PC monitor not lighting up for around 10 mins
Where Dell Flat screen 15inch monitor has not been used for a period of time or on boot up the screen displays for a seond then goes black (although in a certain light you can see the icons and programs in use). If you switch the monitor off and back on again the display appears for a second and goes black again. If you complete this around 30 to 40 times then the display appears fully lit up.
Throughout this time, where the monitor is switched on, the power button appears green
  • 594 Answers
Check the capacitors on the power supply board inside the monitor. They malfunction, heat up, leak or pop and stop doing what they are designed to do, smooth out the power supply to the inverter and display board. You can replace these simply by buying the correct farrad, voltage and temperature rated replacements online for about .30 a piece or go to radio shack and spend 1.50 a piece. You can use a higher voltage like 35V instead of 25V but try and get the 105c rated ones to last longer in the hot P/S environment. My bad ones were 470 micro farrad, 25V and 105c rated and I had 4 out of 8 pop or bulge.
Posted on Apr 08, 2008
SOURCE:
When I turn off my Dell monitor E152FPc for hours, the monitor blinks and will not come on until I have turned the monitor off and on a lot of times
The power supply board is on the verge of failing, the cause is often a bad capacitor that opens, in some cases there may be more than one involved, leaving a bulge at the top leaking it's contents making it easier to nail down.
Jun 03, 2012 | Dell E152FPC 15INCH FLAT PANEL LCD MONITOR...
I have a Dell 15"
You need a new driver for the monitor. Are you now using a new Operating System? Perhaps Windows 7? Go to the http://dell.com websit and look up your monitor under downloads and drivers. Fidn the compatible driver for your operating system and download it.
Dec 31, 2010 | Dell E151FP 15" Flat Panel LCD Monitor
Screen goes blank
Its simple bro , Your CPU is not reading RAM,so just Remove and Re Insert the Ram to in DIMM Slot and then Switch on Computer it will work fine.
Jul 21, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
It turns off after 10 minutes working
When you say it turns off, is the power light going out too?
If the power light is still lit when the screen blanks, it may be a faulty backlight inverter.
After 10 minutes elapse and the screen goes out, if you power it back on, do you get another 10 min, or does it last a much shorter time period, or not at all?
Your best bet is probably simply to buy a new monitor, and sell yours as "broken" on eBay, I'm sure someone out there capable of fixing it would be willing to pay pennies on the dollar to subsidize your replacement screen.
Jul 03, 2009 | Gateway FPD1965 19" Flat Panel LCD Monitor
I have a Dell 600m that boots up and then screen
try turning the computer off for 20 min.or 40 min. then turn it back on
Jun 16, 2009 | Dell InspironTM 600m Notebook
I just bought a dell flat planel monitor its coonnected fine but unable to see any vedio on the screen
I'm assuming the monitor switches on, ie the the orange light comes on when plugged in or turns green once the pc is booting up? If not check the plug fuse or cable connecting monitor to pc. If all is ok can you see the bios screen as the pc boots up, you should at least be able to see that as this doesn't require any drivers. If not, try the monitor on another computer, if it works on another pc then its something to do with your graphics card. Hope this helps.
Jan 21, 2009 | Dell E173FP 17" LCD Monitor
My dell ultrasharp 1800fp monitor keeps flashing on and off, its not a power problem as the power button stays on and when i disconnect the the monitor cable from my pc the no signal message stays on the...
Inside there is a IC chip on the power pack that goes bad, replacement is called for also look for bad capacitors when you are inside looking around, those need to be replaced as well
hope this clears things up. dells third party who built these units did a rotten job on this model. that chip always fails.
Aug 19, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell - 17" flat screen
This sounds like the back light is gone on the monitir... to check this look very close at the monitor whet the PC has booted, if you see a VERY dim image on screen then it suggests that the back light is gone.
Many monitors hace a 3 year warranty so I would try a warranty claim before throwing it away
Jul 12, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Where Dell Flat screen 15" monitor has not been used for a period of time or on boot up the screen displays for a seond then goes black (although in a certain light you can see the icons and programs...
You most likely have a bad connection inside the unit. Specifically, there are a couple of "backlights" that provide the light that will pass thru the LCD panel. If you can open up the unit, with the screen facing up, there should be a small PC board on the right. Check the connections on that board. Be careful as there is high voltage there.
Keep us posted.
Dan
Apr 08, 2008 | Computers & Internet
Pc screen goes black green light stays on
Well since you seem to have tried a bunch of thing why nor go a bit more and replace your video card. Below is a link to your PC:
http://support.packardbell.com/uk/item/index.php?pn=P280110001&g=1400
Dec 21, 2007 | Computers & Internet
Open Questions:
Amazon Prime ContaCt pHoNe #{+1-85O-8I2-4OO9 usa how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.
Oct 16, 2019 | Amazon Computers & Internet
-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A-\&;-AVG Customer Care Phone Number #{+#[+1^888/.499//5520;-]} AB .U.S.A
Oct 16, 2019 | Computers & Internet
Computers & Internet Logo
463 people viewed this question
Ekse
Alun Cox
