Question about Canon PIXMA iP1800 InkJet Photo Printer
Canon ip 1980 offline problem
My canon printer say offline even its power on and connected to my computer
Saya Punya Printer Canon IP 1980, printer sudah terkonek ke PC driver sudah ok tapi ketika saya print tidak ada respon sama sekali saya cek kabelnya bagus tidak ada masalah . kepada para sahabat saya minta bantuannya dan solusinya ? ...
Posted on Feb 06, 2013
I want program driver priter PIXMA ip 1980
Posted on Jun 01, 2010
Why is my printer offline?
First you need to wake up your printer; second, if your computer is not directly connected to this printer, you need to change the IP address (by detecting this printer; use "Add printer"). Somehow, if the printer power is turned off, it changed its IP address.
Feb 04, 2014 | HP Color Laserjet Cp3505n Color Laser...
As long as i have my usb cable hooked up to my printer and laptop it works but when i disconnect the cord its offline.what should i do?
It may not be configured to the correct port.The port selected could have been the USB port that's why when you disconnect the USB cable printer goes offline and would not print wireless. Follow the steps below if you are using a WINDOWS computer: For windows XP :
  • Click on start then go to printers and faxes.
  • right-click on the default printer canon pixma mx340 series
  • go down to properties
  • click the ports tab
  • check to see which box is checked.If the usb port box is checked,that answers the reason why printer goes offline and would not print wireless when USB cable is disconnected.
  • In the list of ports ,look for tcp/ip with the correct ip (192 number) address of the computer.
  • when you find it,tick the box,click on apply then ok.
  • if you do not see it anywhere on the list ,you need install the software.
For win vista
  • click on start,in the search box key in printer then hit enter on the keyboard
For win 7
  • click on start,in the search box put in devices and printers and hit enter
  • click on printer properties
Let me know if you need assistance in configuring wireless connection and installation.
Jul 17, 2011 | Canon PIXMA MX340 Wireless Office...
My printer is canon pixma ip 1980, its orange light is blinking 7 times, it says the cartridge is not installed properly (but i did not even touch the cartridge), how can fix the problem? pls help, i need...
Remove the cartridges, clean the contact points and heads using a soft brush (you can clean them using the brush dipped in alcohol or acetone or spirit). Reinstall them and switch on the printer. If the problem persists, try with another cartridge/s, it's also possible that one of the cartridge/s is/are bad and no longer usable. In that case, you'll need to replace it/them.
Good luck.
Thanks for using FixYa.
Aug 15, 2010 | Canon PIXMA iP1800 InkJet Printer
Vista says CANON MF4370dn printer always offline? IP addrs issue?
first of all, download updated driver from software.canon-europe.com and install ( before install, remove old drivers and programs)
and if appears again, change your network cable.
Mar 29, 2017 | Canon ImageCLASS MF4370dn Laser All-in-One...
How to reset pixma ip1980
This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord.
2. Press & hold the power button.
3. Connect the power cord WHILE holding the power button.
4. Keep on holding the power button for about 30 seconds.
5. Release the power button. The printer should be turned off.
6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Hope this helps.
vulmec.wordpress.com
Jul 11, 2009 | Canon PIXMA iP1800 InkJet Printer
I have my canon pixma 1980 series... error says ink absorber is full and need to reset... please give me a resetter software.... thanks
Manual reset for canon pixma iP 1980 it easy and like resetting canon ip 1880.If found problem in your printer canon iP 1980 maybe this methode can be use. This reset manual be used to reset waste ink counter in canon pixma iP 1980.
Here how :
  • Turn on your printer Canon Pixma iP1980
  • now Press and hold Resume button for two (2) minutes and then release Resume button.
  • Turn off the printer and turn on again, the Printer will back to normal again.
May 02, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Download driver PIXMA iP 1980?
how to install the canon pixma ip1980 printer without cd
Apr 22, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Install
ok first u go to the google and write the canon ip 1980 printer driver and after install the driver and run this folder.. after install the driver printer working ok
Apr 01, 2009 | Office Equipment & Supplies
The ink absorber is full for pixma 1880
Hope this helps.
Jan 15, 2008 | Office Equipment & Supplies
Canon PIXMA  iP1800 InkJet Photo Printer Logo
826 people viewed this question
old marine
old marine
