Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Hi guys, Apprecite for ur expert advise pls? I boot my laptop (Acer Travelmate 4050 series) but it was halted during the booting process (no response after i key-in my windows password). I plugged out the power cord to reboot. (normally on 2nd attempt it will run/reboot smoothly). Unfortunately, it shows one error screen, and give selection to choose to run in safe mode or as per normal.(along with several other options). Selecting any of these selections, the system halted again when executing Mup.Sys . I tried with 2 method : a) chg boot sequence to cdrom -> use bootable cd (provided when purchase the laptop) -> it prompts "this will install windows in ur primary disk,Note:all data in primary disk will be destroyed " q : some poeple said this will not delete the files in my primary disk, is it true? b) i took out the harddisk and put it in external case.but when tried to acess the data, was prompted with message "e:\ is not acessible, error performing inpage operations " pls help to advise, should there is still hope to retrieve my data?
  • jen_nashadi May 31, 2010
    very fast response! pending result status..
  • jen_nashadi Jun 03, 2010
    hi potex18,
    Just to share the result ::
    after the chkdsk action, everything went went out smoothly. I managed to access to the data already (with the enclosure). Put back in the laptop, set boot sequence from hdisk, place in the bootable cd, i can access to the OS without any installations.. After backup all the data, i run recovery console and format everything..Thanks for ur help n advises. nice working with you~ ("p)
    - jen_nashadi-
    Guru:
  • 528 Answers
Hi. In order to resolve this issue. Boot in to your CDROM drive while the operating system disk is in there then run the recovery console. This will put the Mup.sys file back to your computer. Possible cause of this is corrupted mup.sys file which is essential in booting the harddrive. Another troubleshooting is, since you took out the harddrive and put it in your enclosure look for computer with the same operating system and copy its mup.sys file into your harddrive. This file is located at C:\Windows\System32\drivers. That will do the trick.
Posted on May 31, 2010
  • 1 more comment
    Thanks potex18!
    Sorry, may i verify on few things?
    a) upon booting the Cd, it prompts to install OS,and will delete all my files in C: drive. If i proceed, will it delete all my files in c?or i just simply ignore it?
    sorry, i'm a bit concern to keep my data and a bit confused on why they [ut that kind of notifications in the first place, if its not deleting the files...pls advise?
    b) to copy Mup.sys, but it takes a while for the new pc to detect my hddisk..will try it once it appear.
    also, just got new tips to run chkdsk at the command prompt.will try dat , subsequently with action b) above, and will keep u updated about it. Thanks~ (",)
  • Archie Cruz
    Archie Cruz May 31, 2010
    Hi jen_nashadi. Definitely yes, installing the OS using the recovery disk will delete all your precious files on your harddrive. I suggest not to try that one. Unless you have partitions on your Harddrive. Operating system will just focus on your main drive duirng installation and not other partitions.
    Try working on copying the mup.sys file. This will really solved the issue.
    Cheers
  • Archie Cruz
    Archie Cruz Jun 03, 2010
    Its good to know everything now run smoothly.. You did a great Job! .. Till the next solution....
Acer travelmate 4050 boot setup password
Do you need to set a password? I don't understand what you're asking for.
Aug 30, 2014 | Computers & Internet
Got an Acer 4050 from ebay and it goes straight to enter boot password
can you click on f12 before it goes to boot password?
The F12 Boot Menu allows you to choose which device that you would like to boot the computer's Operating System from by pressing the F12 key during the computer's Power On Self Test, or POST process. Some notebook and netbook models have the F12 Boot Menu disabled by default.
If this sounds like your problem then try this:
If this sounds like
To enable the F12 Boot Menu:
  1. Restart the computer.
  2. Press the F2 key to enter computer's BIOS Setup during Power-On Self-Test, or POST, process while the Acer logo is being displayed.
  3. Press the Right Arrow key to select Main
  4. Select F12 Boot Menu
  5. Press the Enter key
  6. Select Enabled
  7. Press the Enter key
  8. Press the F10 key and then press the Enter key to save the changes and restart the computer.
Note: Not all Acer notebooks or netbooks have the F12 Boot Menu feature. Computers that do not have the F12 Boot Menu feature will not be able to enable the feature within the BIOS. I hope this works for you if not, then the problem is obviously not the boot menu. Go to Acer support for more help
Acer travelmate 5730 factory settings restore
Acer Travelmate laptop by pressing ALT+F10 during the bootup to get to the eRecovery and restored the computer to factory default.
Jul 15, 2012 | Acer TravelMate 5730-6204 Notebook
How do i do a system rebuild on a acer travelmate 2410 series 2413NWMLi , the <alt> <f10> does not bring anything up
If your computer does not have a hidden partition for OS recovery, a recovery CD will be required in order to recover the Operating System using Acer Recovery Media.
Order the Recovery Media from Acer https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer
  2. When the Acer logo appears on the screen, press the F12 key repeatedly to enter the computer's Boot Menu.
  3. Press the CD-ROM drive eject button and insert the disc labeled System CD.
  4. Close the CD-ROM tray.
  5. Refer to on screen instructions to select either CDROM or USB CDROM.
  6. The computer will boot from the Acer Recovery Media
  7. When prompted for the Recovery CD, remove the System CD and insert the Recovery CD.
    Note: If there are multiple Recovery CDs, please insert the first of the Recovery CDs.
  8. After the system recovery application has loaded, follow the prompts to reinstall the Operating System.
Note: if your computer is unable to run the Acer Recovery process, or errors occur during recovery, please contact Acer support.
Aug 17, 2011 | Acer TravelMate 2300 Notebook
Free download acer travelmate 4050 serios cl51 drivers
The only drivers available for this laptop are for Windows XP.
You can download these drivers directlyu from Acer:
http://us.acer.com/ac/en/US/content/drivers
From this page, choose "Notebook" then choose "TravelMate" then "TravelMate 4050"
You will see that Windows XP is the only operating system selected, and Windows Vista and Windows 7 are not selectable.
The two choices for Windows XP are XP Home Edition( 32 bit) and XP Professional Edition( 32 bit)
The drivers listed here are for:
Intel Chipset
Realtek Audio
ENE Cardbus
SMSC FIR( (Fast InfraRed) A high-speed IrDA protocol with data rates up to 4 Mpbs.)
RealTek LAN
Agere Modem
Feb 27, 2011 | Computers & Internet
Acer laptop gets hanged every time it is opened. on dignosis it shows code 0211= key board error.pl advise
Try this:
  • open BIOS
  • Look for HALT settings
  • Change settings of HALT ON ALL ERRORS to HALT ON ALL ERRORS EXCEPT KEYBOARD
  • Wait for windows to boot then try your keyboard again
Oct 19, 2010 | Acer Computers & Internet
I don t have the bios password i bought my acer travelmate 4200 second hand and i have a trouble to formate my laptop please help me
press either delete or f2 during the boot process to enter the BIOS you can chage your password from there (be careful)
hope this helps
Aug 13, 2010 | Acer Computers & Internet
I need instructions to reformat my Acer travelmate 280 .ms2132
During bios boot up (Laptop starting) press ALT + F10. This should send you to the factory reset/format setting.
Warning; You will lose all your data, so back up pics, docs etc
Jan 13, 2010 | Acer TravelMate 2300 Notebook
Acer travelmate 3210
Acer Travelmate 3210 is the Series
and in that series your Laptop model is 3212NWXMI
like Acer Aspire 5300 is series and 5320 is the model number like that.
there was no need to update Bios
now in case your laptop is turning on
Please try to start in the Safe mode
and there you shut down your laptop properly and try Restarting in normal mode.
Secondly, If you are well versed with the technology then please
try to reinstall the Windows Xp
and BIOS update is something you should be very careful of.
do not try unless it is MOST required
Dec 30, 2008 | Acer Computers & Internet
Donsen't boot
TRY AND RESTORE YOUR LAPTOP USING THE RESTORATION DISC THAT CAME WITH YOUR PC
Jan 24, 2008 | Acer TravelMate 290 Notebook
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
