Question about Proform LX660 Treadmill Walking Belt
Turns needed to install adjustment bolts on rear roller of treadm
My question is regarding the installation of the rear roller on my Proform LX670 treadmill. I would like to know approximately how many turns are needed to install the adjustment bolts properly without breaking the plastic end caps?
    President:
  • 1,902 Answers
There is no turn amount, you just want to go until they are snug. Do not crank on the bolts or force them you will be able to tell when tight enough
Posted on May 31, 2010
Replace deck on Precor 9.45i
Replacing a Treadmill Running Belt and Deck Following is a basic guideline of removing and replacing the running belt and deck on a treadmill. Due to different brands and designs of treadmills, the following should only be used as a guideline. If any of the information is not exact to the treadmill being serviced, refer to the service manual or call Sportsmith for further help. Tools Needed: Phillips Screwdriver, Set of Allen Wrenches, Set of Box End or Open Face Wrenches (Tools needed may vary depending on treadmill. )
  1. Switch the Power off on the unit.
  2. Next, unplug the unit from the wall.
  3. Remove the finger guard retaining screws and carefully remove the finger guards from the deck at each end of the rear roller.
  4. Loosen each rear roller bolt by 10 full turns. Then count the remaining turns necessary to remove the rear roller bolts. Remember to write down the number of turns needed to remove the bolts in each side for future reference.
  5. Carefully remove the rear roller from the unit. Clean any wax or debris buildup from the roller and place it aside.
  6. Raise the shroud and secure it with a bungee cord.
  7. Work the drive belt off the motor pulley by hand turning the flywheel while pushing the belt aside.
  8. Now remove the front roller retaining bolts.
  9. Carefully remove the front roller from the unit. Clean off any wax or debris buildup and set it aside.
  10. Loosen and remove the deck mounting hardware.
  11. Move the deck toward the left side of the frame to free the deck from the right side. The deck will move down once the frame has been cleared.
  12. Remove the deck and belt by raising the right side edge of the deck over the frame rail and sliding it to the right to remove.
  13. When installing a new belt or deck it is important to note that a new belt and deck surface should always be installed together. Failure to adhere to this guideline will severely shorten the life of the newly installed parts. Some decks can be used on both sides. However, be sure that each side is only used once. Be sure to install the belt in the proper direction on the unit.
  14. Install the belt and deck by first putting the belt on the deck, and then installing them from the right side as a unit.
  15. Be sure the deck is lined up with the frame and push the deck to the left side.
  16. Now carefully lower the right side of the deck to insert it into the frame rail and then push the deck to the right as far as possible.
  17. Re-install deck mounting hardware. (Check with mfr. for proper torque during install process.)
  18. Carefully place the front roller on the deck under the belt and push it forward into place, while placing the drive belt on the inside of the drive pulley.
  19. Replace the front roller bolts. (Check with mfr. for proper torque during install process.)
  20. Now spin the roller by hand while pushing the drive belt onto the pulley. Be sure to spin the roller several times to insure complete installation of the drive belt on the pulley.
  21. Install the rear roller into unit. Carefully start each bolt and turn one to two threads to ensure no cross-threading has occurred.
  22. Tighten each rear roller bolt the number of turns you kept earlier for reference.
  23. Now, Plug in and power on the unit.
  24. Carefully remove the bungee cord from the shroud and lower it back into place.
  25. Start the unit at a very slow speed and check for proper belt alignment. Remember to start at the slowest speed possible and be ready to stop the unit quickly if needed.
  26. If the belt is moving to right side of unit tighten the right roller bolt, If the belt is moving to the left side of the unit tighten the left roller bolt until the belt is tracking properly.
  27. Caution: make very small adjustments such as 1/4 turns and then watch the belt for several moments before making another adjustment.
  28. Once the belt is tracking properly walk on the unit at a slow speed and check for belt slippage on foot fall. If this is happening tighten each of the rear roller bolts equal turns until the slippage is no longer occurring. Caution: make very small adjustments such as ¼ turns and then watch the belt for several moments before making another adjustment.
  29. Now use the unit at a jogging speed to check for belt travel or slippage.
  30. If slippage still occurs make small equal adjustments (1/4 turns) to both sides of rear roller and re-test.
  31. Install the finger guards once you have enough clearance from the rear roller.
  32. Some manufacturers require wax or lube during the install process, please consult your owner's or service manual for further information regarding this.
How to Replace Treadmill Running Belt and Deck
Feb 22, 2014 | Precor Exercise & Fitness
How to replace a Treadmill Precor 9.31 belt
  33. This concludes our instructions of how to install a replacement treadmill belt and deck.
Oct 16, 2013 | Precor 9.31 Treadmill
Replacing precor 956i treadmill deck
Oct 09, 2013 | Precor 956i Experience Series Treadmill...
The belt slips when you are on the treadmill
check the front and rear rollers. One of them should have adjustment bolts on both sides. Adjust both bolts equal turns to tighten belt a bit at a time until the slippage stops. tighten one side or the other to align the belt as well.
hope this helps
Aug 26, 2011 | Proform Exercise & Fitness
The belt always moves to the right side
your roller ajustments are loose, loosing all the rollers front and back, re aline belt to center, tighten front roller first then tighten rear roller, Rear roller has 2 seperate ajusting allen bolts, 1 on each side, count the turns on each bolt when turning them inward, keep the count even turns on both allen bolts
Oct 24, 2010 | Proform CrossTrainer Treadmill
How do I adjust the belt on my Proform Crosswalk Gtx? The belt is too far to the left on the rollers. Thank you.
You can adjust the rear roller bolts tighten the left side to make the belt come back to the right. If it will not come back you may have a broken endcap causing the problem
Aug 09, 2010 | Treadmill Doctor Proform Crosswalk Gtx...
I need to replace the walking belt on a ProForm PFTL40070.
Installing An Icon Fitness Treadmill Belt You can save yourself a great deal of time by following these instructions as opposed to those of the manufacturer. Please contact us if you need any further help. UNPLUG THE TREADMILL BEFORE DOING ANY REPAIR!
Step #1- Remove the plastic railing on the right hand side of the deck. Most railings are stapled down so using a flat head screwdriver or another prying device is the easiest way to do it. The plastic is refastened using screws provided with the belt in a later step. If you cannot see the staples, you may need to remove the cosmetic center insert cover first by simply sliding it to the back of the treadmill. This rail is on the opposite side of the front roller pulley and motor. Some of the models aren’t stapled down and with these, you simply remove the rear end cap and slide the rail off the back of the treadmill.
Step #2- Loosen the rear roller and remove the two adjustment bolts. Some models have a spring loaded tensioner on the right hand side so be careful when removing these bolts. After the bolts have been removed, remove the rear roller end cap(s). The rear roller should now simply slide out of the walking belt.
Step #3- Remove the motor hood. Using a black permanent marker, make a mark on the front roller adjustment bolt on the motor compartment side at exactly where it fits flush with the roller so you will know where to retighten it later. The adjustment bolt is on the right hand side of the front roller. Then remove the bolt with a 7/16” wrench. Step #4- Remove the deck screws which should now be exposed since the plastic cover is off. In this step, also remove the staples with a pair of pliers. Be sure to remove all deck and staple debris before continuing.
Step #5- This step is easiest if you have another person to help but it is possible with one person. Lift up the side of the deck that has been loosened and making sure that the front roller is angled toward the deck, remove the old belt by simply pulling it to the side. A few models had a side hand rail that attaches to the side of the treadmill and if you have one of these, the hand rail must be removed first.
Step #6- Install the new belt just like you removed the old belt. Before proceeding, make sure that the belt is in the center of the two metal belt guides that protrude from the bottom of the deck. The guides should be angled where the sides of the belt are turned slightly upward. Sometimes these can get bent during installation so make sure they are contacting the edges of the belt or the belt will not stay centered properly. Step #7- Install the front roller adjustment bolt where you just start it. Do not return it to its original position yet.
Step #8- Install the deck screws.
Step #9- Slide the rear roller back into position and insert the end caps and rear roller bolts. Most models have a small ground wire on one of the rear roller bolts. Make sure to just slide this over the bolt before it is inserted in the roller. The ground wire dissipates static electricity that is built up on the walking belt to help the roller bearings last longer and reduce static discharge on the electronics.
Step #10- Adjust the front roller bolt to its original position.
Step #11- Tighten the rear roller bolts to where the tension on both sides feels even and you can lift the walking belt 2-3” in the center of the belt from the deck surface.
Step #12- Replace the right side railing with the screws provided using a screwdriver.
Step #13- Start the treadmill and align the belt according to the instructions in the owner’s manual or on our web site troubleshooting page under “Belt Centering Tensioning Instructions.”
Step #14- Once the belt is aligned, test the belt for slippage. If the belt slips at all, tighten the rear roller adjustment bolts equally on both sides ½ turn until the slippage is gone. Do not over tighten the belt where it has less than 2” of lift from the deck surface.
Step #15- Replace the motor hood and make sure no odd noise is apparent and that the belt is tracking and tensioned properly.
May 19, 2010 | Proform 325 Treadmill Walking Belt
How do you adjust a belt on a Proform 385X. It is
If the walking belt is off-center, first remove the keyand UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the hex key to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the left bolt counterclockwise 1/2 of a turn. Be careful not to over tighten the walking belt. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered
May 17, 2010 | Proform Exercise & Fitness
Treadmill is slippng badly
There should be an allen head bolt on each side at the rear of the treadmill going throughthe rear cover into the tail [rear] roller. Turn each one 1/4 turn at a time equally untill slipping is stopped. If belt tracks more to one side tighten slightly more on that side.
Feb 06, 2010 | Proform Exercise & Fitness
Installing endcap assembly on a pro form treadmill#585tl getting proper tension on the rear roller right bolt(with spring) to take slack out of belt for proper adjustment. I can't tighten the bolt...
Well congratulations for having gotten that far! The spring on the right hand side needs to be on the rear of the bolt. Be sure it is not in front of the roller or it will only tighten a certain amount. The bolt goes into the roller first, then the washer then the spring/sleeve then another washer and then the nut on the end. If you need a diagram you can go to iconservice.com and search for pftl4206 that should be your model and go to the parts listing in the rear of the book for the diagram.
Good Luck!
Tim
Jan 17, 2010 | Proform Crosswalk 500 Treadmill
Proform LX660 Treadmill Walking Belt Logo
106 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
