Question about Directv Plus DVR DTV Receiver / 100-Hours Video Recorder
Reset system on Direct TV Plus. Receiving satellite info is stuck on 0% complete
2 Suggested Answers
  • 71 Answers
SOURCE: dvr stuck on ''receiving satellite info'' when reset.
When it's rebooting, on the first blue screen press 02468 on the remote. This will force a software update. If you have trouble getting it enter at the right time or you just want to make sure, just keep pressing 02468 until it goes to the update. It won't hurt any thing. Hope this helps.
Posted on Mar 18, 2009
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
Not responding to remote,volume maximizes itself
this tv is known for the key board buttons geting stuck on . you can take the front panel off on disconect the key board to see if the remote works.
Apr 22, 2010 | Mitsubishi WS-65611 65" Rear Projection...
My user guide refers to 'MyVOD' but it never shows up on any screen. It is the Directv Plus DVR DTV receiver.
VOD (Video on Demand) is selectable TV, films etc. So if you haven't used this service it won't show up on your viewing menu. You also need the correct receiver. Have a look at these links for further info.
http://www.directstartv.com/direct-tv-blog/directv-rolls-out-vod-p81.html
http://www.dish-television.com/2008/07/07/direct-tv-vod/
Jan 17, 2010 | Directv Plus DVR DTV Receiver / 100-Hours...
After just recently replacing the bulb I am
Here is proceudre to reset lamp timer in your TV..
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen message ' lamp time was reset to 0' will appear.
Hope this info will help you.
Thanks.
Nov 18, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Our TV is stuck on a guide plus screen
i actually dont know what that is...mindboggling, right? call your tv company.
Jun 29, 2009 | RCA R52WH73 Projection Television
Dvr stuck on ''receiving satellite info'' when reset.
Mar 18, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Hitachi Ultravision will not change channels
Tuner may be fubar is the only logical explanation. Use external one. Repair not cost effective
Aug 27, 2017 | Hitachi 42HDS69 42 in. Plasma Television
Beam
Reset both devices and make sure the IR ports are alinged together so that they are in direct contact with eatchother.
The IR should work 0-10 meters id suggest 20cents from eatchother.
Mar 17, 2008 | Palm Treo 755p Smartphone
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
Direct TV Remote Satellite Won't Receive Signal
What is the AUX Fisher brand code for an RCA remote control model# RCR160SBM1
Nov 06, 2007 | RCA DIRECTV Satellite Remote Control
Directv Plus DVR DTV Receiver / 100-Hours Video Recorder Logo
780 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
