Question about D-Link DIR-625 (790069292637) Wireless Router
The router does not send a signal to the computer. It appears that it does not work. I have recycled and reset the router couple of times.
  • 508 Answers
I like and use this router in my network at home. That being said i also use a D Link wireless access point to handle the wireless side of things, but that's me.
You router would have set up a WEP key when you set up the router, this key needs to entered onto the computers connection settings. Without this key you will not connect to the internet via the wireless side of the router. How you set this up, i have no idea, i don't use it, i leave my connection so that it looks like it is open but all my routers have mac address access enabled so my routers and my connections are locked down. Realize that this isn't much in the way of help but this may point you in the right direction.
Hope this helps
Posted on May 31, 2010
My router isnt sending signal to my printer
The router doesn't send signals to a printer. The Linksys transmits a radio signal recieved by the wireless adapters on other devices, if your printer has wireless compatibility it must be setup on the printer, in the wireless settings. I don't think it's a Linksys issue. It a computer software issue. If you post the Computer Make, Model, and your OS, the Printer Make, mode,l I will try to help you. Is this the first time using the Printer?
Jan 11, 2013 | Linksys Wireless-G WRT54G Router
I have a speedstream internet modem and 3/4 lights are on all except the internet light. I am not sure what to do because that is causing my wireless router to go out. Please help. Thank you
The most common solution for this is to disconnect/unplug the power supplies from both the internet modem and the router, they may be one and the same, then wait a full minute or two then plug them back in. The power should now be recycled and back to working status. Restart your computer so it grabs a new IP address. If this doesn't work then call your Internet Service Provider (ISP) and have them help you confirm signal from their end. They may send you another router or help change the proprietary settings.
TF
Sep 16, 2011 | Efficient Networks SpeedStream 5100 Router
I have a 655 router.. running windows7 on one computer on Home Network.. Router initially working OK..computer connected via cat5 wire. Disconnected router, moved to new location on desk...reconnected...
You can reset both the modem and the router by removing the power cord where it connects into the router (Called Recycling the Power) I would do it with both the modem and the router for about a full 2 minutes.
Sounds more like you have a connectivity issue from interference from something on you desk. Some known culprits are:
High Intensity Lamps Fans Radio Interference coming from your wireless phone Power strip with filters for telephone signal any other environmental issues including computer monitor. Next door neighbor's router signal bleeding through. Filter device missing from phone Filter device missing from phone line connected to you TV
Try moving the router back to the old location. Does problem go away. You are now too close to something thats breaking your signal. I can log into my neighbors access point across the street and two houses away. Signals are strong but can be blocked by a lot of things mentioned above or tin foil.
Check it out,
TF
Jun 03, 2011 | D-Link DIR-655 Wireless Router
Just out of the blue my linksys wrt54g just quit working yesterday - have reset it several times with no change andeven did hard reset on the back of the router for 30 sec. I have both my laptop and...
A subscribed internet connnection would likely have been the providers responsibility. Once, the devices appear to be in functioning conditions as usual only has a remote signal compromise, contacting the service internet provider should resolve the issue. Also, the provider of the signals usually a remote computer would require to reconnect to your computer in processes discussed. Once informing the admistrator of the remote computer, your systems would require powering of completely, thereafter, the remote server computer searches to acquire the devices requiring reestablishement. Shortly thereafter your systems of computers modems are powered back on to ascertain the new settings of signals. The condition would have been caused by the remote computers replacement of devices where their disconnection causes yours to disconnect. However, the subscriber has to reach to the provider for reestablsiment unless notification of the shortage is being communicated with an alternate arrangement least yet arrived. Contact the internet provider. Goodluck
Jan 14, 2011 | Linksys Wireless-G WRT54G Router
Xomputer will inexplicably lose the signal. A few
I think the problem must be with the router. When it drops the connection, you can see other networks but not yours.
that means at that time the wireless signal on your router must not be broadcasted.
WRT160N router has issues with the firmware. Youcan try to upgrade the firmware of the router.
firmware is the software of the router.
Once you upgrade the software, unplug the power to the router and plug it back in. wait for a moment and now observe the connection.
Click here for more information about the router and internet
Feb 26, 2010 | Linksys WRT160N Wireless Router
Wireless router not working all of the sudden
Reset your router, it would enable you to connect
On the back of your router there is a little black reset button. Use a pen or paper clip and press down for 10 seconds. Make sure the lights on the router stop blinking for one second. Release the button and make sure to reset your wireless security and network ID.
If that doesn't work just unplug your routers power cord. This is the easiest way to reset your internet connection without resetting your router to factory settings.
If neither of those work, unplug the power cord of your modem. This will completely reset the internet connection without resetting the routers settings.
Dec 12, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
My d-link wireless router lights turn on properly but it is not sending any signal and when connected by lan the computer says limited connectivity
Try resetting your broadband connection, then the router, then your computer in that order.
These devices get out of sync on their addressing occasionally and a front to back reboot is all they need.
Dec 09, 2009 | D-Link DIR-615 Wireless Router
Can no longer pick up router signal
Does the wireless light still lit on the router? You can try changing the channel on the router (1 6 or 11) ans moving the antenna. If those things did not work upgrade the firmware of the router and reset to factory default. Do not forget to save the configuration file before you reset to factory default.
Jun 30, 2009 | NetGear WGR614 Wireless Router
Router or modem problem
hi..try to resets the setting of router or try to open the setting of router using/type this #>192.168.1.1<thanks and good luck..^_^
Mar 23, 2009 | D-Link (DCM-202) Modem
Wireless not working...
are u using Netgear WGR614v5? if yes, the router has to be resetted as it hangs once awhile(dunno y). By default, the wireless is "OFF"
Jun 30, 2008 | NetGear WGR614 Wireless Router
D-Link DIR-625 (790069292637) Wireless Router Logo
93 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
