Question about Kenwood VR-405 Receiver
Problem for Kenwood VR-405. Subwoofer has no sound coming from it. Sub is set to "on" in the menu and all speakers work in test mode. I have tried hooking devices individually with RCA's and also just taking the TV's audio via optics cable. What am I missing?
  • forge_steve Jun 01, 2010
    Here is what I've done, so far.
    Comcast HD/DVD Box into Video 1 input on Kenwood.
    1. Via RCA cables All 5 satellite speakers work - NO SUB
    Tried scrolling through Manual, Digital etc... still NO SUB. Also scrolled through Stereo, Pro Logic, etc. Still NO SUB
    (On all the above settings audio had a slight delay to it so it didn't match the video)
    2. Optic cable from back of TV into Kenwood. Tried all the above mentioned settings and still NO SUB. (Although delay problem was fixed.)
    I also tried all the above with my Sony Blu-Ray player. All results were same.
    I just cracked that Kenwood out of the box, brand new. (Relative bought it in 2003ish and it was never used or even opened).
    Perhaps there is something wrong with the Kenwood system?
How do i hook up my subwoofer to the back of my receiver
Posted on Oct 02, 2012
How I fixed this was to get a can of electrical contact cleaner. Any auto parts store or electronics store will carry it. Take the cover off and remove the volume knob. It's responsible for the output volume to the sub. Pry the four silver tabs open and pull apart the knob. You should see some corrosion on the contacts. Use a fingernail file to clean them off now clean it with the contact cleaner. Put it back together and you are ready to go.
Posted on Jul 19, 2012
The subwoofer output on my Kenwood VR-606 has suddenly stopped working. I have tried the "setup" several times, turning the subwoofer off and back on. Also, when I first power up the system, it emits a low...
It sounds like the problem is not with your VR-606. If you hear a hum from the sub, the problem is more likely to be in the sub's built-in power amplifier. However, it is worth resetting the amplifier to factory presets. To do this, unplug the power cable from the mains supply and reconnect whilst holding down the power on/standby key. If the hum persists, connect any powered speaker to the sub-out socket, power on and listen for the hum. If no hum then suspect the powered sub amp. Turn the sub on with no connection to the Kenwood VR-606. If hum persists, the sub has a problem and will need to be replaced or repaired. By the way, you said there is a low frequency hum through the 'speakers' for about 30 mins. Is that all speakers or just the sub? Hope this helps.
Cheers, Don.
Jul 06, 2014 | Kenwood VR-606 Receiver
Cannot get the subwoofer to play...all other speakers work fine...my Kenwood receiver is VR-309...the subwoofer model is Kenwood SW32-HT... I have also used the setup mode to make sure the Subwoofer is...
After making sure that your subwoofer is receiving power, as most models have their own amplifier, make sure that it actually is turning on. There is a possibility of a faulty power switch. Lets rule that out first.
Once the switch is on and the proper power connection is verified, turn your attention to the setup menu on your receiver. Navigate to the LFE/Sub output level. Adjust it up all the way. Then navigate to the crossover setting. Turn it up all the way. If the subwoofer also has it's own control panel including a crossover, turn that up all the way as well. Then with an input on the receiver that has a subwoofer output set up such as for DVD, play some audio. Or likewise you can also use the receivers' test tone capability that will pan each channel individually with a wide band pink noise signal that also includes a signal sent to the subwoofer output.
If this procedure does not produce results then send me a message including your subwoofer model and your observations of your systems' operation.
Jun 10, 2011 | Kenwood VR-309
I have no sound coming out of the sub rca output
Was it there when you ran the test tones?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-VR-405-Receivers-manual/id/480ag202/t/2/
Start on Page 15
Mar 06, 2011 | Kenwood VR-405 Receiver
Reear speakers not putting out sound
If the TV sound source is through stereo RCA cables you'll only get rear sound if you choose one of the DSP modes. A digital source might work as expected, IF you have things correctly set up for multi-channel.
Dec 26, 2009 | Kenwood VR-405 Receiver
I have a vr 309 kenwood reciever with a bad subwoofer port because sub doesnt produce sound through it but does through another reciever, is there a fuse or capacitor just for this output i can check or...
Are you sure the VR309 is sending a signal out through the sub port? Attach one of your other speakers to it as a test (low volume). Then get back to us.
There are such things as user settings that affect this.
Dec 05, 2009 | Kenwood VR-309
Why does my sub only work in the test mode?
You need to get into the "menu" of the receiver and turn the sub "on" It can be adjusted thru the remote as well.
Nov 08, 2009 | Kenwood VR-405 Receiver
Kenwood vr405
Yes you can! I have the 405 as well. Using a RCA-style cable, simply connect your powered sub to the sub pre out on the back. If its turning off when you connect it and receiver has been working fine otherwise, troubleshoot. Either the sub preout (the 405 itself), the cable or the sub must be the culprit. 1st try a different cable, they do go bad. If problem persists, test the sub with another receiver or take back to store and have them test it. After that, the only thing left in the equation is the receiver itself. I've had mine for 15 years and lets face it, we've got our money's worth. A bad receiver is the best excuse to upgrade!
Apr 04, 2008 | Kenwood VR-405 Receiver
Subwoofer shutdown
I'm having the same issue as pdoug: Sub rumbles in test mode, doesn't produce sound otherwise. Which makes me suspect it's the receiver itself -- the filter (or whatever) it is that should be separating the bass signal and sending it to the sub is not working. At least that's my guess.
Either way... this sucks.
Mar 14, 2008 | Kenwood VR-407 Receiver
Subwoofer doesn't turn on
I felt supid this morning.
I bought a high end cable for my subwoofer.... and it did not work but a regular RCA Cable did. When I went to put the cable back in the package I saw an arrow pointing one way, I turn the cable and it works great.
Dec 12, 2007 | Kenwood VR-405 Receiver
Speakers not working
I second this problem, I'm having the same one. Hey, Bosun, did you ever figure out anything?
Mar 01, 2007 | Kenwood VR-405 Receiver
Kenwood VR-405 Receiver Logo
1,300 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
