Question about Viking Stove/Oven/Range Timer Knob - PB010185BK
My 2006 gas viking oven won't turn off it stays at a low temp of 200 degrees.
  • 2,100 Answers
I know that your oven has an electric starter on it, no pilot, so I am thinking the valve is messed up and you have a tiny flame going. We just put a Viking in a house and the Grille was messed up on it, wouldn't reach temp, the owner went nuts calling the company and trying to get somebody out there to fix it. I fixed it for her, just a thermostat wire was off. Anyway, if you suspect a leak, You could check it yourself, by peeking at the back of the knob to the oven, see if it is blocked, broke, hitting something, peek down under the stove and see if it has a flame going in there, the broiler is way down on the bottom. Either that or call the gas co. they will check it for you. Even pressure test it to see if it is leaking. something is on. I don't think the light bulb will reach 200 degrees, maybe. Hope this helps.
Posted on May 31, 2010
Oven will not heat over 200
oven does not heat to desired temp we have used a oven thermometer and most of time oven is at 350 but thermometer is at 275 than up to 325 and then down again to 225
Jul 09, 2012 | Viking Professional VGRC365-4GD Stainless...
My oven stays at 150 degrees at all times...even
clean pilot assembly. then oven thermostat
Jan 01, 2010 | GE JGBS20 Gas Kitchen Range
Viking oven only one burner will light
http://www.vikingrange.com/MEDIA_CustomProductCatalog/m20127_f20254.pdf
Go to this web site. It has a manual on Viking ovens.
Usually, when the set temp is reached, the flame will cycle down to what is called "Minimum Blaze". This is to put heat into the unit at the rate that it leaves the unit. It helps to hold temp rather than cycle off and on. It cycles high when temp goes below set and then cycles down when set temp is reached.
Jul 09, 2009 | Refrigerators
Oven Doesn't Even turn on
The oven thermostat controls the oven temp. It is not working and you need a new one.
Jul 01, 2009 | Roper FGP305 Gas Kitchen Range
Viking DED0530TSS oven calibration?
With a small screw driver and a steady hand. Set the knob to the temp u want then pull knob off. Inside the stem there is a little screw. Try and regulate it slowly also allow it enough time to reach the desired temp. Good luck.
Oct 29, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Low oven temp.
sounds like a bad oven/bake ignitor. very common problem on all gas ranges.
Oct 17, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Calibration
Electric ovens are calibrated behind the temp knob. Pull the knob straight off of the shaft and look at the back of the knob. There should be a metal slide with a scale and a little set screw. Loosen the screw and move the slide in the direction indicated for your needs.
Mar 06, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking Dual Fuel 6 Burner 48" OVEN DOES NOT HEAT
I hate self clean functions - If you think about it - you should too. These ranges are equipped with electronic components and running self clean at 950 degrees will more than likely burn something out. A lot of complaints are because of the self clean. It's not worth it to self clean than to clean it yourself. And 200 dollars is a great price for something like this if it includes parts and labor. Good luck.
Nov 25, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking Stove/Oven/Range Timer Knob - PB010185BK Logo
55 people viewed this question
Top Viking Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Viking Hardware and Accessory Expert? Answer questions, earn points and help others
