Question about KitchenAid 24 in. KUDU02FR Built-in Dishwasher
Want to remove the spray arm and clean the filter
Alot of food has accumulated under the filter. Is there a way to remove the spray arm and clean the filter?
    President:
  • 949 Answers
Below is a link showing how to clean out the sump area below the spray arms. If you want to clean the top filter when taking it apart, vinegar works to dissolve a lot of the deposits.
Sump Clean out
Posted on May 31, 2010
I have a kenmore elite dishwasher model 665. it is several years old, and within the last year, it leaves food particles in glasses, etc... i tried different detergents and switched back and forth...
There should be a filter in the bottom under the spray arm. There should be 4 to 8 screws to remove to get to the filter, and clean.
Jan 27, 2013 | Dishwashers
Dishwasher spray arms don't spin & spray water
Check that the water pumped on arms has enough pressure.
Aug 15, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Tip
How to Maintain your dishwasher.
There are a few simple things to do to your dishwasher to maintain it in good working order and to avoid any service call outs.
1. Firstly on a monthly basis you should check and clean the filter located in the sump of the unit.
Make sure all the water has drained out of the unit and remove the filter and give it a good clean and remove any foreign particles you may find in the sump.
2. In the unit there are 3 spray arms. These are the moving parts of the dishwasher that actually spray water out and do the cleaning. If any of the tiny holes in the spray arms are blocked up with foreign particles or food you will end up with poor wash results.
Each of these arms are removable and should be checked and cleaned on a regular basis. To clean the spray arms poke the holes with a pick of some sort and wash them under the tap.
Make sure the spray arms are fitted back correctly and are tightened back in place. Make sure they can also freely spin.
3. You should also see depending on your dishwasher model some sort of drain pump. If it is accessible like in the model above make sure there is nothing wrapped around the drain pump or something that could obstruct the drain pump from turning and draining the water away.
4. Make sure any fittings inside the unit are tight and not loose as the unit could then cause a water leak internally.
5. The screws around the door frame tend to work loose with time and also may need a tighten up.
6. A dishwasher is not a sink errator and cannot take away anything other than food that it can liquify. I recommend that you scrape your plates prior to loading the dishwasher.
You don't have to rinse them as the detergent needs some dirt and sauce to stick too
If you break a plate or glass remove the filter and clean it and have a look in the sump for the broken part.
If food does get in to the unit most of it will get caught in the filter but food can still get past this and can cause further problems where you need a service technician to remove the circulation pump and free up the pump.
Hope this helps.
on Mar 21, 2010 | Dishwashers
Food gets stuck on dishes especially in the top rack.
There is a waste filter in the bottom under the lower spray arm that needs to be cleaned periodically. If you are not cleaning it, it may be redepositing food particles on your dishes.
remove and clean the filter, and see if that helps.
Nov 21, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
I have a Maytag MDB9100A leaving food particles
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
m,.bn
Feb 23, 2010 | Maytag MDB9100A Dishwasher
KitchenAid Dishwasher (model KUDS01IJBL) has black gunk inside
That black gunk is caused by soap deposits and food particles that do not get washed down the drain. This all collects in the area around the door gasket and front of the wash tub and forms a sticky black sludge. You need to periodically clean the interior of the dishwasher out with a non-abrasive cleaner with some bleach in it to kill bacteria. You should also check the wash pump sump (located under the lower spray arm) to make sure it is not being clogged with food and debris. In order to access the pump sump, you will need to perform the following:
1. Remove the lower wash rack and lower spray arm.
2. Remove the upper wash rack and spray arm.
3. Locate the screws holding in the upper spray feed tube. Remove the screws to the feed tube and turn the whole assembly 1/4 turn to the right (CW direction). The entire assembly will unlock from the wash pump assembly and lift out.
4. Remove the strainer assembly (known as an accumulator) that covers the pump sump area.
Inspect the sump area for food particles and debris that may be contributing to the mess inside the wash tub. If you need some guidance, pcappliancerepair.com has some very helpful exploded view diagrams to assist you.
If you have any questions, or require further assistance, please let me know. I hope this is helpful to you.
Aug 17, 2009 | Dishwashers
Food particles left on dishes
Many times this caused by food particles clogging the screen or blocking the jets on the spray arms. Find the screen in the bottom of your machine and clean it out. If this doesnt help, remove the spray arms and clean them out.
Jun 17, 2009 | Dishwashers
How do i remove cover on food chopper? kenmore 665 the problem is top shelf dishes not getting clean. looking to clean out bottom area,thanks
Hold the lower spray arm hub (plastic bolt spray arm connects to) and turn the lower spray arm counter clockwise to remove it.
Using a torx bit, remove the 4 screws and the top cover. Remove the screws for the lower cover and the chopper cover. Insert a flat screwdriver it into the clip of the chopper cover to pull it up easier.
Unless there are alot of "foreign objects" in that area, be prepared to replace the chopper, the motor and/or sump assembly.
Feb 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a whirpool Quiet Partner III, and the top layer of glasses is not getting clean. I had a technichian out some time ago, and the problrem was caused by food debris trppaed in the filter in the wash...
CHECK THE SPRAY ARM HOLES,ARE THEY CLOGGED ??IF THERE NOT YOU MAY NEED THE PUMP REPLACED (NO PRESSURE).........BY THE WAY THE POWER DRIVE UNIT IS NOW REFERED TO AS A > MOTOR/PUMP WHICH IS NOT INCLUDING THE PUMP.IT'S THERE WAY OF ADDING CONFUSION WHEN WE ORDER PARTS. 1ST LOOK FOR CLOGGED SPRAY ARMS. LEAVE A RATING !!
Jun 08, 2008 | Whirlpool Dishwashers
No Spray
Wow, you've done a lot of work. I wouldn't break the seal around the bottom. If water gets in the motor then your in big trouble. You can try to clean the spray arms out. I was just in my kitchen trying to get the dishwasher to work with the door open to see the arms spray water, but I couldn't do it. Just a little experiment I wanted to try. I told my wife I was trying to help solve a problem and you can image what happened from there .... Let me see if I can find a manual.
Jul 14, 2007 | KitchenAid 24 in. KUDI02IR Built-in...
KitchenAid 24 in. KUDU02FR Built-in Dishwasher Logo
641 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
