Router's wireless function not working
Lynksis router model wrt160n. Internet access for hard wired PC is fine, but I cant get the router's wireless function to work. I get the following error ''MG_100_000_000: Unhandleed error. Please see Lela Log for more information.'' I also tried 192.168.1.1, but the page would not load.
Wireless did work after my original set up. I am running Vista.
  • 153 Answers
Please visit my profile bro. coz i posted there some tips about routers configuration and internet connection errors. here's the URL: http://fixya.com/users/chael890
Posted on May 31, 2010
I have a Linksys WRT160N router that I am using with a MacBook Pro laptop running Snow Leopard. I used my computer (with some difficulty) to set up the wireless access by way of a wired connection. The...
My Friend ,
Login the router setup page .
And under router security settings uncheck the option (block anonymous internet request).
Set the wireless channel as 6 or 9.
And then use wep security key.
this will surely work.
Regards :-
Amit
Jan 07, 2011 | Linksys WRT160N Wireless Router
My router shows connected but no internet access.
Please try connecting the DSL / Cable modem directly to your computer and check if the network works fine, it works fine then power down the wire router and then restart it again and check.
Jan 02, 2011 | Linksys WRT160N Wireless Router
Okay what happens is when i try to Connect to my Linksys wireless-n Router model: WRT160N it connects fine but the internet is so slow but when i connect to it wired it works fine how can i fix the...
open http://192.168.1.1 and go tom wireless page and change the radio band and channel both to auto ...
or simly u can use the following as well
Radio band is : 20mhz
Standard channel : 6
May 20, 2010 | Linksys WRT160N Wireless Router
WRT160N Wireless Router : i just bought a new laptop and a lynsis wrt160n......
The wired and wireless speed will always be different.
The maximum wired speed will be 100 Mbps. That means the wired connection is working properly.
Wireless connection speed will depend on the router and the wireless adapter on your computer.
If you are using B-Adapter then max speed will be 11 MBPS. IF it is G-Adapter then max speed will be 54 Mbps.
The N-adapter will give you more speed.
Check in the Device manager which adapter you are using on your wireless computer.
One more thing you can try changing the wireless channel on the router.
You will need to access the router settings page.
Update the drivers of your wireless adapter on the computer.
You have WRT160N router.
This router has issues with the Firmware.
Is there any computer connected to the router with the cable.
If not then you will need to connect the computer to the router.
Download the firmware of the router from the manufacturer's website.
enter the model number. select proper version number and download the firmware of the router.
Once you download the firmware, you will need to open the router set up and upgrade the firmware of the router.
After upgrading the firmware, it is recommended that you reset and reconfigure the router.
Click Here for more information about router and networking
May 07, 2010 | Linksys WRT160N Wireless Router
Intermitent wireless connection
1. check the firmware updates for you router.
There should be a update manager in the router.
2. bring up a web page type in 192.168.0.1 then enter the user name as "admin"
no password.
3. check status page to see if you are getting an IP address.
this is not a Windows 7 issue.
4. Hard wire the router to the PC to do the firmware updates. That is connect a RJ45 cable or ethernet cable ( straight through) not a crossover.
Apr 20, 2010 | Linksys WRT160N Wireless Router
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Apr 13, 2009 | Linksys WRT160N Wireless Router
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
