Question about RTO Mega Motion 3 Wheel Travel Pal Scooter
The motor or transaxil lock up and stop the
The motor or transaxle abruptly locks up and stops the scooter. Some times after a few feet or it might go longer.
  • 177 Answers
Hi. Sounds like the circuit breaker ( over load switch ) is tripping out. If you let it sit for a few minutes, does it start to work again? Does it stop when you are driving onthe flat ground, or when you drive up a slope.
I have had cases where this happens to scooters going up a slope, usually because the circuit breaker is rated to low. Sometimes a faulty or burn't out motor will cause this fault.
Also check that the brake solenoid ( free-wheel )is releasing properly. Can you push the scooter when the brake is released?
Good luck. Neil.
Posted on May 31, 2010
Testimonial: "thanks for the help"
Tazora elite. Has locked up on me two times now. Almost throws me off scooter. Battery just charged. H ow do I tell if it's a battery problem or a motor problem?
Some scooters are fitted with an electric safety brake which engages when the power is off.
While there could be a mechanical fault with the transmission or motor this would seem unlikely as when the fault is absent the scooter presumably runs ok.
It would seem the electric brake is engaging either due to a fault in the brake or because of an interruption in the power supply to it. That might mean the battery but unlikely. That would be fairly obvious as the complete machine would die at the same time it stopped and you made no mention of that.
Sep 04, 2016 | Tzora ELITE Elite Easy Travel Scooter
What is problem with my rascal 305 four wheel scooter
your problem is related to the overload breaker on the chair you need to figure out why the breaker is tripping either due to batteries going bad or the brushes in the motor need adjusting or replaced , also you need to check the automatic brake is releasing completly a dragging brake will cause the auto reset breaker to trip
Oct 01, 2014 | Health & Beauty
How do I fix my brakes that are locked up on my electric 3-wheel Pride scooter?
If your brakes are locking up while driving, this is a serious issue and you should stop driving the scooter and contact a technician. You can do very serious damage to your equipment that can result in replacing the motor, transaxle and/or both.
Sep 19, 2014 | Pride Health & Beauty
Why my Buzz arround XL stops or drags when in neutral.
to push start a motor bike you have to use a higher gear like third gear but if you are only pushing it from one place to another then it is better in neutral or out of gear
Jul 04, 2014 | Golden Technologies Health & Beauty
My srtrider will only go for a few feet then comes to an abrupt stop its abit like the back wheels jam..but then it will go for another couple of feet then come to a stop again there are no warning lights...
If your batteries are running very low, this is the most likely source of your problems. 80% of my scooter repairs involve batteries. The fact that your scooter runs is a good thing. The fact that it runs only a few feet and gives you no error code when it stops indicates the electronics have no battery power to indicate a flash code. The back wheels jamming probably relates to a no power condition causing the brake to lock (it takes power to release the brake and turn the motor)
This scooter uses two U-1 batteries that last between 1 and 2 years. From your description, I would replace the batteries first and make any further determination of any problems, if any,after that. These batteries are available locally at a large discount (between $50 and $160 each) and can be installed with basic tools, saving you money on the labor charge.
Shop around for the best price. Charge the new batteries fully before use. Enjoy.
Hope this helps.
Nov 25, 2010 | Electric Strider Midi 4 Wheel Mobility...
Scooter stops short without warning
This could be caused by a couple of different issues. If your batteries fall to below 17 volts the unit will shut down. After it sets for a few minutes it may run again for a short time. If this is the case, then the batteries are not being charged properly or they are not holding charge.
Another cause could be the break switch circuit is opening. If that is the case, replace the brake/motor harness
Jun 04, 2010 | Invacare Supply Group Invacare Scooter...
Scooter moves approx 10 feet then stops led flashes 8 times then stops
Hi. 8 flashes is a fault code for a motor fault. It will be either worn brushes in the motor or faulty connectors to the motor. This fault code means that there is no circuit through the motor. Probably time to overhaul the motor. Most mobility scooters have plugs and sockets that are really to small to carry the amount of current that they do. Because of this, they sometimes fail.Good luck. Neil.
May 21, 2010 | Invacare Supply Group Invacare Lynx Large...
Sudden stops
Sounds like the brake. Ohm chech the brake (it is attached to the end of the motor). It should be around 35 ohms
Jan 04, 2009 | Golden Technologies Avenger 3 Wheel...
RTO Mega Motion 3 Wheel Travel Pal Scooter Logo
312 people viewed this question
Top RTO Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a RTO Health and Beauty Expert? Answer questions, earn points and help others
