Does not play a dvd. It turns and looks like it's going to play but then it goes the main screen of mintek
    President:
  • 4,402 Answers
Bad lazer or motor height is off/bad either way it will cost less just to replace it. you could try to clean the laser.
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Posted on Apr 08, 2008
6ya staff
SOURCE:
Problem with Mintek MDP-1810 Portable DVD Player that will play movie DVDs but not computer burned video DVD
The problem I think is with the burner on your pc. Try re burning on another program like Nero and pay attention to the options. It will ask you if you wish to play disc in all types of players.
Dec 25, 2013 | Mintek MDP-1810 Portable DVD Player
Portable dvd player
the laser may be broken,and can not read...
Apr 15, 2009 | Mintek MDP-1720 Portable DVD Player
Unable to play dvd's on my mintek portable dvd player
I would get an optical laser lense cleaner ( it is basically a cd that has fine soft brushes on the underside to clean the laser lense )
something like :
laser lense cleaner link
Apr 13, 2009 | Mintek MDP-1720 Portable DVD Player
Help! Thanks.
Are you using the correct rated power supply for the DVD player, is it the official power supply that came with it. Sometimes problems like these occure when a replacement "universal" adapter is used and the voltage and current rating is incorrect for the item.
Also does the screen come on or is it just the power light which turns on?
Nov 01, 2008 | Mintek MDP-1770 Portable DVD Player
MINTEK DVD PLAYER MDP 1815 NOT PLAYING
Mine is doing the same thing. I turn it on, it lights up, it says open, but it won't play dvds or cds. Its not spinning and theres no sound. It used to be a good little player. Is it fixable for a reasonable price or is it shot? Thanks for your help, Jim
Jun 01, 2008 | Mintek MDP-1815 Portable DVD Player
Will not play any DVD
Turn off and disconnect power from unit. Check laser shuttle worm gear, look for dirt or hair (as I found). Remove with tweezers carefully. Check lubrication of worm gear shaft. If gone or worn, use white lithium grease to lube (very little). Play music CD 2 - 3 x. Than DVD. Worked for me.
Jun 01, 2008 | Mintek DVD-1710 Portable DVD Player
Screen is blank
Check to see if the little button that the screen closes down on (which turns off the screen and only the screen) is stuck, or jammed under the little hole that it comes up.  This button is about the size of a pin on most DVD Players, and is located very close to the screen on either side.
Jan 03, 2008 | Mintek MDP-1030 Portable DVD Player
DVD player isn't showing anything
do you hear movement inside like disc rotating, if so then the switch that closest lid is damaged. This is when you fold dvd down it hits this switch to turn monitor off. It could be damaged. If there is no noise or movement then power supply has damaged or batt dead and no power goes to it from power cord.
Aug 21, 2007 | Mintek MDP-1760 Portable DVD Player
Mintek MDP 1810 Portable DVD Player
Hey, sounds like the backlight on the screen is gone, i aint sure where you could get a replacement for that model as its usually monitors i see the problem with. ie the screens is like black with very faint outline of the picture. Hope this helps John
Mar 03, 2007 | Mintek DVD-1810 Portable DVD Player \
Open Questions:
Televison & Video Logo
166 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
