Question about Canon PIXMA MP830 All-In-One InkJet Printer
ERROR 6A00 HELP HELP HELP Ayuda porfavor - Canon PIXMA MP830 All-In-One InkJet Printer
  • 503 Answers
NOT MY ANSWER- IS A CUT AND PASTE FROM SOMEPLACE DIFFERENT
You may or may not find this usefull.
I thnk the 6A00 is a mechanism jam code.
Regarding Error code 6A00. I have a Canon Pixma iP5000. I got that code. No easy answers on the net so I took it apart myself. The covers are all snap locked on. It was a bit painful but I got the side and top covers off to reveal the print head. There is a device that slides back n forth and acts like a window cleaners squeegie on the printhead. This mechanism seemed to be stuck at its full extention rather than being back at home base. Every time I turned it on and off I could see it tried to move but seemed to be stuck. I gave it a little assistance and that released it. I think it had become glugged up with drying ink and that had acted like a glue holding it out at full extension. The mechanism that drives the sliding squeegie relies on a spring
for it to return. The spring wasn't strong enough to over come the gluey ink and so the whole thing jammed up which is probably what the code means - jammed mechanism. If you are going to try it. Do not force any part of the covers. There are little arrows in the plastic indicating where the snap locks are, stick a flat head screw driver in to release. Trial and error will release the right ones first. You'll release one part only to find it hooked up at the next snap lock. Some are hidden under or on opening covers so keep looking. The base seems to be securly attached to the workings so dont try and get it off. Just top and sides. Ink is water based so a damp rag is all you need to clean. If youre not technically minded dont bother.
Dave
HOPE THIS HELPS
Posted on May 31, 2010
2 Suggested Answers
pineworks
  • 4041 Answers
SOURCE: error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Posted on Jan 25, 2010
Mi durango 2005 no ensiende pase corriente y tampoco cambie la bateria por una nueva y nada lo raro q abro el ensendido y nI una luz del panel aparese esta muerta por completo q sera ayuda porfavor
cambio el altenadoro ,una test ,aranque motor ,con motor en relatine desenganche una terminal de batterie ,motor en marche el problema es el batterie ,el motor parado problema es el altenerador
Nov 22, 2014 | 2005 Dodge Durango
LG TV codes
HOLA! necesito los codigos para programar tv LG CON UN CONTROL UNIVERAL JESEN PORFAVOR AYUDA...
Nov 13, 2013 | Jensen 143307 Remote Control
NCK HUAWEY ETS2
Necesito el codigo NCK de un huawei ets2 imei 351884041892383 porfavor ayuda
Sep 18, 2013 | Vodafone Cell Phones
Mecanica
bdfbdfb
Apr 25, 2013 | Cars & Trucks
Lost my hdd password to my dell inspiron 910 mini laptop
mi dell mini pide un pasword en bios y no lo se, como puedo hacer para desbloquearlo, porfavor ayuda, muchas gracias, Dios los bendiga!!!
Jan 08, 2012 | Dell Inspiron Mini 10 Notebook
Problema con mi kenwood kdc-x590 me pide un codigo de 4 digitos como puedo desbloquearlo ayuda porfavor???
halo you will need to contact kenwood give them the model and serial number they will give you the 4 digit code
Mar 26, 2011 | Kenwood KDC-X590 CD Player
Tengo el problema ERROR GENERAL EPSON TX110 AYUDA PORFAVOR
primero que nada debes de identificar en donde es tu error ya que el error general se da por un fallo de comunicacion
Oct 28, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Error code c0f30
SOLUTION: Check the amount of toner in the affected unit and if empty, check the alignment of the toner sensor actuator arm. It is possible that the arms may have been jarred out of alignment during shipment and fail to sense the low/empty toner condition. This in turn, causes the IU to drop below the proper toner-to-developer ratio resulting in C-0F3x codes. Once the actuator has been properly positioned, run ATDC toner supply until the T/D ratio comes back into the specified range.
hope that help
or try to reset the machine.........
Aug 06, 2008 | Minolta CF2001 Copier
Error 6A00
Solution 1:
Solution 2:
Solution 3:
May 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
91 people viewed this question
old marine
old marine
