Question about LG LRSC-26922 Side by Side Refrigerator
Ice maker won't work
The ice maker got too full and water overflowed in to the freezer. I removed the ice bin and dumped all the ice and replaced it. Since then it has not made any ice
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 148 Answers
My mum use the same kind of freezer, when it had the problem on the ice maker, we both took it to a lg service center to renew the ice maker engine
Posted on May 31, 2010
2 Suggested Answers
SOURCE: ice maker
We just figured out our ice maker suppot try is broken and won't allow the ice maker to twist the ice out when it flips. We purchased a new support piece on line. I saw your problem which sounded similar to what was happening to ours. If you need it, the part # is DA61-02205A. Good luck.
Posted on Jul 22, 2008
Just recently, the ice maker stop dumping the ice cubes from the tray into the bin.
I believe the "tray" is supposed to get heated at end to let the ice release. Faulty "heater connection?" May need repairman diagnostic.
Jan 09, 2018 | Liebherr Refrigerators
My gsl25jfxblb GE side by side ice maker won't stop making ice. It overflows out of the bin and fills the shelf below with ice. Then when we open the freezer door to remove some food, ice spills...
no idea yet but many years back we had one that froze my wifes feet at 5:30 am when she opened the freezer to get ice for coffee and the freezer was full of water .
Mar 20, 2015 | GE Refrigerators
Cme256 scotsman
Is it dumping water or is it pouring water back into the ice bin? if it is pouring water back into ice bin than check your water float to make sure it is not calling for water also make sure the water valve is not letting water seep buy you can cut power to machine and if you here water still entering sump tray then replace water valve. if not then turn machine back on check and see it the water full light is on if so and water is still entering sump tray then replace float switch. If water full light is not on and the sump tray is full of water than remove the water sensor and clean or replace it.
Jul 10, 2013 | Kitchen Appliances - Others
Ice maker 106 626635 spills water in the bucket after dumping the ice. What can I do?
Are the ice cubes getting small then its actual size.Sometimes ice cubes not get made full of its actual size.Can be issue with maker itself.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Kenmore Refrigerators
Ice maker
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Maytag freezer wont produce ice
You have two sides to the water control valve. One side is for the water coming from fountain and the second side is to refill your ice maker after each cycle of dumping ice into the ice bin. The freezer should be a 5 degrees or below for the ice maker to function properly. If the ice maker is empty then fill with tap water up to top edge of the ice maker and allow to freeze. If after the water freezes and dumps the ice into the ice bin the ice maker does not refill I would recommend replacing part=> 67006009 Dual Water Control Valve
or here=> 67006009 Dual Water Control Valve
If the ice maker has old ice inside and does not want to dump itself it will be considered defective and the ice maker core moduel will need be replaced=> W10190972 Ice Maker Assembly
Whirlpool Ice Maker Troubleshooting
I will be here should you have any questions, Thank You, Sea Breeze
Please Rate this Solution
Feb 08, 2012 | Refrigerators
Ice maker is overflowing
Older icemakers have a bar that drops from above your ice bin; once the bin is full the bar is raised and trips turning the ice maker off so that it won't dump. If your's is this style, try manually pushing the free end of the bar upward so that it locks in the upward position. Newer ice makers with the ice bin in the door have a small panel that moves to the open position when the door opens and closes when the door closes. Mine also includes an optical sensor that is visible when this panel is in the closed position. Try placing a non-clear tape over the optical sensor (don't know if that will work or not but worth a shot). If effective in stopping the ice flow then call a repairman. If none of this works, turn off the water supply coming out of the wall to your freezer.
Sep 08, 2009 | Kenmore Freezers
Ice maker stopped working
The laser , is supposed to blink . This laser , tells the icemaker to stop making ice , when the bin is full . Pour about 2/3 cup of water into the icemaker . If it doesn't dump the cubes into the bin , the icemaker is bad . Or , if there is ice in the bin , which hasn't dumped , the icemaker is bad . If the icemaker dumps the ice ( from water pour ) , then look above the fill cup , and see if the black fill tube is frozen . If so , then replace the water valve and turn the freezer temp down slightly . It will take several days for this fill line inside freezer to thaw . If icemaker dumps , and black tube NOT frozen , replace the water valve . The valve , is where the wall water line connects to on the refrig .
Sep 05, 2009 | KitchenAid KSRP25FNSS Side by Side...
Kithcenaid Superba KSRS25QDWH01
If you pop the front cover off the ice maker you will find a screw with a plus and minus on it. Adjust it and that will cut the water fill down and should solve the overfill problem.If the ice is not dumping spray the tray with Pam and that should solve the dump problem.
May 22, 2007 | KitchenAid Superba Architect KSCS25INSS...
LG LRSC-26922 Side by Side Refrigerator Logo
1,364 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
