Question about RIM Blackberry Curve 8300
Dont have signal only sos. what i have to do.?
  • 76 Answers
Reset Radio, If not, reload OS and if not, replace SIM Card
Posted on Jun 06, 2010
How get off sos
you need the right sim card. the reason its saying sos is either your phone is not unlocked or the sim card hasnt been activated
Feb 11, 2015 | Alcatel Cell Phones
Unlock samsung phone sos code
As far as I know there are two possibilities to get this error message.One is poor signal of that respective network for which you just need to switch OFF and ON your mobile and the mobile will be able to receive the signal from near by tower.You may also get this error message when you are trying to insert a sim other than which the mobile is locked to.To solve this problem you need to unlock the phone from that particular network or use the same sim to which the mobile is locked to . You can unlock from
ClassicUnlocking.com
Jan 26, 2014 | Cell Phones
Fault codes 006-380
First check the Laser Unit for a lose connector.
6-380 ROS SOS Y Length
The interval of the ROS SOS (Y) signals exceeds the specified value.
Procedure
+5VDC is measured between the MCU PWB P/J401-B20 (+) and ground (-)
Y N
Replace the MCU PWB (PL 13.1).
Check the wire between the SOS PWB (Y) P/J516-1 and the MCU PWB P/J401 for an open
circuit.
Check the wire between the LD Drive (Y) J529 and the MCU PWB P/J401 for an open circuit.
If no problems are found, replace the ROS Assembly (PL 3.1).
If the problem continues, replace the MCU PWB (PL 13.1).
May 16, 2013 | Xerox DocuColor 3535 Copier
8520 blackberry sos
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Dec 06, 2012 | Cell Phones
My signal says sos
re heat the audio i.c.
Sep 25, 2009 | RIM BlackBerry Pearl 8100
How do i take it off sos mode
usually SOS comes up when you are out of signal range or if you dont have sim inserted.
If you do have a sim inserted, try taking it out and giving the contacts a clean on the sim and phone
Jul 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
No picture and the led ligth is blinking panasonic veita 52
If you have the flashing red light of death you can use the chart below, and call Panasonic to have it replaced. At the bottom is the list terms.
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Jun 11, 2009 | Panasonic (TH-50PZ700U) Television
Panasonic TH42PA20 - No Picture
If you have the flashing red light of death you can use the chart below to see what the blinks indicate and call Panasonic and have the part replaced, at the bottom of this page is the meaning of terms.
Apr 13, 2009 | Panasonic (TH-50PZ700U) Television
"SOS" SIGNAL ON MY BLACBERRY RIM 8100 UNIT.
Try resetting the phone, firstly by powering down, removing the battery and powering back on.
Dec 06, 2008 | RIM BlackBerry Pearl 8100
RIM Blackberry Curve 8300 Logo
243 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
