Question about Polaris 3900 Sport Automatic Pool Cleaner With Booster Pump
Water pressure is high coming out of directonal jet and pool tail
I have tried to oprtate with nd without the blue orifice or bckpressure plate and there is no change should i tak ethe unit apart and clean the internals that control the whell operation
    Top Expert:
  • Polaris Master
  • 8,163 Answers
Put a valve on it to reduce pressure or they sell reduces that go into wall fitting blue or red
Posted on May 22, 2016
3 Suggested Answers
  • 46 Answers
SOURCE: Jet Vac stops moving around the pool
every pool has a dead spot where the vacume gets stuck! expesially when the vacs get a little age on them! juist keep an eye on it and work with it! or replace the vac!
Posted on May 26, 2009
  • 128 Answers
SOURCE: My P380 moves around the pool but does not pick up debri...
Make sure the wall screen is clean. It sounds like you are missing the wall fitting screen. If this is the case you have debrie in the unit and it has plugged the water management system. Take the cover off the head and clear all the jets where the hoses connect.
Posted on Sep 05, 2009
Polaris 280 moves around pool ,screens not clogged water still spraying up toward bag but not picking anything up
Hi, even though the two jets appear to be spraying upwards, the force may be diminished by partially blocked nozzles. To check remove the debris bag and observe jet action as cleaner is held near water surface. the action must be strong enough to shoot well into the air. If not, then often a piece of wire can be inserted into jets to dislodge the debris. you may have to do this one or more times.
the other cause of insufficient jet pressure is that the feed hose to jets has ruptured or the zip strip retainer has broken. unit must then be partially disassembled.
Oct 06, 2014 | Polaris VacSweep 280 Pool Cleaner with...
Does not move around in the pool
What doesn't move around the pool?
For assistance with your problem, you can't be so general & evasive!
We may be Professional Service Providers, but we also can't afford to keep batteries in our crystal balls.
Wait... I think I may have a couple batteries with a little life in 'em..
I think I see a poolsweep sorta just acting sluggishly or barely moving around in the pool.
I really can't tell if it is a "Pressure" cleaner or "Suction" Cleaner. Man, this crystal ball is acting strangely - I can't tell if it is a pressure cleaner, is it the kind with a booster pump or the style that runs off the return water flow through one of the inlet fittings?
Anyway, try cleaning your filter - backwash the DE or Sand, or remove the cartridge & hi pressure garden hose nozzle it. See what I mean about these darned batteries, the crystal ball isn't working very well now.
You might have a clogged impeller on your pump, or your booster pump. Empty your skimmer basket if dirty. Remove the wall adaptor if you have a pressure style cleaner, as the filter screen in it, could be plugged/clogged & needs to be cleaned.
If it is a suction style cleaner, check the throat of the unit, you may have a pine cone or other foreign object blocking the entry way for water to move efficiently and operate the unit throughout out the pool.
If you have a pressure style cleaner that has a whip/tail hose, check it for holes or if the jet orifice at the end of it is still there. If that hose has been compromised, your unit will actually be as if dead in the water.
Good luck, Maybe next time I will have fresh batteries in my Crystal Ball to assist you when you feel I need to guess at your problem.
May 18, 2014 | Pool & Spa
Inner spa jet orifice has broken off
this company blows fiberglass liner into the existing pipe.
Flow-Liner® Systems LTD.
Specializing in Trenchless
Non-Invasive Products & Systems
"We Keep the World Flowing™"In the US 1-800-348-0020
International: 1-740-453-9387
Sep 22, 2017 | Pool & Spa
Polaris tail not sweeping. I believe the impeller on the booster is clogged restricting water flow
If unit is operating satisfactorily otherwise, the check end of sweep tail for missing orifice tip. Without it tail won/t sweep. Also check adjusting screw. Out - more tail flow In - less.
Dec 01, 2012 | Polaris Pb4 - 60 Booster Pump
Pool cleaner will vaccuum but no movement in pool. plenty of water pressure going thru back hose
Before doing anything, take the Jet Vac out of the pool and set it on the deck. Stand clear and turn it on. It should have enough water going through the blue jet to spray several feet and propel the jet vac on dry land.
What propels the Jet Vac is not the water going through the hose, but the water going through the little blue Jet under the Hose. You can unscrew this from the bottom of the shell and clean out any obstructions. Also, check the screen at the connection where the hose meets the wall. It is located in the white valve with the red button on it right at the pool wall. It will unscrew from the wall of the pool with the system off. Also make sure the booster pump is coming on.
Also, it may be stuck in reverse or neutral. If this is the case there will be jets of water shooting forward of the jet vac when it is on dry land.
Apr 15, 2011 | Pentair Jet Vac Venturi Shell Blue Jv2c
Zodiac Baracuda Zippy Pool Cleaner only clean one pool side because strong jet don't let move to other side
If you don't have directonal eyeballs on your jet's you can get a dirveter for the jet that will push the water down the wall rather than out into the pool. Get these at your local pool store. Baracuda and Kreepy Krawlie both make them.
Jul 05, 2010 | Zodiac Baracuda Zippy Pool Cleaner
2 hp Swimming Pool - Jet / Well Pump Motor / Century B124: Water pump from swimming pool to filter lost it's ...
NOT THE MOTOR ,THE SEAL... JET PUMPS ARE NOT FOR POOLS.. LOW FLOW HIGH PRESSURE.. YOU NEED HIGH FLOW LOW PRESSURE ... IF NOT YOU MAY HAVE A SUCTION LEAK OR A BAD SHAFT SEAL... VOTE JAY
May 17, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Restricted flow
Try cleaning the filter cartridges thoroughly. Also test operation without filter(s) in place, temporarily. Check that any adjustable jets are open and not creating too much back pressure on system.
Apr 16, 2009 | Pool & Spa
Polaris 3900 Sport Automatic Pool Cleaner  With Booster Pump Logo
32 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
