Question about Belkin Computers & Internet
The mouse pointer disappears when i change to a hp
The mouse pointer disappears when i change focus to a hp laptop computer running vista. The other 2 PCs ported to the kvm are using XP pro and the kvm works fine with them
  • 116 Answers
SOURCE: belkin 2 port kvm toggling
What is the model name?
Press Scroll Lock two times within two seconds. Then press the Arrow keys, up or down to switch between ports. Or press Scroll Lock two times and the press the number One or Two key to switch between ports.
Posted on Nov 16, 2007
SOURCE: KVM 2 PORT SWITCH
Hot-Key Commands
You can change ports on the switchthrough the simple Hot-Key commands using the "SCROLL LOCK" key and the UP and DOWN arrow keys.
1. To invoke the Hot-Key mode, Press the "SCROLL LOCK" key twice within two seconds.
2. Press the UP or DOWN arrow keys to switch to the previous or next port respectively.
Alternatively you can directly switch the KVM focus to any computer by entering the switch port number. Ex. press "SCROLL LOCK" "SCROLL LOCK" 2 and the computer on port two will be selected.
Posted on Jun 26, 2008
  • 233 Answers
SOURCE: mouse and keyboard not recognized on second computer
Sounds like KVM has a bug. Maybe their website has a fix.
Posted on Dec 21, 2008
firesnake09
  • 2923 Answers
SOURCE: Problem with KVM switch and Vista
Your problem has nothing to do with the Operating System (Vista), it has something to do with the brand of your computer. I have similar problem before, I have Vista (Dell), but the time I connected another Vista (Sony Vaio), everything worked correctly.
This is what you need to do:
1. You have to make sure that you are using a standard USB keyboard and mouse.
2. Connect first the keyboard and mouse directly to the Vista computer to see if the USB ports of your computer are working properly.
3. You may power cycle the KVM switch by disconnecting it from the computers (including the keyboard and mouse) and leave it disconnected for 2 minutes.
4. Reconnect everything after two minutes and then reboot the computers.
5. Try using different USB keyboard if problem exist after power cycling the KVM switch.
Posted on Apr 06, 2009
  • 561 Answers
SOURCE: microsoft 6000 wireless keyboard / Mouse & KVM
Hi any KVM switch will work with these products
Belkin normally make very good KVM switches but they are pricey, cheaper ones can be picked up on Ebay, but not too sure of the quality
Posted on Feb 11, 2010
Mouse cursor disappear on hp w2371d
See this... http://h30434.www3.hp.com/t5/Desktop-Lockups-Freezes-Hangs/Disappearing-mouse-pointer/td-p/1568463
If it only disappears when you move it left or right off the edge of the screen, your video software may think you have a second monitor. Tell it different.
Aug 04, 2014 | HP W2371D 23 Full LED Monitor 16:9 5ms...
Mouse pointer disappers
I've seen this happen a couple of times when Word uses the initial preview "Read Mode" or Protected View . Try changing the mode by clicking on the View tab and changing the mode to Print Layout. When it happens to me, that seems to do the trick. If you don't want Word to use the Protected View, go into the Trust Settings for Protected View and uncheck the options in there...this may also keep it from happening in the future...good luck! :-)
Apr 24, 2014 | HP Pavilion 23xi 23" LED LCD Monitor -...
Cursor not showing up
Well the touchpad driver could be erased or a virus may have damaged it.
You should go to Acers website and then support and download drivers and get the right touchpad driver.
Install it and see if it works.
Use TAB to navigate for now. or use mouse keys.
This means keep pressing shift really fast and accessibility option will show up.
Use tab and space bar to navigate to MOUSE TAB and select Mouse Keys and hit enter.
Done for now you can use the numpad to operate the cursor.
Second option is to go out and buy a USB mouse.
Worst case scenario: Touchpad is damaged and needs replacing.
Or simply a cable got disconnected and needs reconnecting by taking the laptop apart
Get Your Laptop Mouse to Show Up if It Disappears
Using a laptop is as efficient as a desktop computer to complete tasks, use the Internet and talk with friends on a daily basis.
If your laptop's mouse cursor disappears, there are various tricks and solutions available to help get your mouse pointer back to resume your work and current computer tasks within minutes.
And this can be accomplished without the use of software applications or advanced computer skills.
Press "Ctrl" + "Alt" + "Delete" and choose "Task Manager" if your mouse pointer becomes available, pressing the keys simultaneously.
This will allow you to close any open programs that may be causing issues with your mouse pointer.
Plug in an external mouse to allow the computer to attempt to find the device, prompting the mouse pointer to appear which may solve the problem or allow you to temporarily work with a mouse pointer.
Reboot your computer by pressing and holding the laptop's power button for a few seconds.
This will reset your laptop's current open settings and most often allow your computer's mouse pointer to reappear.
Upgrade your laptop's video and graphic card drivers (if available) to ensure the mouse pointer disappearing or flickering is not a hardware issue.
Select "Start" > "Control Panel" > "Hardware and Sound" > "Device Manager" to view your current graphic and video settings.
Visit your device manufacturer's official website to download the most current version of your drivers.
http://support.microsoft.com/kb/198614
Aug 05, 2013 | Acer Computers & Internet
Samsung laptop cursor tweeking
Step 1
1. Open Mouse by clicking the Start button, clicking Control Panel, clicking Hardware, and then clicking Mouse.
2. Click the Pointer Options tab, and then do any of the following:
To change the speed at which the mouse pointer moves, move the Select a pointer speed slider towards Slow or Fast.
• To make the pointer work more accurately when you're moving the mouse slowly, select the Enhance pointer precision check box.
To speed the process of selecting a choice when a dialog box appears, select the automatically move pointer to the default button in a dialog box check box.
To make the pointer easier to find when you move it, select the Display pointer trails check box, and then move the slider towards Short or Long to decrease or increase the length of the pointer trail.
To ensure that the pointer doesn't block your view of the text you're typing, select the Hide pointer while typing check box.
To find a misplaced pointer by pressing the CTRL key, select the Show location of pointer when I press the CTRL key check box.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Step 2
If you are using touchpad, try reducing the Touchpad sensitivity and check
1. Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers."
2. Select the "
Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop.
3. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "
Apply."
4. Pick the "
Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings."
5. Read the information provided in the next dialog box. It gives you options for tapping your
touchpad, using the buttons, scrolling, pointer motion and sensitivity.
6. Make any changes you want from the various topics. When you make a change, click "
Apply." Click "OK" when you finish making all your changes.
7. Do some work on your computer for a while, If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Step 3
If the issue persists try to perform a clean boot and check whether the issue is still persists.
Follow the steps mentioned in the article given below.
How to configure Windows Vista to start in a "clean boot":
http://support.microsoft.com/kb/929135
Note:Once the troubleshooting is over, reset the computer to start as usual.
Also I would suggest you to keep in touch with mouse manufacturer
Oct 10, 2012 | Samsung SENS R460 LAPTOP LCD SCREEN 14.1"...
The cursor jumps around on my ASUS K501J notebook.
Step 1
Step 2
2. Select the "
Apply."
4. Pick the "
Step 3
Oct 08, 2012 | ASUS K50IJ Notebook
Unexpected system halts, disappearing mouse pointer icon, and reboot results in a stall at the HP INVENT screen
reinstall, ur OS, there may be a virus in ur os, check that your laptop is not heating up , use reginout to fix problems , i may help you
Sep 17, 2009 | HP Compaq nx6110 PC Laptop
Mouse Pointer Disappears
Run a dianostic on your memory or add more to the system
Mar 30, 2009 | Microsoft Wireless Optical Mouse
Computers & Internet Logo
57 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
