Hello, I bought a "TLX-04011C: 40" HD Widescreen LCD TV with Digital ATSC Tuner" in December 2008. I was watching TV tonight, I heard a loud pop, and saw sparks come out of the top of the television. The television is now unplugged.
  • 3,037 Answers
What probably happened is that a capacitor blew it's top in the unit. First off, I would try calling the manufacturer about it and see what they can do for you (generally there is only a 1 year warranty but you can try). Otherwise, the capacitor (if that is what blew, they do make a loud pop when they explode), should just need to be replaced. If you can't distinguish the part that blew, an electronics store should be able to figure out which part is needed and solder it back in. If it is just a capacitor, then it should be a relatively cheap fix. If you want to attempt to replace it yourself, digikey.com will have the capacitor you need. Again I am assuming it is a cap, but to be sure, you would have to open up the tv to take a look which will void the warranty. I will be happy to answer further questions you have on this, but you need to decide how you want to proceed.
Let me know how this works out for you.
Benjamin
Posted on May 31, 2010
How do I get my 7" widescreen lcd tv with atsc tuner to show channel numbers?
ATSC Digital (VIRTUAL!) Channel NUMBERS vs Actual Channel ...
www.avsforum.com/.../1260172-atsc-digital-virtual-channel-numbers-vs...
Jul 2, 2010 - 4 posts - ‎4 authors
Then came ATSC tuners and digital - [I was about 20 minutes into .... *SHOULD*display the SAME VIRTUAL CHANNEL NUMBER when tuned ... iView-3500STB Tuner & DVR Owners Thread - AVS ...
Mar 30, 2013
OVER-THE-AIR DIGITAL TELEVISION RECEPTION ...
Dec 3, 2005
More results from www.avsforum.com
Jan 13, 2016 | Televison & Video
Polaroid monitor doesn't see signal from DISH
try to reboot dish gateway(modem)
if this helps please take time to rate
Feb 01, 2013 | Polaroid 19 inch Widescreen 1080i LCD HDTV...
I have a Polaroid 40" HD TV TLX-04011C while
There may be an issue with "cold" solder joints on the power supply board, or there may be a failing component on that board as well.
Some things to look for also are bad solder joints particularly on the fuses of the inverter board or boards depending on production run. Those are going to be rectangular items marked with "8A" on them near where the multiwire connector attaches to that board under the plastic cover. As well as any bulging electrolytic capacitors. Since there usually more than one in parallel if one shows as bad- replace them all
A can of cold shot help locate the specific area or component of the 24 volt section of the power supply that is the issue.
Nov 08, 2011 | Polaroid TLA-04011C 40 in. LCD TV
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
Polaroid tlx-04011c shuts off by itself but blue light still stays on..sometimes stays on for a while but eventually shuts off
The problems is the Tuner board.That the board,where the coalax signal cable plug into it to get the broscasting signal.Tries Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Jul 15, 2010 | Polaroid TLA-04011C 40 in. LCD TV
No signal on samsung 40"lcd tv
IF it is an ATSC tuner ,newer type ,( digital tuner) it needs better antenna, most importantly Check the cable from Antenna to the connector. using multimeter , put on resistance ,any, anc check both ends of the cable, when there is no change on the multimeter consider the wire is broke somewhere. Make sure the antenna is pointing towards the tv station. also check www.antennaweb.org i think to see the DTV channels in your area. GL
Apr 08, 2010 | Televison & Video
I don't know how a program it, since you change digital.
So far as I know the HLN series does not have an ATSC tuner, thus no over the air (OTA) reception. You can probably still get a $40 coupon for an OTA ATSC to NTSC converter. Note that will NOT get you high definition (HD). With Dish you can get HD receivers that do get OTA ATSC both HD and SD. With Direct, no OTA AFAIK. With cable you would need a QAM tuner, not in your TV AFAIK to get clear channels as required for locals. Otherwise cable needs a Set Top Box for digital and scrambled channels although the standard definition (SD) non-scrambled channels work with your NTSC tuner. Too bad there seem to be no ATSC to 5-cable RCA or HDMI HD converters except Dish. -Ken
Aug 10, 2009 | Samsung HLN617W 61" Rear Projection HDTV
TV. CODE
for what remote ?
Feb 03, 2008 | Polaroid FLM-3232 Television
Televison & Video Logo
Top Televison & Video Experts
