Question about HP DeskJet 940c InkJet Printer
Hp deskjet 940c printer
My hp deskjet 940c tells me that I have an issue with 300x300 dots per inch. I have tried to change this but cannot get it to change. When it prints it looks like it is running out of ink, but I have new ink carriage.
    Genius:
  • 1,027 Answers
1.Setting DPI values
2. Follow one of these paths to select your print options, depending on the
software program you are using:
• Click File > Print, then select Properties
–or–
• Click File > Print Setup, then select Properties
–or–
• Click File > Print > Setup, then select Properties.
The printer properties box appears with Setup, Features, and Advanced
tab options.
3. Select the Setup tab, then choose the following:
• Print Quality: Best
• Paper Type: The appropriate photo paper type
• Photo Paper Printing:
- PhotoREt for best print speed and quality
–or–
- 2400 x 1200 dpi for source images greater than 600 dpi (requires
400 MB or more hard disk space and takes longer to print)
• Paper Size: Appropriate paper size
4. Select the Features tab, then choose the following:
• Orientation: Appropriate orientation
• Two-Sided Printing: Unchecked
• Copies: Up to 20
5. Select the Advanced tab if you wish to make optional adjustments to
color, ink volume, or ink drying time.
6. Click OK to return to the Print or Print Setup screen.
7. Click OK to print.
Posted on Apr 08, 2008
Where can I get a free users manual for a hp deskjet 940c?
Try this
http://h10032.www1.hp.com/ctg/Manual/bpd08798.pdf
or this (download or view online from this address)
HP Deskjet 940c Manuals
or go here
http://www.devicemanuals.com/productsupport/HP_Deskjet+940c_manual.html
The hp website does not seem to have manuals but has other info (how to's) which be of help
HP Deskjet 940c Printer support
9.November.2015
Nov 09, 2015 | HP LaserJet Office Equipment & Supplies
We have an HP 940C Deskjet connected by LPT to a Lenovo XP. The 940C Deskjet Control Panel's Printer Status reads "Status Unknown". The printer functions, but we need to use the Control...
Hello, I was using a 940C till quite recently and had no probs; however I was using USB to connect. Perhaps your LPT cable isn't fully wired and so bi-directional comms don't work, ie status info isn't received from the printer, tho' am only speculating. Anyway, could you use USB to connect or try a different LPT cable, maybe a known good or more modern one...worth thinking about anyway! Good luck, Nicam49 p.s. don't forget to vote :-)
Sep 11, 2011 | HP DeskJet 940c InkJet Printer
Hi! I have a huge problem with my hp deskjet 940c. It won't print colors - only pink! I have bought two new print cartridges, but it's still no good. The black one is okay. Can you help me?
The issue here is that Most HP printers after a certain amount of years of use have that issue, mine was with the black cartridge so i bought a new one from best buy for about 30 bucks not bad for a decent all in one printer
Mar 06, 2011 | HP DeskJet 940c InkJet Printer
DeskJet 940c InkJet Printer: I have an hp deskjet 940c printer. The orange lig...
the moving ink frame is probably pointing to a symbol such as replace color ink( three dots on ink cartridge picture). Replace color ink. You are probably printing your black and white documents with colored ink--always select black or greyscale.
May 17, 2010 | HP DeskJet 940c InkJet Printer
Cannot open toolbox
re-install your software because your registry has been changed
Sep 17, 2009 | HP DeskJet 940c InkJet Printer
Copy count - how can I find it on my HP Deskjet 940c?
If holding the resume button or ink button doesn't printout a status report, you need to look on your computer with the printer hooked up, in the maint. tab for that printer in the control panel. You just have to look around, sometimes in printer preferences or advanced maint.
Aug 10, 2009 | HP DeskJet 940c InkJet Printer
Third light from the right keeps blinking printer wont print Hp 940c
I had the same problem and the following worked for me: I used a cotton swab with alcohol to clean contact points (copper colored dots) on the back of the ink cartridges themselves. I also gently cleaned the brass-colored pins in the cartridge slots. Hope this solves your problem.
Jul 01, 2009 | HP DeskJet 940c InkJet Printer
Have changed computors and have lost my install cd for the hp deskjet 940c. is there a download that I can get off the internet.
Hp is very good for being able to download drivers to their products. Go to www.hp.com and to support and then drivers and select your make and model to download thr drivers for it.
Joe
May 21, 2009 | HP DeskJet 940c InkJet Printer
Printer will not work
Not sure if you can do this, but I have used my 940c HP Inkjet successfully since it was new several years ago. I have found that anytime I have had any problems at all, I just unistall it and reinstall using the CD's that came with it. It has always solved any problems, in general. Specific problems can be taken care of by reading the Toolbox that is installed with the CD also. Good luck.
Jan 24, 2009 | HP DeskJet 940c InkJet Printer
Vista Home Premium, 32 bit, no toolbox for hp 940c deskjet printer
faithful is good..the toolbox you are referring to, is the HP toolbox? that's a driver issue, plain and simple..
check this link, and see what the HP icon reveals for this model and operating system..
by the way, you are my 2300th solution at Fixya, so you are entitled to a FREE tuneup4good for your PC..
that link also has some information related to that service.
Mar 26, 2008 | HP DeskJet 940c InkJet Printer
HP DeskJet 940c InkJet Printer Logo
122 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
