Question about Maytag Neptune MDE5500AY Electric Dryer
Drum not turning on front loader dryer - Maytag Neptune MDE5500AY Electric Dryer
  • Maytag Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
Posted on May 31, 2010
My Samsung front loader dryer squeaks when running
The rollers at the rear could be worn
Dec 20, 2016 | Samsung Dryers
Remove the drum
it all depends on the dryer. most of the front loaders require you to lift the Lid up, then take off two screws on the front panel(up close to the lidp) and then lift the front panel up and off.
Dec 26, 2014 | Dryers
Our Whirlpool Front LOADER WILL not start. All the lights on the front panels are but the drum will not turn. I have repalced the main control panel under the top of the drum.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 26, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Affinity front loader dryer. The drum is not
It's noisy If your dryer is noisy, check these: Rollers Idler pulley Glides Rear drum bearing Blower wheel Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it. Hope this helps
Dec 10, 2009 | Dryers
Dryer makes a thumping noise when drum is turning its an electric fridgidare de5520rw2
Sounds like you have flat spots on your drum rollers.
If your machine is a front loader, remove the front of the machine, this will expose the belt and drum, remove the drum and belt, and this will expose the drum rollers.
Check the rollers to see if they have flat spots on them, if they do replace them with new ones. This should solve your thumping noise.
If the rollers do not have flat spots on them then you can try to lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil.
I hope this helps
Oct 02, 2009 | Frigidaire Dryers
When I turn on the dryer you can hear a drag and turns loudly
Sounds like you may have a sock or something stuck between the drum and the front felt seal...or maybe your drum roller needs lubrication or replacement.
If you have a front loading machine you would normally pull the front of the machine off, that will expose the drum and seal, if you remove the drum, then that will expose the rollers.
Lube the shaft of the rollers with a good grade of machine oil such as
3 in One oil.
I hope this helps
Oct 01, 2009 | Maytag Dryers
My dryer keeps grabbing clothes strings and zippers and catching them between the drum and door. It's a front loader. How can I repair this?
The drum slides on your dryer are worned and possibly ate away the front bulkhead and drum.
These parts keep the dryer drum aligned.
Front panel needs to be removed to determine how extensive the damage is, hopefully changing the drum slides will solve the problem.
Aug 18, 2009 | Kenmore Dryers
My front loader gas Duet dryer has left brownish stains
Sounds like bad drum seals. Check all the way around the drum at the wall for sections of seals missing or an uneven gap around the drum at the wall.
Hope this helps.
Aug 14, 2009 | Whirlpool Dryers
Front loader Electric Dryer the belt
It's not that hard, but it can be a little tricky. First UNPLUG the dryer or turn off the gas to it, whichever is applicable.
Then, assuming you have the new belt, you will open the lint filter door. There will be two screw heads visible. Remove them. Place a knee in the center of the dryer just below the top. Place your hands at the front corners and **** hard while pressing with your knee and lift up on the top of the dryer. Once you do this, tilt the dryer top back until it rests on the wall behind the dryer.
Next remove the two bolts at the top front corners. Disconnect the wiring harness connector for the door switch and lift the front panel of the door up and away from the rest of the dryer. You will notice the drum rides on the front panel and will fall down.
Take out the old belt. Loop the new belt around the drum in the same approximate position that the old belt was riding. Take a small loop of belt and push it through the tensioner while lifting the tensioner to relieve tension off the belt. Then loop that end around the motor pulley.
To re-assemble the dryer, reverse the directions for taking it apart. Remember to hook up the wiring harness. You will have to lift the drum into place to make sure the felt on the front and rear ride correctly on the guides.
Jun 24, 2009 | Dryers
Dryer does not turn anymore, dried shoes inside
the belt that turns the drum has broken or come off
you will need to remove the housing and replace the belt or call for service
Good luck
Jan 07, 2009 | Kenmore 62602 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
