Question about Weiser Lock Powerbolt 1000 Lock
I need a schematic for my door handle so that I can try to figure out what's wrong with it reassemble it.
Help fixing a kitchenaid microwave oven/hood combo door handle
The door handles on most appliances, like outside cars & truck handles, are secured with screws from inside the door.
You will need to take the door completely apart to tighten the screws. This may be a very hard job, as it needs to be reassembled as well. God bless your efforts.
Oct 24, 2016 | KitchenAid Microwave Ovens
I did a really dumb thing... Kohler bypass shower doors, frameless. For some odd reason, the bottom piece fell off the inside door! I scraped off the left over silicon glue, got some more, and very...
I know it's is going to be a tedious process to remove,clean, and replace bottom piece but I think that is what you need to do. Sorry I don't have a easy fix for you. Good luck and thank you.
Jan 25, 2011 | Kohler Home
I am replacing a door knob when I put the new one in it would not turn on either side I have reassembled the old one and it will not turn either what am I doing wrong? Nothing is wrong with the knobs I...
Be suer the the slot pins are in line. or you are tightening it to tight this will cause the knob to not turn. The othe thing is the knob you have is not lining up with the latch slots.
Jan 12, 2011 | Top Knobs M826 Door Pull
I need a schematic for an over the range microwave door in order to replace the handle. A samsung model SMH7187STG
Do you have the new handle already? I need a whole new door due to a scratch and will have a new handle from the scratched door that I wont need........
Oct 25, 2009 | Samsung Microwave Ovens
How do I fix the door handle it popped off
look to see if any damage to handle no damage replace[damaged get a new one salvage/dealer]take off inside door panel and reattach outside handle clip latch rod inplace and test than reassemble door
Oct 18, 2009 | 2002 Chevrolet Impala
DOOR HANDLE LOOSE MODEL#gs5shaxnq00 Whirlpool sxs Ref side
Ther is nothong wrong with the ice Dispensing unit the screws in the door handle are loose and we can not figure how to tighten them.
the model# is GS5SHAXNQ00
Aug 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Chevy G20 Van Door Handle stopped functioning; need schematic
This was a lot easier than I thought. The underside of the door handle itself had cracked, where it grabs the teeth of the opening mechanism. We popped off the old handle, and popped on a replacement. Whammo. Thanks!
Nov 11, 2008 | 1995 Chevrolet G20
Weiser Lock Powerbolt 1000 Lock Logo
179 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
