Question about Canon PIXMA MP830 All-In-One InkJet Printer
We are getting a black stripe about 6-8 mm wide on the back of prints. I have run drum clean ups and it will clear for a couple of prints then it comes back. Is there a waste tank that can be emptied and cleaned?
  • Lebanon Raingam
    Lebanon Raingam May 31, 2010
    Can you please let me know what model of printer are you using? When you say "I have run drum clean ups" I am confused, since your problem category is under canon pixma mp830 all-in-one Inkjet Printer not laser printer. Thanking you.
  • 29 Answers
There is probably a rubber spongelike piece, like the one another lady found who had this same problem. luckily for her it fell out with the next print job. take it to someone who can open the printer. ask them to remove or remount this rubber strip to solve the problem. more than likely its close to the ink source, since it is probably the rubber strip that wipes the ink off the nozzles?
Posted on Jun 03, 2010
HP color laserjet CP 1510 printing stripes on the left
Is this for all colors or just one color? There are three color toner cartridges plus a black cartridge.
Mar 09, 2015 | HP CC378A Color LaserJet CP1518ni...
My Canon Pixma ip3300 prints on top of an absolutely perfect printing, a sequence of stripes colored in magenta, the stripes are 2,7 mm wide and are 2,7 mm apart from each other. All other functions of...
try to clean the ink print head cartridges also its trailing (belt, pulleys) you can reach. a dirty ead may cause that or better check it to printer solution software, there you can test, align, clean printhead.
Feb 12, 2011 | Canon PIXMA iP3300 InkJet Photo Printer
Lines on print. There's are three lines on picture print only. Can't see the line on document. It's about 1/4 inch wide and going throught top to bottom.
Have ou gone into your menus. Into troubleshooting, then image quality.
You will want to run both the eliminate light stripes and eliminate smears procedures. that will purge the print head, blow air through the jets and hopefully resolve the problem. I do believe the 8550 has a Jet Substitutin procedure where you can do a workaround and make other jets make up for the light areas.
here are some directions, Will forward more
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Troubleshooting Print Quality Page], and then press the [OK] button.
  4. Evaluate the 'Light Stripes Test' page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. The 'Light Stripes Test' page is the last page of the Troubleshooting Print Quality Page that printed.
    WARNING: To avoid injury, do not touch the sharp metal strip attached to the clear rubber wiper blade in the Maintenance Kit.
  5. Use a clean lint-free cloth or a new paper coffee filter to gently clean the maintenance unit's clear rubber wiper blade, use only a wiping motion across the entire length of the wiper blade, and then empty the waste tray. A dirty maintenance kit wiper blade can cause white lines and weak or missing printhead jets.
  7. Repeat step 3 to reprint the Troubleshooting Print Quality Pages. If there are no missing or partially missing color bars then the print quality problem has been resolved. If there are missing or partially missing color bars then the printhead cleaning procedure will need to be performed. Continue with the next section.
To clean the printhead using the basic eliminate light stripes procedure:
  3. Press the [Up] or [Down] arrow button to select [Eliminate Light Stripes], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Basic], and then press the [OK] button. The printer will perform a head cleaning, which will take about five minutes. The printer will then print a cleaning page and a light stripes test page.
  5. Repeat steps 1 - 4 one more time. If there are no weak or missing jets then the print quality problem has been resolved. If there are still weak or missing jets after two basic light stripe cleanings, continue with step 6.
    NOTE: Do not try the Advanced Eliminate Light Stripes Cleaning mode without performing two basic cleanings first.
    To clean the printhead using the advanced eliminate light stripes procedure:
  6. Press the [Up] or [Down] arrow button to select [Advanced], and then press the [OK] button.
  7. Select the missing jet color and number. If necessary, check the light stripes test page to determine the color and jet number of the missing jet.
    NOTE: Only perform the advanced light stripe cleaning once. If weak or missing jets still persist, continue with step 8.
  8. Print the Troubleshooting Print Quality Page. Evaluate the Light Stripes Test page for missing printhead jets, such as missing Cyan, Magenta, Yellow or Black color bars. If necessary, perform the basic eliminate light stripes procedure one more time. If the Advanced Eliminate Light Stripes procedure does not resolve the weak or missing jets, perform the Enable Jet Substitution Mode. See the Related Items below.
Feb 05, 2010 | Xerox Phaser 8550DP Printer
When printing, a black stripe is printed on the back side of the printed pages (about 1/4'' wide, running from top to bottom). The ink strip bleeds through to obscure printed side. Any suggestions?
You need to have the exit rollers cleaned at a shop, and a mylar strip added to keep that from happening again. It's the ink from the cleaning station backing up thru the exit rollers.
Dec 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Have just placed new toner cartridge., prints have black stripes
Try cleaning the charger wire on top of the toner/drum unit. It should have a green plastic knob/handle to slide the cleaner left to right and back. Do this several times.
Sep 29, 2009 | Brother HL-2040 Laser Printer
Canon S900 - No black ink (none!)
Clean the contacts on the back of the print head.
Aug 22, 2009 | Canon S900 InkJet Printer
Pale vertical stripe on black prints
It sounds like the black drum unit needs to be replaced.
Apr 23, 2009 | Ricoh Aficio CL3500N Laser Printer
Repeating wide smudgy horizintal line across my printed pages
I had the same problem, replaced the PCR in the cartridge, the small black drum that pre charges the drum and erase the old image.
After that print was all back ok.
Regards
Dec 11, 2008 | HP Q2613A OEM Genuine Black Laser Toner...
Brother MFC9600 dirty printing
We were having a lot of print quality problems, similar to what you describe. We replaced the drum and it worked fine.
Nov 19, 2008 | Brother MFC 9600 All-In-One Laser Printer
Phaser Printer 8550 leaves black lines
There is a wiper blade between the print head and the drum. Sounds like you have some buidup on it causing your problem.
Nov 13, 2008 | Xerox Phaser 8550DX Laser Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
85 people viewed this question
old marine
old marine
