Question about Sony PlayStation 2 (PS2) Console
PS2 Memory Card Read Error
The system doesn't recognize memory card in slot. If I hold it in REAL firmly we may be able to save a game on occasion Playstation 2 does not recognise any memory cards in either slot, I have tried several to no avail - it just says no memory card inserted.
    President:
  • 1,950 Answers
Have you tried cleaning the open connections?
Posted on Apr 08, 2008
  • Damen Wong
    Damen Wong Apr 08, 2008
    There could simply just be dust intefering with the connection.
  • 4,889 Answers
Assuming you've got the right cards for your system, there are two tests you need to perform:
1. Borrow a memory card from a friend and try saving files to it and then reading them. If this does not work, your PS2 is probably broken and you'll need to get it fixed.
2. If other memory cards work in your system, go over to a friend's house and test your memory card in their system. If this does not work, you know that your memory card is busted and needs to be replaced.
    Genius:
  • 1,142 Answers
Clean the memory slot with isopropyle alcohol
  • Anonymous Apr 08, 2008
    Use a ear cleaning swab and dip it into isopropyle alcohol which is easily available in the market and try to clean the metallic contacts and it should work but make sure you turn off the device while you do so.
SOURCE:
I bought a new ps2 and a datel 32mb card and the game i put in says there is no memory card,
Try these steps. If this doesn't work you may want to take the card to Game Stop or something and have them test it to see if it's working. Hope this helps!
  1. Insert the Memory Card into the PlayStation 2 console. The port is located directly above the controller port. Note that there are two different memory card ports; there is no difference between the two. Some games, however, will attempt to auto-load from slot one so it is recommended that you keep your memory card inserted in slot one.
  2. Plug your controller into the PlayStation 2. Power up the system without a PS2 disc inserted. You will be taken to the system menu screen. Select the "Memory Card" menu to examine any data on the card. If the memory card is new there should be no data on the card, if it is used you may see old saves from the previous owner on the card. If you no longer desire to keep these saves, you may highlight them and press the "Triangle" button to delete them.
  3. Insert your PlayStation 2 game disc into the system. When the disc appears on the system menu, select it. Load the game, and play until you are prompted to either create a user profile, or to save your game. Once you have saved any data to the memory card, reset the system.
  4. Select the "Memory Card" menu and examine your memory card. You should see a new icon representing your game's save data. If this data appears on the card, you have correctly set-up your PS2 Memory Card.
    If the data does not appear on the card, you will need to format the card. If the system detects corrupt data on the card it will automatically open a prompt asking if you would like to format the memory card. Select "Yes" and the PlayStation 2 will format the card.
Dec 31, 2010 | Datel Max Memory 32MB Memory Card
Slot one not reading cards properly.
There isn't way to fix this easily. I recommend taking it to Geek Squad and having them look at it. Although it may be cheaper just to purchase a new Ps2.
Jul 17, 2010 | Sony PlayStation 2 (PS2) Console
I have 2 Sony PS2 memory cards but neither will save data at breaks in games. Am I doing something wrong ? I am new to gaming and have followed instructions without success. Help!!!
It could be that they were damaged in someway or the memory slot in the PS2 is broken. I've been able to fix mine by blowing into both openings, the slot and the card, but if that doesn't work, check the game it self to see. Usually the game will say something like "Saving Data-Please Do Not Turn Off System Or Remove Memory Card". If it isn't saying that, it probably hasn't saved at all.
Jan 17, 2010 | Sony PlayStation 2 8MB Memory Card - Black
I must assume that the card you are talking about is not a Sony brand memory card. Sony Playstations are very picky with memory cards and can cause strange malfunctions even permanent damage if they are not Sony brand or Sony approved memory cards. Sorry that doesn't fix it, but my brother lost his by using a non Sony memory card. It fried the machine.
May 30, 2009 | Sony PlayStation 2 (PS2) Console
Final Fantasy IX will not save
Final Fantasy IX is a Playstation One Format Game, to save the game on a playstation 2 you will need a playstation one type memory card.
Aug 13, 2008 | Sony PlayStation 2 (PS2) Console
My sony playstation won't save.
i fixed it there was a lose connection on the inside of my playstation so if you open yours youll probable find slot 1 isnt connected or is only partly connected
Aug 11, 2008 | Sony PlayStation 2 (PS2) Console
Guitar Hero III on PS2 Saving Failed
Could be. Maybe the game doesn't recognize the 16 MB. You can try an original 8 MB Sony one. They're not that expensive anymore. But first try the other Memory Card slot.
Let me know if it worked. Please rate.
Greetings,
DarkNeogen.
Jan 05, 2008 | Sony PlayStation® 2 Console
My memory card slot 1 doesn't work can I change the unit so that games will save to slot 2 instead or how do I swap the slots in the unit
When you choose to save when you are in any game, on the save screen you can choose to save to slot 2 provided there is a memory card inserted in slot 2.
Dec 27, 2007 | Sony PlayStation 2 (PS2) Console
my system keeps saying the memory card has been removed and i even try holding it in or switching slots but it doesnt work???? I HATE MY PS2
Dec 05, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
224 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
