Question about Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher
No water is flowing into the washer, and especially no water is spraying around inside. what can i do?
  • Viking Master
  • 43,501 Answers
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
Dishwasherno water is flowing into the washer, and - 2_bing.gif Trouble No Water entering Dishwasher2_bing.gif
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on May 31, 2010
What is a bypass unloader
According to epowerwash.com:
"The unloader valve diverts water flow into bypass when the trigger gun valve is closed. Unloaders may be designed to respond to either an increase in pressure or a change in flow. The unloader valve may also be used for variable pressure adjustment."
More information here:
All About Unloader Valves ePowerWash
Jun 06, 2014 | Alfred Karcher Pressure Washer
Jameco single handle kitchen faucet with spray hard to turn
make this steps and fix it. God bless you
f a faucet leaks, replace seals and gaskets . If a shower head leaks, create a better seal or replace seals .
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type.
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
If the aerator leaks around the edge, replace the washer in the aerator
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head
Nov 25, 2013 | RTO Jameco #K-1320B Bone Drop In Lav Sink
Jameco single handle kitchen faucet with spray is hard to turn
The water coming out the shower jets is not powerful, help?
follow this steps and fix it. God bless you
If a faucet leaks, replace seals and gaskets .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If the aerator leaks around the edge, replace the washer in the aerator .
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head .
Nov 25, 2013 | Home
Have power to unit. sounds like it is working. pull trigger on the gun and hardly any water comes out. turn it off and there is pressure coming out
Have you tried pulling the spray nozzle tip off and checking it for blockage? The spray tips have a tiny hole for the water to pass through, and sometimes a grain of sand or debris will get stuck inside the nozzle and restrict the water flow. Something to check.
May 22, 2010 | Garden
Windshield washer not spraying washer fluid from front or rear
Is there any water in the plastic container?Also check if there is no leak around the pipe flow and also make sure water pump can be heard to pump water.It could also be a switch, loose or fuse problem.
Dec 22, 2009 | Nissan Xterra Cars & Trucks
Problem with the air flow water cime out
There is a ventilator mechanism on the top right corner, behind the control panel / front cover.
******TURN THE POWER OFF AT THE BREAKER BEFORE STARTING, BE SURE POWER IS OFF ******
Open the door; remove all of the screws that hold just the front panel (not the controls panel). These screws are located on the inside of the door, around the outer edges. The front door panel will be able to be removed. Close the door with the front panel removed.
***IMPORTANT be sure nobody will come in contact with the exposed wiring (especially little kids) *********
Turn back on the breaker, turn on the washer, and run a quick rinse cycle. See where the water is coming from.
On my washer (same model) i had to replace the entire vent kit (sears parts ~$40.00) Call them with your model and serial number, or search online. Removal and replacement was very easy, and it did fix my leaking problem. Checked with the front door panel off and a quick rinse before I TURNED POWER BACK OFF and put the front cover back on.
Root cause?? From what I can tell, the solenoid stopper hardens over time, which allows for water from the spray arms to leak past.
Get it fixed now before you smoke the motor or control card. My part number was ABT35083501 be sure to double check model before purchasing.
Dec 04, 2009 | LG LDS4821ST Stainless Steel 24 in....
Maytag Washer Problem
Have you tried starting the wash cycle at several different time settings? Especially the shortest time setting, just before the start of the first spin? If it works at another setting, it's possible the dial/switch mechanism is worn and not making contact at your usual setting. In any case, a spray of a good electrical contact cleaner spray (NOT WD40 or similar) - with the power lead UNPLUGGED - sprayed into the switch mechanism might help. You would need to remove an access panel to get at the switch mechanism.
Ian from Australia
Dec 26, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Viking 24 in. Professional Series VUD141 (Ultra-Premium) Built-in Dishwasher Logo
175 people viewed this question
Top Viking Dishwashers Experts
Mike
ray gallant
Ronald Rissel
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
