Question about Microsoft Windows XP Professional for PC
Phase missing in 3 phase power. the circuit will show error on 1 and 2 phase comin...n when 3 ph are coming it will show ok signal
    Brigadier General:
  • 10,406 Answers
Category: Microsoft Windows XP Professional for PC
I recommend that you hire a qualified electrician, to deal with your "non-computer" problem.
Posted on May 31, 2010
Canon ir 2220 ERROR CODE E261
U NEED TO INVESTIGATE
the input/output ports of the DC controller PCBs.
COPIER>I/O>DC-CON<DC-CON (5/7)>
P020 xxxxxxxxxxxxxxxx=runs from left to right 15>0
ADDRESS=P020
BIT-
0- zero-cross signal -
1- heater trigger 1 signal 0: ON
2- heater trigger 2 signal 0: ON
3- heater error OFF signal 0: error
4- not used
5- not used
6- M9 registration motor phase A pulse signal -
7- M9 registration motor phase B pulse signal -
E261 0000
The intervals of zero-cross signals deviate from the tolerance range while
the fixing heater is supplied with power.
Main cause The wiring is faulty (short circuit, open circuit). The main power supply
PCB is faulty. The DC controller PCB is faulty.
Making Corrections
1. Connectors
Are the connectors J205 on the main power supply PCB and the connector
J308B on the DC controller PCB securely connected?
(zero-cross signal: J205-7 <-> J308B-1)
NO: Connect the connectors securely.
2. Main power supply PCB, Main controller PCB
Try replacing the main power supply PCB. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Jan 22, 2013 | Office Equipment & Supplies
KP-61HS30 has sound but no video
1) the problem you have is lack of raster , the problem in tv has 4 phase 1) raster 2) picture 3) synch 4) sound.
2) test the power supply , check the horizontal output +125vdc ,vertical output from +80vdc, +al other circuit +12vdc, if there are missing fix it, see the diagram attached.
3) TEST the signal from tuner,i-f, detector, AGC
GOD BLESS YOU
Jul 12, 2012 | Televison & Video
I installed a 3 ph 208v Square D starter with 2- 120v relays wired from the incomming power, in series, for phase loss protection. I took a neutral to the mag coil and and a wire from the relay contact to...
1. Why not buy a phase loss monitor that monitors all 3 legs. 208v 3ph is 115-120V to neutral. If you're using two 120V relays you'd only be monitoring 2 legs of the 3 phase. Using relays can be risky, as sometimes when you loose one phase you'll still pick up voltage through your load. If your set on using relays use 2-208V relays. Connect one to phase A+B and the other to B+A and then wire two of the normally open contacts in series and put that in your circuit with your pressure switch. I'f you're using 208V for control voltage, then you need to take L2 to the oveloads and then to the coil. L1 would go to your pressure switch, and the return from the pressure switch would go to the other side of your coil. You could add your phase loss protection here.
Apr 10, 2010 | Square D Ehb24020pl 20 A Ehb4 Ehb Circuit...
Machine keeps stopping and showing fo5
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Oct 22, 2009 | Washing Machines
I have 8000 miles on my Tucson check engine light came on at start up this morning...gas cap is tight...no problems?????
there are over 200 reasons for the check engine light to come on, the gas tank cap is just one of them, this light and the problem that turned it on are most likely covered under the federal emission warranty, contact the dealer. see trouble code list below for some of the probelems that cause a check enghine light.
P1100 Map Sensor - Malfunction
P1101 Map Sensor - Abnormal
P1102 Map Sensor - Low Input
P1103 Map Sensor - High Input
P1104 Air Flow
P1105 Air Flow - Abnormal
P1106 Air Flow - Low Input
P1107 Air Flow - High Input
P1108 Fuel Pump
P1109 Fuel Pump - Abnormal
P1110 Fuel Pump - Stuck On
P1110 ETS System - Malfunction
P1111 Fuel Pump - Electrical
P1112 Manifold Differential Pressure Sensor
P1112 VGT Actuator - Malfunction
P1113 Manifold Differential Pressure Sensor - Abnormal
P1114 Manifold Differential Pressure Sensor - Low
P1115 Coolant Temperature Input - Abnormal
P1116 Boost Pressure Sensor - Malfunction
P1118 ETS Motor - Malfunction
P1119 Inlet Metering Valve Control
P1120 Electric Governor - Malfunction
P1120 Inlet Metering Valve Malfunction
P1121 APS PWM Output Circuit Malfunction
P1121 Throttle Position Input - Abnormal
P1122 Boost Pressure Control Valve
P1123 Fuel System Rich - Idle
P1123 Timer Position Sensor - Malfunction
P1124 Fuel System Lean - Idle
P1125 Fuel Press Sensor1
P1126 Fuel Press Sensor2
P1127 Fuel System Rich - Part Load
P1127 Control Sleeve Position Sensor
P1128 Fuel System Lean - Part Load
P1130 Start Solenoid- Malfunction
P1131 Injection Quantity Adjust
P1134 O2s Transition Time(B1/S1)
P1135 Injection Timing Servo
P1140 Inlet Air Temperature Sensor Malfunction
P1141 Slow Duty Solenoid- Malfunction
P1145 Main Duty Solenoid- Malfunction
P1146 Idle Co Potentiometer
P1147 Accelerator Position Sensor (ETS) Circuit
P1150 Barometric Pressure Sensor Malfunction
P1151 Accelerator Position Sensor (EMS) Circuit
P1152 Accelerator Position Circuit-Low Input
P1153 Accelerator Position Circuit-High Input
P1154 O2s Transition Time(B2/S1)
P1155 Limp Home Valve- Malfunction
P1159 Variable Induction System
P1162 High Pressure Pump & Fuel Line
P1166 O2s (B1) Control Adaptation
P1166 Limit O2s Lambda Control (B1)
P1167 O2s (B2) Control Adaptation
P1167 Limit O2s Lambda Control (B2)
P1168 O2s (B1/S2) Heater Power
P1169 O2s (B2/S2) Heater Power
P1170 ECM (Barometric Pressure Sensor)
P1171 ETS Valve Stuck - Open
P1172 ETS Improper Motor Current
P1173 ETS Target Following Malfunction
P1174 ETS Valve Stuck - Close #1
P1175 ETS Valve Stuck - Close #2
P1176 ETS Motor Open/Short #1
P1177 ETS Motor Open/Short #2
P1178 ETS Motor Power - Open
P1179 ETS Position F/B-Mismatch
P1180 O2 S1 Heater Circuit- Malfunction
P1180 Fuel Pressure Regulator - Malfunction
P1181 Fuel Pressure Monitoring
P1182 O2 S2 Heater Circuit - Malfunction
P1182 Fuel Pressure Regulator - Short
P1183 Fuel Pressure Regulator - Open
P1184 O2s No Activity (B1/S2)
P1184 Fuel Pressure Regulator - Power
P1185 Fuel Position - Excessive
P1186 Fuel Pressure - Too Low
P1187 Regulator Valve - Stuck
P1188 Fuel Pressure - Leakage
P1189 Governor Deviation
P1190 Intake Throttle Actuator
P1191 ETS Limp Home Valve On
P1192 Limp home - Target Follow Malfunction
P1193 ETS Limp Home - Low Rpm
P1194 Limp Home - TPS2 Position Malfunction
P1195 Limp Home - Target Follow Delay
P1196 ETS Limp Home - Close Stuck
P1300 Spark Timing Adjust Signal
P1300 Injector Specific Data Fault
P1300 Synchronization Error-CKP/CMP
P1301 TDC Sensor - Abnormal
P1302 TDC Sensor - Low Input
P1303 TDC Sensor - High Input
P1304 Phase Sensor
P1305 Phase Sensor - Abnormal
P1306 Phase Sensor - Low Input
P1307 Phase Sensor - High Input
P1307 Accelerator Sensor - Range/Performance
P1308 Ignition Coil.1
P1308 Accelerator Sensor - Low
P1308 Accelerator Sensor Circuit - Low
P1309 Ignition Coil.1 - Abnormal
P1309 Accelerator Sensor - High
P1309 Accelerator Sensor Circuit - High
P1310 Ignition Coil.1 - Low Output
P1310 Injection Control Circuit Fault
P1311 Ignition Coil.1 - High Output
P1312 Ignition Coil.2
P1313 Ignition Coil.2 - Abnormal
P1314 Ignition Coil.2 - Low Output
P1315 Ignition Coil.2 - High Output
P1316 Ignition Coil.3
P1317 Ignition Coil.3 - Abnormal
P1318 Ignition Coil.3 - Low Output
P1319 Ignition Coil.3 - High Output
P1320 Ignition Coil.4
P1321 Ignition Coil.4 - Abnormal
P1321 Glow Indicator Lamp - Short
P1322 Ignition Coil.4 - Low Output
P1322 Glow Indicator Lamp - Open
P1323 Ignition Coil.4 - High Output
P1324 Glow Relay - Malfunction
P1325 Glow Relay - Abnormal
P1325 Glow Relay
P1326 Glow Relay - Stuck On
P1326 Glow Relay - Short
P1327 Glow Relay - Electrical
P1327 Glow Relay - Open
P1330 Spark Timing Adjust Signal
P1331 #1 MF Signal Line Short
P1332 #2 MF Signal Line Short
P1333 #3 MF Signal Line Short
P1334 #4 MF Signal Line Short
P1335 #5 MF Signal Line Short
P1336 #6 MF Signal Line Short
P1337 #7 MF Signal Line Short
P1338 #8 MF Signal Line Short
P1340 IFS 2 Open
Jun 16, 2009 | 2006 Hyundai Tucson
IR T 20 air compressor will not kick on
IS IT THREE PHASE OR SINGLE PHASE? MOTOR TAG WILL SAY PH 1 OR PH 3.DOUBLE BREAKER OR TRIPLE BREAKER WILL ALSO TELL. IS THIS A BRAND NEW INSTALL OR AN EXISTING COMPRESSOR THAT JUST NOW STARTED DOING THIS. SOUNDS LIKE A POWER PROBLEM LIKE A MISSING PHASE OR BLOWN FUSE. REMOVE FUSES WHEN OHM CHECKING - DONT TEST THEM WHILE STILL INSTALLED.
Mar 14, 2009 | Air Tools & Compressors
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E33
switch 1
--- Cycle blocked
(door open) 8.32
(door open) 8.33
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
Strange noise and burning smell form my PC tower
HI,
this seems that there is the issue with SMPS check for the following please
1.Power is comin in the machine
2.if power is there then there is short circuit
3.please get it checked with professional and if u know then once reassemble the machine and check the static mat below the m/b (if power is coming and fans are moving) other wise SMPS is bad
Feb 26, 2009 | E-Machines eMachines Desktop PC
FAULTY MGE UPS
a 3 ph ups normally can work upto 450 volts because the normally its the transmisson range of voltage
220 to 250 is the voltage range of normal 1 ph line so check for proper line voltage or load voltage
Nov 06, 2007 | Computers & Internet
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Microsoft Windows XP Professional for PC Logo
42 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
