Question about Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive
Do I need only one cord (usb) to connect to my laptop?
Do I also need a power cord? I just moved my bussiness and I'm not sure what was required to connect Maxtor to my laptop.
    Brigadier General:
  • 10,406 Answers
The "physically-smaller" external hard-drives draw power through the USB cable.
The "physically-larger" external hard-drives require an external power-supply (just like a laptop requires an external power-supply).
Check the casing for a plug where the electrical power would come in; if none, then the unit will draw electrical power through the USB cable.
Posted on May 31, 2010
Can I use just the upstream hookup to connect an external monitor to my laptop? Also need to replace power cord. was not included Not the output needed Pwr rating says 12v dc 5.5a. That's all.
I use either VGA or HDMI connectors to connect to an external monitor.
I'm not sure what you're asking on the "power cord". Are you asking about the charging "brick" and such? Or?
Jun 02, 2015 | Planar Computers & Internet
Power cord issues due to moving it while plugged in
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Jun 02, 2012 | Sony VPCF13UFX/H PC Notebook
What does usb device not recognized ?
The best you can do is,
Turn off the PC/Laptop
Disconnect the USB cable from Camera to pc/laptop
Disconnect the power cord connecting the pc/laptop and the wall jack or surge protector
Disconnect the power cord connecting the camera to wall jack or surge protector
wait for 5-10 mins
Connect the power cord of PC/laptop and turn on the pc/laptop and login to your PC
Connect the power cord of Camera to wall jack or surge protector
Connect the usb cable or camera to PC/laptop
It should get recognised and work fine.
Regards,
Shawn
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Jan 20, 2011 | HP Photosmart R847 Digital Camera
My WD external does not connect well to my laptop.
sounds like the drive heads are broken or out of line the unit you have does require a power cord its the data cord that it doesn't need , suggestion is to remove the driver heads and replace them with new ones from a matching Drive , its all you can do to save your vital files , if you are willing to replace your heads I can assist you however its not an easy task
Jan 11, 2010 | Western Digital My Book Essential Edition...
Won't charge
The plug in terminal that is soldered to a board inside the laptop has a loose solder connection. This procedure require opening the laptop and some soldering iron, and some solder. If you are not confident in doing this don't try it cuz you can mess up your laptop forever.
Aug 15, 2009 | Compaq (480082-001)...
Power cord failure to make a good connection
contact the company that makes your computer/laptop.... you need to get a new power cord
Sorry to inform you of this, but i have had this happen before and a replacement power cord was necessary. If you are lucky, like i was, they might send you a replacement for free
May 01, 2009 | HP Pavilion dv6000z Notebook
Does not recognize
Did you try the disk on a different computer to make sure the disk is functioning?
And if using a laptop, make sure that power is not an issue, an external power supply or 2 USB ports are always required.
Also check:
http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Maybe one of those troubleshooting suggestions can help you.
Jules
Mar 16, 2009 | Western Digital External USB 2.0 80 GB...
I WANT TO CONNECT MY LAPTOP TO BROAD BAND INTERNAT CONNECTION WITH USB PORT INSTED OF ETHERNET
u will need to buy a usb cord that fits into the modem to the laptop also you may require the moden software to install the usb cord
Jan 27, 2009 | Computers & Internet
Psc 2110 carriage jam
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Nov 02, 2008 | HP PSC 2110 Color Printer
Need instructions for eGo portable hard drive. This shold ave come wit th purchase but did not.
there's no much need for instructions.
you just plug the hd into a USB port avaliable in your computer. the operating system should be able to recognize it a few seconds after you have plugged the hd into the usb port.
some hd may require for 2 usb to be connected to the computer for the computer to see it.. usually they come with a "y" usb cord. one goes to the hd and 2 usb type a cord go to 2 usb ports on the computer
to check to make sure the computer sees the hd. go into my computer and check if a removable storage device has appear.
also check your hd is on, some external hd may have switch to turn them on.
also check if your hd requires external power if it does it should come with a power connector that needs to be connected and plugged into the power outlet for it to work.
post your finding if you need more help.
Oct 14, 2008 | Computers & Internet
Maxtor OneTouch 4 500GB External USB 2.0 Hard Drive Logo
125 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
