Question about HP Pavilion dv6000z Notebook
Hp530 software from vista to xp
Vista was preloaded, I want to install xp error message
*** stop: 0x0000007E (0X0000005, 0XF75DD0BF, OXF7A292208, 0XF7A28F08)
*** PCI.SYS - address F75DD0BF base at F75D6000, DATESTAMP 3b7d855c
    Scholar:
  • 75 Answers
it seems that this particular message can be related to problems with drivers being loaded. so i guest is u are using a xp cd with SP1 try a copy of XP Pro SP2 included .... also check out the ram on your system... ddat could be a bit of a problem also....and last ... in Bios change hdd from AHCI to IDE mode ... xp has a bit of a trouble seeing sata drive
Posted on Apr 08, 2008
Aspire One netbook BSoD
Those error codes don't really mean very much to the general consumer, but blue screens of deaths are caused by bad RAM memory in your computer, not viruses. I'm going to take a guess that your computer is either several years old and/or it constantly get quite warm? Heat can shorten the life of computer components by quite a bit. You may need to get one of your RAM cards replaced to solve this issue.
There's a free program called Memtest86 that you can run to determine if this is the case. It will scan all your memory and look for bad sectors. You can download it here: http://www.memtest86.com/ and burn it to a CD. What it does is create a bootable CD that will execute the program as the computer turns on to scan all the memory. There are full instructions on their website. The process can take an hour or two depending on how much memory your computer has, and if it turns up any bad sectors then you know what your problem is.
A computer can run with bad sectors in the memory, but it makes it unstable that it will keep bluescreening, so if you have bad sectors in your memory it might be better just to replace the RAM. Luckily, this isn't too expensive. For instance, if your computer has 4GB of memory, it probably has 2 2GB RAM cards installed. You can get a 2GB replacement notebook memory for, I'd say $30 or $40. Installing RAM is very simple, and if you're willing to install it yourself, it won't cost you more than that.
Dec 06, 2012 | Acer Aspire One Netbook 8.9" Notebook
Hi..i have HP pavilion dv5 laptop with preloaded Windows Vista. i want to istall windows xp instead of vista. i tried installing it using xp bootable disc. but after loading the required installation files...
its very simple....
enter the bios setting...The BIOS settings menu is accessible by pressing the f2 or f10 or the f6 key on some computers.
if the BIOS provides an option to disable the native-SATA configuration in the BIOS, do the following steps to Disable the native-SATA in the BIOS
1. Use the cursor to navigate the Configuration options to locate the Native-SATA setting. 2. If there is a SATA setting, select the Disable option, and then press F10 to save the change and restart the computer.
if your system bios does not contain such option.... then find "Native SATA mode" or "SATA IDE"
then change "AHCI" to "ATA"
Jan 16, 2011 | Computers & Internet
I get a stop error message when I try to install windows like this stop: 0x0000007e pci.sys
the error that you are getting is caused when you use an old Windows XP CD without service pack 2 integrated. If you want to install XP on to the new system you must use an XP CD that has service pack 2 integrated.
Nov 16, 2009 | Dell Inspiron B130 Notebook
I am having a acer laptop, while i was rebooting my system suddenly i got the blue screen with below error STOP: 0x0000007E (0xC0000005, 0x80536268, 0xBA4CF3B8, 0xBA4CF0B4)...I cant even boot with the safe...
This might help you.
Otherwise I need more information:
When did it start - after install, after update, after changing some components or something else? Does the message state in which driver did the error occur?
Oct 14, 2009 | Microsoft Windows XP Professional
Stop: 0x0000007e
Upgrade to vista or windows 7, Xp is not supported by microsoft anymore (BUMMER)
Sep 30, 2009 | Microsoft Windows XP Home Edition
I have a software which is compatible with xp and works fine in my office however i'm using vista in my home pc and when i run this software after installing the same it gives me error message as ''INS32...
your software dont support vista
give the name of your software i will check is there any version compatible with vista or i ll bring you a direct link to a software wich has the seame fonctions and support vista
ok
Jun 04, 2009 | Computers & Internet
Installation of windows xp on a preloaded windows vista laptop
See this , you have to download the SATA driver , as you have a SATA hard disk , then slipstream it into the xp installation package.
Alternatively , put the driver on a floppy and press F2 when prompted during the setup when its loading all the files (It says Press F2 if you want t o install a SATA Driver"
Then it will detect your drive and install as normal :D
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Jan 07, 2009 | Toshiba Satellite A100-S8111TD Notebook
Presario f700 drivers
You have to download XP drivers from the manufacturer's website. This normally happens because your harware was designed for the new OS(Vista).
Just go to hp.com and search for the model of your Laptop.
May 20, 2008 | Compaq Presario 700 470024-192 Notebook
HP530 Vista and VideoCAM
tell you what go back to xp its far safer i could get in to you pc just by getin the update code top tip for you there xp is far beter not to say faster and its more simple
Oct 27, 2007 | Microsoft Windows Vista Business DVD...
Software won't work with vista
Uninstall Windows Vista. Do a fresh install of Windows XP Professional Sp2. Download XP drivers and install camera. Many software programs have trouble initializing in Windows Vista. Good luck!
Oct 12, 2007 | Microsoft LifeCam VX-6000 Webcam
HP Pavilion dv6000z Notebook Logo
201 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
