Question about Maytag M6P09S2B Portable Air Conditioner
I need hose for expelling hot air where can i find and at waht price?
  • 146 Answers
You can get it at home depot. it is called foil flex. 10-20 dollars
Posted on May 31, 2010
My CVA620 machine asks to "expel air " but
keep holding the hot water button down until you get a steady stream of water with no air. if you continue to get the error message after the water comes out, you will need to check the flow meter. if water never comes out, you have a leak inside the machine, a pump issue, or a blockage in the water path. That machine uses the same pump for steam and hot water, so if your steam is working, your pump is probably good. Blockages usually occur from not descaling properly. That machine is prone to leak at the hose fittings. the original o rings were black rubber, and failed fairly early. the replacements are red silicone and last much longer.
Jun 12, 2011 | Miele Coffee System
I have a 1999 ford taurus that has coolant coming out of the surge tank, even though the dash temp gauge is a little under the halfway mark. i have replaced the water pump, thermostat, and surge tank fill...
try bleeding the air out of the pipes....the topmost hot water hose is the best one,just undo the clip when hot to expell any air.(wear rubber glves cos its really hot..)
Oct 10, 2010 | 1999 Ford Taurus
I have replaced everything related to the water cooling system except the heater coil, yet on hot days, high speeds and climbing the engines get really hot.
take off the highest hot hose and expell any air in system(just releasing the clip when the engine is hot may do it)
Aug 06, 2010 | 1987 Nissan Maxima
1994 chrysler lhs changed thermostat and added coolant but car runs hot when driving not when parked and on
try undoing the topmost hose clip to expell any trapped air in system(engine running and hot...)
Jul 28, 2010 | Chrysler LHS Cars & Trucks
Heater blows cold air
CHECK HOSES FROM RAD TO SEE IF THERE BOTH HOT.... U MAY HAVE A DEFECTIVE THER.MOSTAT.. IF NEED TO REPLACE, USE A FAIL SAFE TYPE...WHEN THEY FAIL .THEY STAY OPEN SO U DON.T OVER HEAT UR ENGINE &DO ALOT OF DAMAGE CAUSE THERE,S SOME MUCH ALUM IN ENGINES THESE DAYS... ALSO CHECK FOR AIR LOCK IN THE SYSTEM...LEAVE RAD CAP &RUN THE ENGINE TILL IT,S HOT.. WHILE THE FLUID IS CIRCULATING, IT SHOULD EXPELL ANY AIR IF ANY IN THE SYSTEM, GD LK, CHARLIE
Mar 05, 2010 | 2006 Nissan Titan
My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
Jul 05, 2009 | Miele Coffee Makers & Espresso Machines
Meile espresso maker does not expel air
Press Hot Water and Steam Button at same time.
Dec 24, 2006 | Miele CVA615 Espresso Machine
Maytag M6P09S2B Portable Air Conditioner Logo
118 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
