The p key and the surrounding keys on my keyboard aren't working, as well as all the numbers past 3; but everything else is. How do I fix it?
    Brigadier General:
  • 10,406 Answers
If you need to ask "how", I recommend that you take the computer to a qualified technician, and get them to safely and correctly disassemble your computer, replace the computer, reassemble it, and test it.
Posted on May 31, 2010
My at symbol and others do not work. how can I fix this please?
Catherine, Try compressed air to blow dust and debris from key board, try a system restore to an earlier date, you could also try re installing key board/driver, you may also have faulty key board and need to replace..
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Some Keyboard Keys not working
Not all keys on keyboard work
Some of my keyboard keys aren working
Aug 07, 2016 | Logitech Computers & Internet
My number pad has partially stopped working, unresponsive keys.
replace the keyboard it not that hard check on line for a video for your modle
Mar 07, 2014 | MSI GT70 0NC 008US - Core i7 2.3 GHz - 750...
Key stuck on (keys are loose, not actually stuck) but works ok with external keyboard
There's more than likely something sticky in your keyboard, someone probably spilled liquid in there and now it's sticking as though your pressing even though you aren't.
A new keyboard will fix this problem.
Jul 18, 2012 | Computers & Internet
How to fix key on Toshiba Satellite L655-S5061 Laptop Keyboard
The keyboard is made that limited to no service can be done, replacement of the entire keyboard is required. Short term solution is use external keyboard if available.
Apr 15, 2012 | Toshiba Satellite L655-S5160 Laptop PC...
My keys of my keyboard aren't working, what can i do to solve my problem? ( just especific keys aren't working )
The keyboard may be faulty or the keyboard chip on the motherboard may be faulty.
To determine id it is a motherboard problem, connect an USB keyboard into ythe laptop's USB port and if the keyboard works correctly then the laptop's keyboard needs to be replaced.
A replacement keyboard may be available from this WEB site.
http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Jul 15, 2011 | Compaq Presario Notebook
Mouse no longer cut and pasting.
make sur the "numlock" key is not locked. (top left corner key)
go to start>>control panel>> accessibility optons. make sure all of th echeck box under the keyboard tab and no check mark in them.
Jan 27, 2009 | Gateway 2520915 Keyboard
Key board numbers and lights wont work
I would start by restarting the computer.
If this does not solve the problem you are more then welcome to get back to me and I'll see if I can help you to further solve the problem.
Dec 17, 2008 | Gateway 2520915 Keyboard
Microsoft Wireless Multimedia Keyboard 1.1 not working
Could be spyware or a virus. Try this.........If this does not help let me know.
Turn the system restore off. System restore keeps everything in restore. Meaning......... If you have spyware or a virus, it will stay in your system. Run Spybot S&D (This program is free and is better than using msconfig as long as you go through the settings and change everything to the highest settings.) Then do the same with Adaware 2008 (sounds stupid to use 2 things for spyware, but one catches what the other one does not.). I have links on my website (tandnfamilyelectronics-online.com). These links go directly to the download so you will not get the run around. You would do good to try a program called Window Washer. This is a great program that completely cleans anything in your computer that you do not need. It will not clean out anything that you have to have. I have used this for years to clean out my customers computers and have cleaned as much as 3 gigs of trash out. If you contact me I will give you some tools that I have for free that will do a great job on your computer. I have them ready to download and I will give you the link. (dean@tandnfamilyelectronics-online.com)
Window Washer free Download.
May 29, 2008 | Computers & Internet
Help please tell me why my keys will not work on my laptop.
Try using an external USB desktop keyboard (or a PS2 keyboard, if you have a PS2 jack on the laptop).
If everything works then, your laptop keyboard is malfunctioning. This is usually due to one of three causes:
1. One key is stuck in the "down" or "depressed" position (collapsed/dented silicone cup beneath, or damaged flex legs under key). Look at the keyboard from the side, to see f any key looks lower than the rest (or higher than the rest) Be careful taking it apart to clean and reassemble.
2. Bad ribbon connector, torn, or merely corroded/oxidized keyboard cable connector. This requires opening the laptop to fix. Usually 2-3 screws under laptop labeled as keyboard, allow it to be pried off. Release the cable LOCK, and remove the thin ribbon cable. Reinsert it 5-6 times to clean off contacts, and LOCK the jack again once you are sure it is all snug. If the ribbon was TORN, you will need a new one. Good luck, not easy to find on old laptops.
3. Worst scenario... someone spilled coke (the worst) or beer/beverage inside the keyboard. This eats up the printed oxide connectors, and this cannot be repaired. you will need a new keyboard assembly.. Use a magnifying glass to look between keys, to see if there is stickey, gooey material there. This would be the bad news indicator for number 3.
Feb 10, 2008 | Toshiba Satellite A105 Notebook
The pound symbol
I am unable to answer your problem that why you are not getting the required symbol if it is there (Hope that you are pressing the no. 3 with Shift key pressed).
But if you need a Pound sign you can get it by pressing 0163 key from the right side numeric keypad while pressing the alt key (i.e. alt+0163).
Remember that you cannot use the upper number key for this purpose.
Feb 06, 2008 | Acer NSK8458AN Keyboard
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
