Question about Jenn-Air JED8430 Electric Cooktop
I BOUGHT THIS UNIT AT HOME DEPOT. THE UNIT WAS A DEMO MODEL, AND NO INSTALLATION INSTRUCTIONS WERE WITH THE UNIT. I NEED THE WIRING DIAGRAM TO HOOK THIS UNIT UP TO MY EXISTING ELECTRICAL WIRE DIAGRAM. I TOOK AN OLD JENN-AIR COOK TOP OUT, AND I AM ATTEMPTING TO REPLACE IT WITH THIS NEW ONE. JED8430BDS. I ALSO CAN NOT GET THE EXHAUST FAN TO WORK. THE 4 BURNERS WORK, BUT THEY DO NOT SEEM TO GET FULLY HEATED. THE NEW UNIT HAS TWO RED WIRES, ONE BLACK, AND ONE WHITE WIRES. THE WIRES FROM MY ELECTRIC UNIT IS ONE SMALL WHITE WIRE, ONE GREEN WIRE, ONE RED WIRE, AND ONE SOLID UNINSULATED WIRE, BRASS IN COLOR.
  • 8,197 Answers
You can get the manuals on link below.
http://www.ajmadison.com/ajmadison/itemdocs/8111P463-60.pdf
Install
http://www.ajmadison.com/ajmadison/itemdocs/8101P419-60.pdf
I will let you know that the wires hrom your house are as is.
White wire = Neutral
back wire = hot/power
green wire = ground
uninsulated wire is also a ground
Now you should also have another black or red wire in the box if you took out a electrick unit.
If you took out a gas unit than the wires you see are just for a 110 plug for the igniters.
You need to have 220 for this unit.
You might need to have another wire added so you can use the cooktop.
Posted on May 31, 2010
How do I deactivate demo mode in my Miele cooktop?
PDF]Miele Ceramic Cooktop - Customer Care
customercare.concordadex.com/.../Miele_Ceramic_Cooktop_KM5840-5860-5880.pd...Operating and Installation. Instructions. Ceramic Cooktop. KM 5840. KM 5860. KM 5880. To prevent accidents and appliance damage, read these instructions before installation or use. .... work should be performed by a Miele authorized service ...... Deactivate demo mode (see "Programming"). The cooktop turns off while it ...Missing: my
deactivate demo mode Miele cooktop Google Search
Feb 25, 2018 | Miele Cooktops
Can you advise me on gas connections needed and how to fit connections
I think you are better off going to a Home Depot or Lowes or a plumbing supply house and ask for a gas stove hook-up kit. Then you ask all the questions you need, and ask questions over until you have a good knowledge of what to do and how to do it. There is a great safety factor here, so you need to be clear on how to do the hook up. You can take some pictures of the gas line and of the stove hook up pipe. If you do not have a gas line coming into the kitchen for the stove hook up, then get a qualified technician to install the gas feed.
May 26, 2014 | Cooktops
Where can I get a wiring diagram for whirlpool speed top 2600 electric cooktop
Sometimes if you call the manufacturer of an appliance and have your model number ready, they will email you an diagram or mail it to you. I would not tell them what you are planning on doing, simply because of them not recommending doing this they may not give you what you need. Just tell them you need a diagram thats all. I've done this in the past and it was free, just depends on the company you are dealing with. Hope this helps, good luck.
Feb 11, 2012 | Cooktops
We have a Jenn air jed8430. It was installed but never supplied power to it or tested. We want to make sure the wires are right before powering it up. Black is with Black. Red is with Black with Red...
I just looked, and there is not a wiring diagram available on the web for this unit.
I am concerned about the black with red stripe to red.
Check to see if there is a wiring diagram somewhere on the unit (there wasn't one in the installation instruction or manual for this unit.). I believe the red wire on the house side goes to the black/black wire on the cooktop side (so I believe you are correct on your concern.).
House side green should be to the coiled silver cooktop side silver wire.
But the wiring diagram will confirm these things.
I think the black/red stripe is for the blower.
Jan 28, 2009 | Jenn-Air JED8430 Electric Cooktop
I need a wiring diagram hook up for a Jenn air 201595D Range top & also for a GE Double oven JKP36G0D1B0
Cook top manuals and installation.
http://www.jennair.com/catalog/product.jsp?parentCat=2&cat=12&prod=1457&tabOption=specs#info
Could not find installation manual on oven but did find manual. If you are just trying to wire to the house wiring you need to conect this way. Yo uwill have 3- 4 wires from the house. 1 white, 2 black or 1 black and 1 red. From range hook white to white Black to black or red they both are the hot line. and the other black or red to black or red from the house. If you have bare wires that is the ground There is 2 ways to do the hook up on the ground. 1st way is if you have ground in box from house wire them together. 2nd way is if there is no groung just wire it up with the white wire that is the netural line. It will be fine that way. If you can see in you main braker box the netural and the ground go to the same bus bar.
http://genet.geappliances.com/DocSearch/pdf/49-4751.PDF
Good Luck and If you have any more ? fill free to ask befor you rate.
Jan 16, 2009 | Jenn-Air JED8430 Electric Cooktop
Wiring for Neff Hob-not supplied/no wiring instructions
The details of how to wire the T1213 hob are printed on the base of the hob next to the terminal compartment. For a single cable installation, Neutral is connected to terminals 4 & 5 which should already be linked with a copper link. Terminals 1,2 & 3 should be linked together using the links supplied (hidden in the side of the terminal compartment) and Live is connected to any one of 1,2 or 3. The Earth goes to the terminal beside the cable clamp.
Nov 28, 2008 | Neff T1323 Electric Cooktop
Need a wiring diagram for the burner switch for model c-206b-c
Hello vijay_sin204,
Here is a link for you to view a wiring diagram as well as exploded view with parts list of your cook top. I hope this helps you..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Nov 25, 2008 | Jenn-Air JED8230 Electric Cooktop
Frigidaire electric glass cooktop wiring problem
HEllo
I have the following manuals in PDF format,
I will gladly email them to you.
Model: GLEC30S8ESB Owner Guide(English): 318200612en Wiring Diagram: 318046807 Installation Instructions: 318201426 Parts Manual: 5995479655
Eddie Rentas
Tupper Lake NY
Jul 21, 2008 | Frigidaire 31 in. GLEC30S8 Electric...
Amana Model ACC4370
send me an email at b4829@yahoo.com will help dont forget to check my boxes
Mar 11, 2008 | Amana 29 in. ACC4370 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
Top Jenn-Air Cooktops Experts
Paul Carew
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
