Question about Vacuums
Vacuum Power Switch on Handle Doesn't Work
Hoover Upright Vacuum model U5470-900   -  The On/Off switch on the handle does not properly engage the power switch deeper in the handle assembly. It appears to ride over the lower switch and doesn't engage it to operate it. If I play with it, I can get it to maybe turn on the vacuum, but, then the upper handle switch won't turn it off. Our current workaround is to use the power cord for on/off operation
  • Anonymous Jul 09, 2008
    The switch in the handle is no longer connected to the on/off switch within the sweeper. We are turning the unit on by plugging it in.
  • Anonymous Mar 22, 2014
    switch does not engage, vacuum always on
The switch is very cheap. I have the same vacuum. The solution is to stick a thin peice of cardboard under the slide track for the rod in the handle assembly. You will see the rod when you disassemble the handle for the sweeper. Move the on/off switch on the handle assembly a few times and look at the bottom of the of the assembly to see a thin black rod with cut grooves. This rod activates the on/off switch.
There is a little track that this thin rod of plastic travels along. However over time the the plastic rod begins to recess further into this track. The rod still slides but is now to far away to activate the on/off switch. This isn't very technical but just slide a thin peice of hard paper or cardboard between the rod and the slide track.
Make sure the red on/off switch on the sweeper is set to off. Put the handle back with the switch in the off position. Test the sweeper using the handle a few times before reassembling the screws. This fix may not be permanent according to how you have the paper/cardboard set between the slide track and the rod but it works very nicely.
Hope this helps! : )
Posted on Jun 23, 2008
  • Engineer Bob Jun 24, 2008
    -Update!
    When applying the cardboard or hard paper between the track and rod, bend it in a slight v shape so that the rod still aligns with the track. Ensure that the paper or cardboard stays in place by testing the switch after reattaching the handle assembly (do not yet install screws). If the power switch operates normally go ahead and install the screws.
    If pictures or a short movie would be more helpful, just reply in this topic.
    Bob
Replace on off switch on u5458-900 hoover vaccum cleaner
Remove the screws that hold the upper handle assembly onto the body of the vacuum. The upper handle assembly will slide off the back to reveal the power switch
Dec 28, 2013 | Hoover U6616-900 WindTunnel Bagless...
My new Hoover Wind Tunnel Upright UH50000 will not turn off unless I unplug it.
First I would be sure the handle was properly installed. Remove the two screws holding the upper handle in place and tap it bacwards to remove it. Set the switch inside to the OFF position. Next set both buttons on the handle to the OFF position and re-install the upper handle. If the switch still does not turn the vacuum on and off, the switch will need replacement.
Apr 01, 2011 | Hoover U6630-900 WindTunnel Bagless...
Just put handle on windtunnel u6401-9rm and the self propelled switch will not flip into self propel mode. is there an adjustment on the self propel part?
When installing the handle on this machine, you must be sure the on/off switch and the self propel button are both in the OFF position. The actual switch inside must also be OFF, and the metal fitting on the end of the power drive cable should be between the two lines molded into the plastic. After it is re-assembled, it is sometimes necessary to wiggle the handle up and down a bit to engage or disengage the drive button.
Mar 16, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
On/off switch not working
Please make sure the mounting screws that attach the upper handle to the lower handle are tight. This sets the proper spacing of the switch rod to the switch. If this does not help, you could remove the upper handle and cycle the switch with your finger. If it still does not cycle On/Off, the unit will need serviced.
Oct 04, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
Trouble engaging the on switch for both suction and to drive the roller on a Hoover Savy windtunnel (bagless).
The electronics in the handle are constantly going out. First things first though, recline the unit and turn the vacuum upside down so the front is resting on the carpet. Locate the black wired which is near the nozzle and body, wiggle that cord while the vacuum is on to test. if it cuts out, that is your problem if it doesn't replace the top handle and that will fix your unit
Aug 26, 2009 | Hoover U6630-900 WindTunnel Bagless...
Replace on/off switch on hoover vacuum
My wife picked one up on the side of the road that someone had tossed. The power switch would not turn off. I took the two bolts out of the top part of the handle, and then removed the screws along the back. This will remove the required panels to access the On/Off switch. Once I found the actual on/off button, I found it to be frozen in the "ON" position. After manipulating it for a few minutes, I got the switch to work. This machine now operates great, and I now have a Hoover :)
Nov 21, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
How to remove handle from Hoover 5445-900 upright wind tunnel vacuum
Hoover.com doesn't have a manual specific to your model but there is one similar which will show how to remove the upper handle from the body.
http://www.hoover.com/pdfs/manuals/U5467900.pdf
Do you have a replacement switch? If not I believe you can buy one from Hoover (the switch and/or the upper handle assembly). Unfortunately your model isn't listed on the website, is this a new vacuum? I recommend giving them a call, that would be the easiest way.
Also remember when working with electronics to unplug the vacuum. Even when there is no power residual electricity can remain in the wires. If you feel unsure, take it to a repairman.
Hope this helps!
Dec 22, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
390 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
