Question about Garmin Forerunner 301
How do I open garmin forerunner 301 - Garmin Forerunner 301
3 Suggested Answers
eMitH
  • 22 Answers
SOURCE: garmin forerunner 301
hi
the garmin gps often use a soft rubber in their contruction
either wait til the unit is out of the heat or use a bit more pressure to push the button doen firmly
the map60 range has the same issue with the power on/off buttons
there is no replacement parts as its built into the case
D
Posted on Nov 21, 2007
SOURCE: Change battery on Garmin Forerunner 301
Hi - look at this solution for a forerunner 201, which has the same case design. I was just looking myself! R_nz Rank: Apprentice Rating: 96%, 8 votes I've made some progress here, I discovered that there is a small notch beneath the flat black pastic insert that holds the rubber button cover in. By gently prising this out, I can at least expose the pcb with the buttons on. I still can't figure out how to open the case though ****! Comments: Jan 29, 2008 - Well, I got there in the end! As above, I managed to prise the plastic insert cover off the rubber button cover, the peeeled this off as well. Underneath is a mylar printed circuit with the silver domeos of the buttons moulded in. This is siliconed down, but you can peel it up with a fingernail. The top left end (above the on button) is aatached inside the case, so start at the other end. Jan 29, 2008 - .ctd.. Once you have lifted the mylar strip, you can get at the case seam underneath and prise it gently open with a flat blade. The case is glued together with a light silicon or something. My problem was unresponsive buttons and by detaching and then re-attaching the small connector by the big silver block where the mylar attaches to the main board and then re-attaching it, it seemed to fix it! :-) Oct 22, 2008 - As an end-note; I glued my 201 back together with a light Silicone sealer. It seems to be at least rain proof anyway. Forerunner 201 battery replacement (Expert level): Opening the 201 was not easy and could not be done 100% clean, but thanks to R_nz (above) I got it open. My problem was dead (almost) battery, after 6 years of superb operation. I found the battery to be glued (double sided tape) to the back cover. To remove, push it up slowely and pull out. Beware of the short wires. 1. It is a flat battery, wrapped in shrinkable tube. Made by MDTechnology, P/N 043048 3.7V, 500mAh see http://www.mydbattery.com/EN/products.asp?ID=12 2. On the cover, the battery is soldered to the underside of a small PCB, hard to get to (by expert!). If you find a battery, suggest to cut the wires and solder wire-to-wire. Hope that helps
Posted on Jul 08, 2009
My Garmin 301 if not being recognized by my computer.
Which operating system is on the computer?
The Foretrex is not compatible with Windows® 95, 98, Me, or NT. It is also not compatible with Mac® OS 10.3 and earlier. This is a common limitation of most USB mass storage devices.
Also, check to be sure that the USB cable is not defective.
Sep 10, 2011 | Garmin Forerunner 301
When I wear my hrm on he Garmin 301 and cycle, if I am mountain biking in very difficult terrain, my avg hr will be around 145 bpm for over an hour and the calorie count comes back as 130 cal? Impossible,...
This sounds like an OS issue, but may be a hardware failure. Do you ever notice your HRM disconnect and then reconnect to your GPS? If so you may be losing connection to your fitness device which could effect your results. If your connection is fine I would suggest giving the unit a firmware update using Garmins WebUpdater Software. Here is a link http://www8.garmin.com/products/webupdater/howtoinstall.jsp.
Feb 25, 2011 | Garmin Forerunner 301
Forrunner 301 won't turn on or charge
You can try various resets to see if you can get it to respond.
Have you tried plugging the unit into the wall instead of the USB
port.Do you get the Battery Charging message at any time.You can
try a soft reset.Press mode and reset.Then try to power on while
plugged in.A hard reset will delete all your data and settings from
the Forerunner.Press the Power and the Mode button until the unit
comes on and asks if you want to erase all user data.Select Yes.
If the above won't work, try a hard reset that by-passes the
confirmation screen.Press Mode, Reset and Power.
Oct 29, 2009 | Garmin Forerunner 301
Jul 08, 2009 | Garmin Forerunner 301
Garmin Foreruner 305 will not turn on or charge
I had the exact same problem and thought my beloved forerunner 305 had finally died. Try pressing the lap and mode keys simultaneously, and then power on. That may do a "soft reset." Worked for me.
Jan 05, 2009 | Garmin Forerunner 301
Garmin forerunner 301
oops, i meant i know its NOT the oxidation problem
Jun 29, 2008 | Garmin Forerunner 301
Garmin 301
try syncing again or try replacing the battery of the HR belt
Mar 02, 2008 | Garmin Forerunner 301
hi
D
Nov 21, 2007 | Garmin Forerunner 301
Garmin Forerunner 301 Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
