I have Lotus 1-2-3 release 3.4 installed on a computer running Windows 2000 and all of a sudden I can't print any of my spreadsheet. I reinstalled the software and it still won't print. All my other DOS programs print fine. Any suggestions? Best regards, Marc S. Ciampa
  • 16 more comments
  • MCiampa Apr 08, 2008
    It is the default printer, any other suggestions
  • MCiampa Apr 10, 2008
    I have been emailed solutions from Benimur, Coolguy008 and Ekse and I can't access them. Can someone make this site more user friendly.
    Thanks,
    Marc
    Yes it's print a test page and the printer works fine with all my other DOS and Windows based programs
    This is a DOS based Lotus 1-2-3 spread sheet program that I've been using for years. I developed Macros that are incompatible with the Lotus upgrades so upgrading the software is not an option. Thanks for the help
    Thank you Benimur for your time. To answer your questions I'll list them in order
    1. Yes, it's connected to LPT1.
    2. I have no idea how to configure the CMOS/BIOS. How do I proceed with this.
    3. There are no pipe characteristics embedded in the print range
    4.None of the cells are hidden.
    I've done everything I capable of including deleting and reinstalling the software but to no avail.
    Nothing has changed since the last time I printed. No upgrades or the addition of any new hardware or software.
    The printer has always been the default printer. Thank you
    Still no luck getting this to work
    Thanks Benimur,
    I replaced the printer cable along with the changing the BIOS settings and still can't print. This is becoming frustrating as hell.
    Printer is connected to LPT1 port
    Sriramojou,
    I deleted the software and then reinstalled with the same results. I even went through the trouble of installing the software on another computer in my office and it printed fine.
    Basti,
    I tried everything you recommended and still nothing.
    Basti,
    I've tried printing differerent spreadsheets and nothing, there are no error messages and when I go to dir>lpt1 it prints all the directories
    The Machine,
    I've removed and reintalled the printer, printed a test page, but can still can not print out of Lutus.
    Thee are no error messages at all.
    Printer is not picking up the job from the computer when printing from Lotus.
    And it prints from the command prompt test.
  • MCiampa Apr 11, 2008
    Thank you The Machine but it still won't print. My only solution is to delete this software from my computer and install it on a spare unit I have in another office.
    Best Regards,
    Marc
  • MCiampa Apr 14, 2008
    Ekse,
    Yes I can print a test page and yes, the printer works fine. The reason I use this old version of Lotus is because I have developed many complicated Macros over the years that are not compatible with the Windows based lotus programs
    Thank you The Machine for all the time you have spent helping me out. I tried the printfil software and really didn't get anywhere so I deleted Lotus Software from this computer and reinstalled it on a spare unit.
    Best Regards,
    Marc
    Champion:
  • 217 Answers
Not sure if I saw an answer for this earlier question. Aside from your program settings, how is your printer plugged into your pc? USB, Parallel, Serial, etc...? Please don't rate this question yet :)
Posted on Apr 10, 2008
  • Mike Wright Apr 10, 2008
    Nevermind, I saw your answer
    Genius:
  • 1,447 Answers
When you print on the Lotus program are you using a dos program or the application itself from windows screen?
If from application from window, try file print and select printer model or Port setting if applicable, if from DOS try changing the port setting on printers and faxes to COM1 to free the LPT port.
Just for troubleshooting purposes....
But if you can print from other application without changing any setup, there is something you need to configure on the application or on lotus application.. .
  • 2 more comments
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Apr 10, 2008
    Try using the generic text only driver as well by adding it from the Add printer wizard...
    and LPT ports on bios should be set as bidirectional or ECP but i dont think it has somethng to do with the bios setup...
    Try printing a different spreadsheet file as well from lotus.
    Are you getting an error message when printing? what is the exact error message?
    Go to command prompt: type dir >lpt1 then click on enter, it should print something. if its not printing something is blocking LPT port, a device or an application. set bios to ECP for LPT and check printer port setting under propertied if its set to lpt1- unchecked the enable bidirectional support box click on apply, make sure from the back of computer its plug in to LPT1( printer). try to print.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 171 Answers
I only tell check the printer settings in lotus if you are printing from command mode it will printing or not,check if it comes the problem with lotus123 try to uninstall lotus123 and install latest lotus and try if its working ,problem with the old lotus123
    Master:
  • 788 Answers
Can you think of anything that would have changed around the time it stopped working? Did you upgrade printer driver? Did you add another printer?
  • 2 more comments
  • Dean Joly
    Dean Joly Apr 10, 2008
    Did you try removing and re-adding the printer so that it picks up default settings?
    Do you get an error in 1-2-3 when you try to print or does it just go through the motions and "thinks" it printer?
    Any errors in Windows when you try to print?
    Have you tried watching the printer's print queue while trying to print to see if it gets a job?
    Are there any print settings in 1-2-3? Something like print emulation type or port number?
    Try opening a command printer (type cmd in the run dialog) and typing this at the prompt (without quotes): "dir c:\ > lpt1" this should print your root directory contents to the printer connected to lpt1. If this also doesn't work then something is intercepting your lpt1 commands.
  • Dean Joly
    Did you try my command prompt test above?
  • Dean Joly
    Ok, Windows, printer, driver, and system wise everything seems to be in order then. The only thing I can see to be a problem is Lotus 1-2-3. When you reinstalled did you delete all traces of it from your hard drive? There must be a configuration file somewhere that is corrupted that is not getting refreshed when you reinstall.
    Otherwise scan through all the configuration option from within 1-2-3 or any .cfg, .ini, .txt files in it's folders to see if you can find a missing link or a bad configuration.
    If all other Dos and windows printing is working then everything should be in order, the only variable that is not common to all other things is Lotus.
    You could back up all your data, reinstall Windows, drivers, software and start over again.
  • Dean Joly
    Dean Joly Apr 11, 2008
    Check this software out: http://www.printfil.com/english.htm try the free trial and see if it helps, might be exactly what you need. Let us know!
  • 813 Answers
Hi friend
chk your lostas setting can u set your pinter as a defolt printer if u dont do then do it try to print during the printer istall one qution come this qution is come do u have to print from dos programs then u have to click on yes u click on no then your printer cant supports on a dos mod programms so rinstall your printer & try to ptint
thnx using fixya
    Brigadier General:
  • 6,966 Answers
Hi Marc,
Is the printer connected to the desktop PC using LPT1/Parallel and not USB?
If yes and all your DOS programs print fine, you may need to alter the settings of the LPT1 in your CMOS/BIOS configurations/setup. Choices are ECP, EPP, Normal. Pls try all settings and determine if a particular one will work for you.
Additionally, pls verify that no pipe character(s) are embedded somewhere in the range you would want printed. To my recollection, Lotus 1-2-3 suppresses the printing of a row/cell if the first character is a pipe character/vertical bar (|), the vertical bar probably won't be visible in the worksheet grid; look at the cell address along the top of the window.
Alternately, to verify whether the cells/range are hidden or not, highlight all of the cells in question, right-click and select "Range Properties" (from the pop-up menu), click on the "Security tab" (key icon) and verify that there is no check mark in the Hide Cell Contents checkbox.
Hope this be of additional help/idea. Pls post back for any development(s) (or even the lack of it) or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Apr 10, 2008
    Hi again,
    Bear with me, have you tried replacing the printer cable? I know that
    the printer works with all your other programs but pls try.
    If that doesn't work, try re configuring your LPT1 port settings in the CMOS/BIOS - on most desktop PCs, pressing DEL key immediately after powering up would lead you to the CMOS/BIOS configuration page. Among the different settings would be one for the Parallel/LPT1. Though there may be a number configurations, you need only change the ECP, EPP, Normal, ECC + EPP choices. After selecting one, save and exit, reboot and run your Lotus 1-2-3. try printing. You may perhaps need to try/cycle through all choices until one works for you.
    Cheers.
    Genius:
  • 3,422 Answers
You can try this open up the word fille and then:
Tools --> Options --> Security Tab. Remove the check before "Warn before printing, saving, or sending a file that contains tracked changes or comments."
For excel do this:
Tools --> Options --> Security Tab. Remove the check before "Read-Only Recommended."
another thing is please update your software.this usually fixes the problem.
Goodluck,
Please don't forget to rate the solution.
  • 13,433 Answers
Have you tryed to print a test page from the printer? is the printer working?
let me know.
  • Ekse Apr 11, 2008
    Im just wondering, why are you still useing a program like lotus 1-2-3 for dos?
    President:
  • 4,402 Answers
Can you print a different form from 123?
try saving the form and try something simple to see if that prints.
Posted on Apr 08, 2008
    Genius:
  • 1,142 Answers
Please set the printer as default
How do i install lotus123 ver 9.8.2 on windows 7 pro computer
I do not know which version of lotus you have, but it is very doubtful it will run on a Windows 7 system which is a 16/32 bit system. Wikipedia says that up to release 4 it ran under DOS, Release 5 was for windows 3.1, 97 edition ran on Windows 95 and millenium edition 98 released in 2002 was the last edition. If you have 97 edition or later it MIGHT run, but better probably to get a copy of Excel.
Mar 01, 2015 | HP Pavilion 21t TouchSmart All-in-One with...
Lotus 123 how to see the top row
try selecting upper left corner, which should select entire sheet, then unhide. Best guess, haven't used 123 in a while....
Aug 18, 2014 | Lotus Smartsuite 4 1-2-3 5.0 123 5 Wordpro...
Lotus 123 problems
Microsoft Excel should open your old Lotus files.
Go to File > Open > Select Files of type: Lotus (*.wk?) and select your Lotus file.
Alternatively you could install and use OpenOffice spreadsheet or LibreOffice Calc and open your Lotus files.
Jul 24, 2014 | IBM Lotus 123 Millennium Edition 9.5...
Who invented microsoft excel/
Excel is a spreadsheet developed by Microsoft but is by no means the first spreadsheet.
The very first spreadsheet was developed (or invented) by Dan Bricklin and Bob Frankston called VisiCalc. VisiCalc was a spreadsheet written to operate on the Apple II computer and was released in 1979. The program was sold to Lotus who developed Lotus 123 from the VisiCalc principle. Lotus 123 was released in 1983.
Excel, first released in 1987, is a development of the early spreadsheets and therefore cannot strictly be classified as an invention. Excel is far more powerful than VisiCalc but that is also a result of development over the years that Microsoft have been working on the product, and the increase in computing power.
Dan Bricklin and Bob Frankston never patented the product because software patents were almost unheard of in the 70s.
Apr 11, 2011 | Microsoft Computers & Internet
Windows xp will not install my hp officejet 7310 all-in-one printer after i uninstallit? i keep getting a 1603 error or can't remove the old webreg?
If problems arise while installing or uninstalling the software, download this removal utility to uninstall the HP All-in-One software before attempting software reinstallation. IMPORTANT NOTE:
This utility removes only version 4.2.0 of the driver.
Running the removal utility may remove the drivers and software for other HP printing, scanning or digital imaging products.
This utility works in stages. The first time the utility is used, it runs at level one. The next time the utility is used, it runs at level two. There are four levels. The effects of each level are shown in the table below.
Uninstaller level Description 1 Removes the Windows device discovery (Plug and Play) entries from the Windows registry. After running level 1, connect the USB cable to the all-in-one and let Windows try to discover the device again. 2 Performs Level 1 and removes the software drivers. After running level 2, run the all-in-one installer and use the "Add a new device" option to attempt to reinstall the all-in-one again. 3 Performs Levels 1 and 2 and removes the HP Photo and Imaging software. You must completely reinstall the all-in-one software after running level 3. 4 Performs Levels 1, 2 and 3, and removes HP Software Update. You must completely reinstall the all-in-one software after running level 4. Installation instructions:
  1. Click the Download now button.
  2. When prompted, choose Open or Run to start the download and run the installer.
  3. Follow the onscreen instructions.
Details and specifications File name: s.gif gr_uninst.exe [1/1, 866.52k] Released: s.gif 2005-01-11 Version: s.gif 4.2.1 Compatibility: s.gif Microsoft Windows XP, Microsoft Windows 2000
Dec 20, 2010 | HP OfficeJet 7310 All-In-One InkJet...
My system is full of viruses. Do i install antivirus and try and remove the viruses or do i need to uninstall windows xp sp2 and reinstall with a antivirus.
The "best practises" approach recommends:
1. backup of your data/music/E-mail files.
2. a "full" format of your C: drive.
3. reinstall Windows from trusted media.
4. install anti-virus software, and update it.
5. run Windows Update, repeatedly, to get all the updates since 2000 (when XP was released).
6. reload your data.
Nov 23, 2010 | Computers & Internet
Excel is devloped for which operating system
Microsoft Excel has become a crucial tool in the international workplace, providing basic database functionality, along with spreadsheet and calculation tools. While it is currently the market leader for spreadsheets, the history of excel shows that throughout the 1980s and 90s it faced significant competition from rival software platforms like Lotus Notes, Mosaic TWIN and the Paperback VP Planner. The original Microsoft spreadsheet program was called Multiplan - which began development in 1982 - but it was never as financially successful as Lotus Notes.
Interestingly, Excel was first developed for the Macintosh operating system beginning in 1984. It made use of graphical menus and the mouse, innovating strongly relative to the other major competitors at the time. Drop-down menus and a point and click interface helped to make it more usable to non-technical workers, and in turn helped to influence graphical user interfaces in other software and operating systems at the time.
As such, when Windows was launched in 1987, Excel was one of the most important and popular pieces of software for it. The early exploration of the graphical user interface for Windows had already been conducted and market tested by earlier versions of Excel. While it was certainly not the first spreadsheet software package, it was the first to provide a powerful combination of usability and functionality to business clients of all sizes.
Lotus was relatively slow to bring Lotus 123 to Windows, failing to predict the popularity of the operating system.
One of the major turning points in Excel was the inclusion of Visual Basic for Applications in 1993, which greatly increased the functionality of the software. In turn, it also encouraged a generation of professionals to learn the programming language, further solidifying the long term demand for Excel over other spreadsheet suites
Read more: http://www.brighthub.com/office/collaboration/articles/13188.aspx#ixzz1IWkjtDx5
Oct 30, 2010 | Answer Racing Ion Motorcycle Jersey 2010
I have a new computer with Windows 7 and I wanted to install Lotus Freelance Graphics 9.0. It did not work. Is there any possibility to fix this problem. Lotus 1-2-3 9.0 is working properly.
I did not see a driver for Win7 on their website but it is worth contacting them. they may have a driver that they can suggest although I don't even see one for Vista. Here is the link to their web. You have nothing to lose by contacting them. Good Luck and Happy New Years.
http://www.ibm.com/Search/?q=Lotus+Freelance+Graphics+2+windows+7+driver&v=16&en=utf&lang=en&cc=us&Search=Search
Jan 01, 2010 | Lotus Freelance Graphics 2
LOTUS 123
am a sales tax auditor in hospet i have purchased a new duol core desktop pc in that pc xp installed
but lotus does not support the xp os please give me solution
Jul 09, 2008 | IBM 1-2-3 Millennium Edition 9.5 for PC
Software problem; Lotus 1-2-3 Release 9 for Windows
Do Alt Print Screen and the paste into wordpad the print it
Mar 05, 2008 | Computers & Internet
Computers & Internet Logo
254 people viewed this question
David Payne
David Payne
