format Camera
I need repair manuals for MAMIYA RB 6x7 ProS: Lenses & Body. Where are they available?
Http://stores.ebay.com/photobooksonline/Service-Repair-Manuals-/_i.html?_nkw=Mamiya+rb&submit=Search&LH_TitleDesc=1&_fsub=6&_sid=98011905
Posted on Jan 19, 2012
3 Suggested Answers
cammedic
  • 667 Answers
SOURCE: aperture diaphram on mamiya secor lens 80mm f/2.8
The lens has a lever marked A/M near the aperture ring. If the lever is in the 'A' position, the lens will stay wide open until you trip the control lever at the back of the lens next to the rear optics. In the 'M' setting, you can see the aperture move as you change the f-stop setting on the ring. Set the lens to anything but wide open and move the control lever with your finger. You should see that aperture move.
Posted on Jan 14, 2008
SOURCE: I NEED TO FIND INSTRUCTION
have you tried Mamiya's website?
they have some instruction manuals to download.
m.
Posted on Dec 06, 2009
ASA setting for M645
It's not on the body but on the finder. Assuming the finder has one, it'll be on the right side (as viewed from the back). See pages 13-15 of the manual available from http://butkus.org/chinon/mamiya/mamiya_m645/mamiya_m645.htm
Mar 28, 2014 | Mamiya 645 Medium Format Camera
My camera shutter is stuck and all I see through the lens is black?
Need servicing from the service center. They disassemble the camera & unlock the shutter from internal side.
Aug 09, 2012 | Mamiya/sekor 500 Dtl 35mm Slr Film Camera...
Mamiya C3 film advance
Hi there,Here's a link to a PDF instruction manual of your camera body.
http://www.cameramanuals.org/mamiya_pdf/mamiya_c3.pdf
It is possible that the crank handle is missing, as it is a removable piece. Bring your camera to a camera shop and see if they have a box of old parts to replace it with. You can either use a regular round knob, or (if you're lucky) one with a crank on it.
Aug 01, 2012 | Mamiya Used C3 Professional Tlr Body...
Focusing a mamiya k/l lens.how do i use the floating element ring? thank's
Step A. Set the floating element ring to its' infinity position (if you are using extension tubes, this will vary and you must set according to the tubes).
Step B. Focus the camera on your subject.
Step C. Look at the bellows scale on the camera body (it will generally range from 0-40) Important: Don't read the scale akin to the lens you are using. This will make perfect sense, when you examine the bellows. Mentally record this number.
Step D. Adjust the floating element ring to the recorded number.
Step E. Leave the ring on this new setting and re-focus the camera on your subject.
Step F. Make sure the dark slide is removed and capture your photograph. :)
- That's it mate. Not so foreboding, when you
Dec 12, 2010 | Mamiya K/L 127mm f/3.5 RB Lens
I installed a Mamiya lens on my RB 67 Pro S. I cocked the shutter and fired it. Now I can't recock shutter and I can't get the lens off. The lens blades are closed.
Hi RMT, I sueest you only one thing. Please visit the service center. Beoause you already cocked the shutter & make it fired. So please follow the link its really very helpful for you.
LINK
Thanks & waiting for your feedback.
Feb 17, 2010 | Mamiya RB67 Pro SD Medium Format Camera
I have a RB67 pro SD and just bought a #1 extension tube for it but the lens doesn't want to mount deep enough? What am I doing wrong? I can't close the lock ring.
You might have an earlier rb pro S ( not pro sd ) version.
The later pro sd lenses have a larger diameter rear element.
The rb67prosd extension yube is clearly marked pro sd the older version just has-
mamiya no.1 45mm.
Nov 25, 2009 | Mamiya RB67 Pro SD Medium Format Camera
Mamiya RZ67 Camera Older model.
Problem solved- The camera does not operate correctly unless the battery is in good condition, in place, and all the contacts are clean. In the RZ76 as opposed to the old RB models the components "talk" to each other: via electronic circuits. The back "tells" the camera bod if the dark slide ins in or out and whether the film is loaded or at the end of the roll. If the batter voltage is too low or the contacts are no clean and making full contact the body has no way of knowing the condition of the film backs and the interlocking mechanisms fail to work.
What I did was firstly test the battery under load and discovered that the cell was a bit low. It was a fresh battery but it is a good idea to turn the camera off after shooting in case the is a slight current draw when the camera is idle (?) . I replaced the battery and traced the voltages through the body to see if it was getting to some of the contacts such as the onces on the meter prism which has LEDs to be lighted. I also used an ohm meter to check out continuity- everything seemed to be in order. I then cleaned all the contacts including the battery terminals withl alcohol and made sure everything was dry and clean.
Now- everything works. The camera was turned off overnight and the battery has lost no voltage when tested under load..
This camera is equipped with RB lenses which have no electrical contacts and therefore the camera and lenses can't "communicate" so the meter will not work with theses older lenses.
Ed
Apr 09, 2008 | Mamiya Photography
Mamiya-sekor C 65mm lense
Any luck with the lens?
Need help?
atdlee@netzero.com
Oct 18, 2007 | Mamiya K/L 65mm f/4 RB Lens
Mamiya RB67 Pro SD Medium Format Camera Logo
342 people viewed this question
Top Mamiya Photography Experts
Tony
Parshiv Luthra
Are you a Mamiya Photography Expert? Answer questions, earn points and help others
