Question about Humminbird Fishfinder 565 With Transom Mount Transducer
When turning on my wide 128 comes up trransducer not connected and only simulation on screen
Have Sharp - AR-5516 and H5 error blinking on the screen
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY.
Mar 28, 2015 | Sharp Office Equipment & Supplies
What size belts for varidrive
If you're talking about a main drive belt (the one that turns [drives] the rear wheel), drive belts are usually measures as width (how wide) and number of "teeth".
An example is here:
http://www.jpcycles.com/product/600-0541
this belt is 1-1/8" wide, by 128 teeth.
Dec 27, 2013 | 2007 Vespa GTV 250 ie
Gps-simulator
The GPS Simulator mode is a mode where the unit will not look for satellites. instead, it will show simulated satellite receive signals on the satellite reception screen and allow you to simulate driving to the destination that you programmed into it. You will be able to see each turn just as if you were really driving on the road.
Apr 23, 2013 | Garmin nuvi GPS
Is all cloth for billiard tables green?
No. The most popular color may be green (attempting to simulate the idea of grass); however table cloth can come in a wide variety of colors.
Jul 25, 2012 | Sport & Outdoor - Others
I have a Dell PC with an ATI Fire GL X! video card connected to wide screen monitor. Aspect ratio seems wrong This is very noticable in Autocad where circles appear as elipses and squares as rectangles...
You need to change the screens resolution to the one of the monitor: right click on an empty part of the desktop, click Properties, click Setting then move the slider till the native resolution of the monitor is selected. Now click Apply and OK.
Mar 27, 2011 | ATI FireGL X1, (128 MB) AGP Graphic Card
I WOULD LIKE A MAUAL FOR A HUMMING BIRD WIDE 128
Hello and thank you for using Fixya.
Click on this link to view the Humming Bird Wide 128 owners manual.
If you need futher assistance please feel free to contact me. Have a nice day
Mar 08, 2011 | Humminbird Smartcast Rf 35 Dual Display...
Sharp AR-M550 with a paper tray error F3-12
1. Start and end of simulations Note: The "PAUSE" key in the descriptions means the "INTERRUPT" key. Simulation IN The Simulation IN mode becomes only available from the Copy mode screen. In the simulation mode, printer operation is inhibited. Printer operation is also inhibited in either of the Aging mode or the Adjustment Copy mode. The printer selection key is disabled, too. By operating the keys [C] – [PAUSE] – 0/g – [PAUSE], the simulation main code input screen appears. * If the interval between any two key operations is more than 5 seconds, the entry into the simulation mode is canceled. (Ref.) 1 ~ 9: Loading/ sensor checks 10 ~ 19: Resetting troubles 20 ~ 29: Counter/mode setting 30 ~ 39: Sensor activation checks 40 ~ 59: Adjustments 60 ~ 69: Digital readout and printer Simulation OUT The simulation can be terminated by pressing the [CA] key. 2. Simulation main code input screen SIMULATION NO. _ INPUT MAIN NO. AND PRESS PRINT SWITCH 1 If any trouble has occurred when the trouble code is requested, the 7-segment readout displays the trouble code (main only). [Note] The trouble code is canceled when the copier enters the simulation IN mode. [Note] The 7-segment readout becomes blank when the copier enters the simulation IN mode. 2 Only the [PRINT] key LED comes on. [Note] The [PRINT] key LED is usually OFF. It comes on when the copier waits for the [PRINT] key to be turned ON in the simulation mode. 3 The main code input area (2 digits) waits for the input of a main code. [Numeric Key]: Main code input [Note] Codes are entered in the ring format. [PRINT]: Sets entered data. [C]: Clears entered data. [CA]: Terminates simulation. [Others]: Cancels (ignores) entered data. 4 If a simulation has a sub code, it should be executed on the sub code input screen; a simulation does not have a sub code, it should be executed on the simulation execution screen. 3. Simulation sub code input screen
Dec 08, 2009 | Sharp AR-5320 Black and White Copier
Eagle Cuda 128 does not read water depth
Hi Chris, Did you get a fix for this issue? My Dad's Eagle Cuda 128 is also having the same problem - constant reading of 60ft. I'd love to hear if you have a solution. Many thanks,
Mar 14, 2009 | Eagle Boating
Finding a product
treo 755p from sprint and the mougal too
Feb 18, 2008 | LG VX8300 Cellular Phone
What is the difference between the F1 & the F2 film simulation mode?
F1 simulation mode suppresses flaring in flash highlights when the flash is used and stresses smooth tonal transitions in the reproduction of skin tones. It is ideal for portrait studio work where the aim is professional standard negative (i.e. Pro Neg Film). F2 simulation mode provides vibrant reproduction of natural colors such as blue skies and is ideal for landscape and nature photography. Almost like shooting with slide film (i.e. Fuji chrome/ Velvia) Note: Color spaces needs to be set on sRGB and D-Range set to wide in order to use these modes. Color, Tone and Sharpness cannot be changes in any F simulation mode.
Aug 29, 2005 | Fuji FinePix S3 Pro Digital Camera
Humminbird Fishfinder 565 With Transom Mount Transducer Logo
Top Humminbird Boating Experts
Mike Marcotte
Mike Marcotte
Phil Walker
Phil Walker
Steve
Steve
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
