Question about NEC Speaker Wire Computer Speakers
The tip of the audio plug doest seem to be working the metal is bent a little and idk if i can replace it ..what should i do ?
M886 won't charge battery. replaced battery still no charge. charger is good.
Hi Jane, I'm Peter. I have had the same problem and discovered that on certain phones the port where you plug the charger cord into may have a little finger of metal that has been bent down some so it can't connect the charger connector . On mine I had to remove the back of my phone to get a little better view then got a toothpick ( don't use any metal ) and gently pried the metal finger back straight so it could slide properly into position to charge. I hope this helps .
Jan 01, 2015 | Cell Phones
The timing Is off. start it and it doest blow out
Broken lifter, bent valve stem and stuck, maybe there is a hole in the piston, broken piston, broken camshaft.......List goes on
Sep 14, 2013 | Honda VT 1100 C2 Shadow Sabre Motorcycles
I have a Parkside precision pendulum-action jigsaw, model number PPHSS 730. It has three blades... two for wood, one for metal.... but how can I tell which is for metal?
Tom,
The one for metal will almost certainly have the smallest teeth. Sometimes the metal one will a wavy tooth set - that is, if you viewed the blade from the front, there is a sine-wave shape to the tooth set pattern. (Tooth set means the tips of the teeth are bent a little bit to the left or right to make the cut just a little wider than the rest of the blade so that it doesn't get stuck in the cut.)
Good luck.
Feb 10, 2013 | Makita Jigsaw Blade
Dell battery plugging point bent...urgent help needed
You are going to have to have that plug in piece re-done with a new piece on the mother board soldered. Who ever told you to remove pieces was way wrong. Now as a result your going to have to have this done or you will not be able to use the laptop. Those pieces are meant to give you better support for the plug in and are also the ground. Take it in and have it done professionally. I would not mess with it anymore.
John
May 20, 2012 | Dell Inspiron 1525 Notebook
Sleeve seems to be too big, how do i securely fit the radio in?
Hello 3134,
I'm assuming that you have the correct mounting sleeve. If not, you need the one that was delivered with the radio or an exact replacement. Also, once the receiver is inserted and locked into the sleeve, you need the appropriate "keys" to release it from the front.
There are some little metal "fingers" (tabs) that need to be gently bent inward until they securely contact the recesses built into the receiver case. The best technique is to push the tabs slightly from the outside and with one hand inside the sleeve, pull on them from the very tip. To insure that the case is centered, bend all of the tabs about an equal amount.
Hope this helps.
Sep 27, 2009 | JVC KD BT11 CD MP3 CAR RADIO IPOD AUX...
No Power
First check no pins broke off missing (its easily overlooked), next best way to fix pins:
Get yourself a .5mm mechanical pencil from a shop make sure it's a metal tipped one and empty the lead, also make sure there is no lead loaded in the tip.
Next place the tip over the bent pin (wow it’s a perfect fit!) and slowly bent it back to normal.
Now I suggest you undershoot the bend because it is safer to bend metal more in the same direction then to have to bend it the opposite way.
Retry for power up once everything is seated correctly in position.
If this still fails then check see if the power is connected to MOBO if it is then, and all other wires.
hope this helps
Jun 10, 2009 | Dell Dimension 4600 PC Desktop
Sound card in PC is operable
Look at the plug.... is it metal then a little band and then the tip or is it metal a band then metal and then the tip.
Aug 30, 2008 | Yamaha YST-MSW10 Computer Speakers
No right ear audio
This is caused by the output jack on your zune, what happened was when your headphones were plugged in they got bent or twisted and it moved half of the holder away so it is not touching the cable when it is plugged in, you will probably have to send your Zune into microsoft to have this fixed.
Jan 22, 2008 | Microsoft Zune JS8-00001 Digital Media...
Sound in right speaker only
Do you have stereo headphones available? If so, try plugging the headphones into the computer. If both headphone speakers work then the problem is either in the monitor or the audio cable. If only the right headphone speaker works, then the problem is in the computer....probably a bent or broken contact in the audio output jack, or perhaps an incorrectly placed sound jumper on the motherboard.
Try to find another sound jack...for example, if you're using the sound jack on the rear panel...is there another one on the front of the computer?
Are you using the correct type of stereo sound cable? There should be three metal electrical contacts on the sound connector....a metal tip, a separate metal ring, and the metal sleeve. If there is only a metal tip and a metal sleeve with no ring...then you're using a "mono" cable that will only support one speaker.
If the cable and computer are ok, then your monitor probably has a problem with it's left speaker. You'll need to take it to a qualified computer or tv repair technician to track down the exact cause and repair it.
Jan 20, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Open Questions:
43 people viewed this question
Top NEC Audio Players & Recorders Experts
richie46
Trippy Tripp
Outback Jack
Outback Jack
Are you a NEC Audio Player and Recorder Expert? Answer questions, earn points and help others
