Question about Olympia Supertype 330 Typewriter
Key and wheel problem
I got problem with the key and wheel.
When i press 'a' button, i got a 'z' print on the paper.
I dont know what to do.Its goes with all the button.
Please help me.
  • Olympia Master
  • 3,594 Answers
CheckThe pitch slide switch, it should be in 10, 12, or 15 if it is in PS this will do this. If it isn't in PS push down on it & slide it up and down a few times they do fet dirty.
DickyO
Posted on Jun 01, 2010
When I send something to print the right hand side of the paper comes out all crumpled up, as if there is something stuck that it can not pass. I have looked in the printer but can't see anything. When...
Issue
While printing, the printer paper is torn, ripped, wrinkled, or damaged.Solution Follow these steps in the order presented to resolve the issue.Step one: Remove all paper from the input and output trays Remove all paper from the input and output trays on the product.Step Two: Check the paper path for obstructions Press the Power ( ) button to turn off the product. Verify the input tray is empty, and then check for paper jams, bits of paper, and other obstructions, gently removing any obstructions.Lift the top door or the front cover, depending on the product, to access the print carriage, and then check for any obstructions in the paper path.Gently remove any paper or other obstructions from the paper path you might find, and then close the print carriage access door.Open the rear access door.Gently remove any paper or other obstructions from the paper path.Check the spring-loaded rear access door rollers to verify that they are clean and can be rolled.check the paper rollers inside the rear access and verify that the rollers are clean and roll upwards.Check the star wheel assembly inside the printer on the output side of the carriage. Verify that it is in good condition and clear of paper bits or other obstructions. NOTE:The star wheel assembly is located inside the printer on the output side of the carriage. The star wheel assembly is a set of small, star-shaped wheels on top and rubber rollers on the bottom. The assembly grips the printed side of the paper, and moves the paper to the output tray after printing.Replace the rear access door and verify that the rollers on the door and the rollers inside the rear access of the product are "matched up" with each other.Press the power button to turn on the product.Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include: Plain paper, 20 to 24 lb (75 to 90 gsm) Legal size paper, 20 to 24 lb (75 to 90 gsm) Card stock, up to a maximum of 110 lb (200 gsm) Envelopes, 20 to 24 lb (75 to 90 gsm) Photo paper, 145 lb (236 gsm) NOTE:Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.Step Four: Make sure that the paper is loaded correctly Gather a stack of plain, white paper and load it in the product's input tray.Use only one type of paper in the stack.Use 10 to 25 sheets of paper in the stack.Fan the stack of paper to make sure that the sheets do not stick together. Tap the stack of paper against a hard, flat surface, such as a table top, to make the edges even.Insert the stack of paper into the input tray.make sure that the stack of paper is flat in the input tray. Verify the right side of the stack of paper touches the right side of the input tray and that the stack is pushed completely into the tray.Position the paper guides firmly against the sides of the paper stack without bending the paper.Step Five: Test the All-in-One Follow these steps to print a self-test page. If the page prints successfully, the product is functioning correctly.Press the Setup button on the printer.Depending on what product you have, perform one of the following:Press the arrow key to select Print Report and then press OK.Press the arrow key to select Self Test eport and press OK.A test page prints.If the test page prints without damaging the paper, you do not need to take any other action.If the test page is damaged during printing, proceed to the next step.NOTE:For printers which do not have a Setup button, check the product documentation to find out how to print a self test page.Step Six: Contact HP If you have completed all the steps listed above and are still experiencing a problem, the rear access door or the star wheel assembly is likely damaged. To replace the rear access door, contact HP. If the star wheel assembly is damaged, replace the product.Cause There are several possible causes: Bits of paper might be obstructing the paper path and need to be cleared.Unsupported paper types and sizes might catch and tear in the printer mechanism while printing.Paper pushed too far into the input tray when it is loaded, might feed into the printer incorrectly, causing the paper to tear.Paper stacks loaded into the input tray with too many or too few sheets of paper, might feed into the printer incorrectly, causing the paper to tear.Paper stacks that are not properly stacked when loaded into the input tray, might feed into the printer incorrectly, causing the paper to tear.The rollers on the rear access door and inside the product's rear access might not be clean, in good condition or freely rolling.the star wheel assembly might be obstructed or have damaged or missing parts, causing the paper to tear.The rear access door might be damaged.The wheels on the star wheel assembly might be damaged.
Oct 12, 2011 | HP Officejet J5780 All-In-One InkJet...
Have a canon b95 faxphone machine. When receiving legal size documents, it receives and prints on 2 separate sheets. How do I correct so incoming only prints on 1 legal size paper
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
May 18, 2010 | Canon FaxPhone B95 Plain Paper Inkjet
I have a Xerox 7345. Instead of printing red it
In one of these diagnostic areas you will find an auto gradation adjustment, perform that. Here are the steps.
To enter the CE mode:
  1. Press and hold the 0 key for 5 seconds, then while still holding down the 0 key, press the Start button.
    The CE Access Number screen will appear.
  2. Enter 6789 and press Confirm.
  3. The top most area of the UI display will be reversed to let the user know that the mode has changed to the CE mode
  1. Enter the Diagnostic mode.
  2. From the Common Settings screen, select Image Quality Adjustment.
  3. Select Calibration.
  4. Select the button of the Screen Type to be calibrated, that is, Copy Job - Text, Copy Job - Photo, Print Job - Text, or Print Job - Photo.
  5. Press the Target button and then select the type of jobs to be calibrated, that is, Copy & Print Jobs, Copy Jobs Only, or Print Jobs Only.
  6. WC 72XX only: Load A4 paper in the Tray 5 (Bypass). Press Save.
    WC73XX only: Select a paper size and type using the paper supply button
  7. Press Start. The auto gradation routine will run and a message will display upon completion.
  8. Take the print from the output tray. Follow the instructions on the screen to complete the color correction.
Jan 15, 2010 | Xerox WorkCentre M-24 Color Copier
Reloading paper in Canon P100-DHII
If you found the where the paper goes, it shouldn't be difficult.
Turn the power on and feed the paper by pressing the Printer/Advance paper button (I don't know exactly what it looks like in your machine -- it may have "Print", "P" or a upward arrow typed on it) .
Aug 05, 2009 | Office Equipment & Supplies
Inserting paper- I'm not sure exactly where the leading edge of the roll goes - it doesn't seem to feed when I press the feed button, although the wheels and gears do turn.
Try to load the paper again --- there is a slot just infront of the printer
Make sure u turn the switch to "PRINT" position
Jul 10, 2009 | Canon P1-DHV Calculator
OKI 24DX - Press ONLINE button to print each page
you have to open your printer icon in CONTROL PANEL
CONTROL PANEL
THEN
PRINTERS AND FAXES
RIGHT CLICK ON YOUR OKI PRINTER
select PREFERENCES
under SET UP and MEDIA size change it to A4
I think this might help you. I'm guessing that you have the wrong size paper selected. And each time the computer needs you to confirm you want to print with a different size paper
I wouldn't phone OKI help line..I was on hold for 15 minutes, then just gave up.
Jul 01, 2009 | OKIPAGE 24 Led Printer
Drum parts i think?
No it is P ad paper,when you make a copy then you select paper button and press print key
Tareq Bin Mostaq
Bangladesh
cell:01819879575
Mar 14, 2009 | Sharp AL-1642CS Copier
Paper goes crooked the jams
both wheels are not grabbing , they need to be cleaned
Oct 15, 2008 | Lexmark X1150 All-In-One InkJet Printer
Ckeck printer ##343
its a printer reset error press
*AF-Key = Additional Functions key = the black button with the star in a head above it.
1) Enter SERVICE MODE. (Press AF-Key, followed by "scan", "copy", "scan" -Keys)
2) Select TEST MODE (press right arrow button 13 times).
3) Hit -OK-
4) Select [8] PRINTER TEST
5) Hit -OK-
6) It'll now say "- 8-2 +" press the right arrow key once to get "- 8-3 +"
7) Hit -OK-
8) Select 0. [INK COUNT].
9) Hit -OK-
10) It should return to showing the "8: Printer Test - 8-3 +"
11) Press the [Stop/Reset]key - (black key with triangle and circle on it) - (returning to the state of 4), and then press the [ON/OFF] key.
Cleaning the print head:
At any time, DO NOT wipe the actual print head with your fingers. Use ONLY water.
-Remove print head assembly from printer.
-Remove ink tanks.
-Use running warm water, wash away the exess ink that is dried around the print head.
-Take one disposable mug, fill with hot water, drop the print head assembly in there, and let it soak for an hour, or so.
(-IF you have massaging shower head, with spray jet -function, use this to deep clean the actual print head.)
-Dry it up carefully, do not wipe actual print head, just tap gently with soft paper.
-Install ink tanks, install assembly to printer, let it settle for some time (5-30 minutes)
-Run Nozzle check, cleaning, print head alignment
hope this helps if you have further problem do let me know
pls appreciate by rating this solution
Aug 13, 2008 | Canon SmartBase MP360 All-In-One InkJet...
Loading paper
Hi, I had the same problem...but I fixed it. Here's how: At the very back of the calculater under the paper roller there is a very thin horizontal slot. Insert the tip of the paper roll into the slot, then press the paper advance button located on the top left hand sidw of the calculator until you see the paper. Guide the paper through the top slot and voila.
Mar 28, 2007 | Canon P23-DH Calculator
Olympia Supertype 330 Typewriter Logo
32 people viewed this question
Top Olympia Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Michael Galve
Michael Galve
Are you an Olympia Office Equipment and Supply Expert? Answer questions, earn points and help others
