Question about Dell E176FP 17" LCD Monitor
Screen goes white
After every 2 or 3 minutes its goes white, as a white wall paper
  • 11,361 Answers
Check the ribbon cable between the LCD panel T-CON board and the logic board. When you lose 5vdc feeding the LCD T-CON board the screen will glow white.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 31, 2010
My screen wall paper is not right. Trees are white, camera shows my vase as white. It is purple. How canifix this?
ARE YOU USING MANUAL WHITE BALANCE IF SO CHANGE SETTING TO AUTO WHITE BALANCE MIGHT REMEDY YOUR PROBLEM
Aug 22, 2015 | Cameras
I got my craftmade ceiling fan about 10 years ago, the fan has now stopped working but the light works, I changed out the switch on the wall that was not the problem sometimes I will turn on the wall...
pretty sure its the 3 speed pull chain switch.$4.50 to $6.00 at home depot or lowes or hardware/elecrtical store.
how 2 replace switch.
1.turn off breaker to fan/fan lights,probably that whole room.
may need extension cord & floor lamp from closest room with electric, so u can see.
2.need 6ft step ladder to get up to fan.look see how to get to fan speed switch. speed switch unscrews from outside but body of switch is inside fan cover.
3. need to take fan off ceiling to replace switch.
4.switch has 4 wires, power feed into switch and 3 selector
wires that go to high speed winding,medium speed winding and low speed winding.
speed selector switch has 4 settings, off, low,medium,high.
about ac circuits , black wire is 120 volts, hot.
white wires are neutral return wire. an ac voltmeter will read 120volts ac with its red and black probes between black,hot and
white,neutral.
white= neutal=ground which is green. If wired properly and polarity was observed, white and green ground wires both connect to the neutral ground buss bar in the circuit breaker panel box and are the same electrical point.
black wires,and the selector handle getting the hot juice into the fan and white returns the used juice to the circuit breaker panel box.
If polarity was observed, you can touch white and ground without getting a shock.
black will jolt or even fry you dead, so make sure the breaker to the fan is off, so that the circuit is de-energized before you touch it.
PLEASE NOTE--- make drawing on paper of what color wires from the fan motor go to what color wires on the selector switch.
If the switch has 4 black wires, you need to put different color electrical tape as a marker, on each wire. or ,to be cheap, you can use white paper,scissors to cut paper,and pencil and write 1,2,3,4 on the paper and tape to the 4 switch wires.
that is: wire # 1 from the switch goes to the black wire from the wall--ac hot
wire #2 from switch goes to yellow fan motor winding,
wire # 3 from switch goes to orange wire from fan motor
wires are specific and NOT interchangeable.
go to www.ehow.com & type into search engine box
how to replace fan motor speed selector switch.
Oct 12, 2013 | Craftmade International CQ52 Ceiling Fan
Installing a GE digital wall timer. Instructions say" connect Hot/live wire of main to black of timer. Connect Hot/live wire of load to red of timer. connect white of (neutral) to white of timer. green...
Review:
Black goes to Hot wire from breaker box
Red wire goes to Load (light, fan, motor)
White wire goes to Neutral
Green to bare copper ground wire
Orientation:
Your original switch had 2 wires plus bare ground.
One of these wires is Hot, the other goes to Load.
You said original wires are Red and Black
How do you find Hot wire?
-Your original switch had 2 wires.
-Remove timer from box.
-Pull original 2 wires out where you can test them
-Turn on power
-Use regular tester
-Tape tester leads to wood sticks so your hands stay away from voltage
-Power is on
-Test each original wire to bare ground wire
-When tester lights up, that is Hot wire ... this wire connects to Black wire on timer
- The other wire goes to Load so it connects to Red wire on timer
How to test for Neutral wire
Test Hot wire to your white wires - No need to untwist them.
When tester lights up, that is Neutral
White wire from timer connects to Neutral.
Green goes to ground wire.
How to reset timer
I'm not sure which timer you have. Probably GE 15086. Reset is small round button below HOUR button. Use paper clip and push-in reset until timer flashes 12 o'clock.
Sep 25, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Liftmaster Chamberlain Garage Door Opener Transmitter 300MC: I'm tryin to connect the sensors on my garage open...
IF YOU HAVE THREE SCREWS THE WALL BUTTON GOES TO 1 AND 2
THE EYES
THE WHITE WIRES W/BLACK LINE GOES TO 3
THE PLAIN WHITE WIRES GO TO 2
IF YOU HAVE SLIDE IN QUICK CONNECT THE WALL BUTTON GOES WHITE WITH RED TRACE TO RED.
THE SAFETY EYES WHITE WITH BLACK TRACE GOES TO GRAY PLAIN WHITE GOES TO WHITE
HOPE THIS HELPS
May 18, 2010 | liftmaster Chamberlain Garage Door Opener...
Screen goes off black...
your console might be over heated . if you continusly try to play it, stop leave it alone for around 10 minutes. get a soda watch some tv and make sure that consule is completly disconnect from the wall.
Jan 17, 2009 | Sony PlayStation 2 (PS2) Console
My samsung SCH-i730 is stuck on the white loading screen
You may have to do a major reset on it. First remove and replace the battery and turn it on again. If that doesn't fix it, there is a tiny reset button on the bottom near the connector. You will need to push it in with a small point such as a paper clip wire.
Jan 03, 2009 | Samsung SCH-i730 Pocket PC
Milky white screen
adjust the screen voltage lower.
May 31, 2008 | Mitsubishi WS-55807 TV
White screen
you have to get the flexcable replaced......take the phone to a mobile service center and have them replace it.
Jan 24, 2008 | LG KG800 Cellular Phone
Dell E176FP 17" LCD Monitor Logo
274 people viewed this question
Alun Cox
