Question about FixYa Computers & Internet
How do I edit a question I posted on FixYa? It is under some humidifier but it's a thermostat.
  • 8,197 Answers
Sorry you can not edit once it is posted. You can just post a new question.
Posted on May 31, 2010
Testimonial: "Thank You, that's what I figured. I'll repost. :)"
My pencil torch wont light or ignite.
Hello Lorna Allen
Your posting history shows that you have made two posts and both are identical saying you posted in the wrong category. That leads me to believe that you have set up an account and posted something in the wrong category and then set up another account and made two new posts. This is not the right way to use Fixya.com. You make ONE account and use only that account. EVERY post you make is editable for both question content and for category.
What you should do now is edit THIS post of yours into a real QUESTION, and I will Delete the other post. To do this Click on your name on the upper right side, and then click MY ACCOUNT. This shows ALL of your posts. Click on the highlighted one and then under the question, click EDIT. Or you can do it right here after you have read this. Look up above at your question and click EDIT underneath it.
Another tip that so many make mistakes at as a new poster. To make a reply to anyone who is 'speaking' to you, always click COMMENT under the posters post,, and never open a NEW post to make a comment. If you do it the right way, the person you are replying to will get a notification that there is a follow-up and they will come back and help you.
Thanks for using Fixya. Any questions, just COMMENT below my post.
Andrew
Fixya Moderator
Jun 30, 2016 | Colibri C-Series Scepter CB-LTR014314
I installed a honeywell 360a flow thru humidifier, and a new transformer. I have power thru the wires to the fan cover. Also the humditstat clicks when turned on. The fan does not work and the solenoid...
Posting a diagram of how you wired the installation will help the both of us figure out what the problem is. You don't have to accept or rate this solution in order to post comments or information. But accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Jan 11, 2011 | Honeywell HE360A1027 Whole House...
How do I remove the thermostat cover to change the battery?
Many of the newer Honeywell models have a battery compartment that can be accessed without removing the thermostat.
Look for a small tab at one of the top corners of the thermostat. If this is not the case try pulling directly away from the wall at the bottom, then tilt up.
Aug 27, 2010 | Honeywell Power Humidifier: Furnace...
A/C won't come on, replaced batteries, display reads -AC Honeywell chronotherm III Thanks for any advice !!!
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Aug 07, 2010 | Honeywell Power Humidifier: Furnace...
How do I know my aprilair 760 humidifier is working?
A simple check you can perform on your aprilaire 760 is the following:
1) locate the two brown wires coming out of the 760 (these wires will be wired to tell the 760 to turn on when the hvac bower is on and the humidistat is calling for moisture).
2) temprarily disconnect the two brown wires from the external wiring and then short the wires together. All you're doing here is bypassing the your thermostat and bower-on indicator.
With the 70 unit plugged in to the wall outlet and the two brown wires connected together, both the fan and the solenoid valve (water inlet valve) should both be activated.
Dec 13, 2009 | Aprilaire 700 Humidifier
Thermostat does not read current settings or respond to commands.
HONEYWELL WEBSITE:
Go to honeywell.com
Oct 08, 2009 | Honeywell Power Humidifier: Furnace...
Water runs out back humidifier into plenum & onto floor
Hi John Your whole question did not show up (maybe you can re-post) . I can answer what part i understand though. If the humidifier was wired in right it will not send power to the humidifier until the furnace is on, and calling for heat. This stops the unit from working in the cooling mode in summer.Make sure your furnace filter is clean as well
Hope that helps
Mar 05, 2009 | General Filters 1042-LH Humidifier
Humidifier won't turn on with furnace fan set to Auto.
There is a devise called a current sensing relay (a little black box that hangs on a blower motor wire that senses current from that wire) If you have such a devise it should hang from the white (common) wire. Loop the wire through twice.
Nov 23, 2008 | Aprilaire 600 Humidifier
Crane Adorable One Gallon Cool Mist Ultrasonic Humidifier
I posted the instructions for cleaning the unit a little while ago, but under a different Crane humidifier product. See http://www.fixya.com/support/t253969-cleaning_instructions
Nov 25, 2007 | Crane Penguin 1 Gallon Humidifier
Computers & Internet Logo
74 people viewed this question
Top FixYa Computers & Internet Experts
Mark Magill
Mark Magill
Are you a FixYa Computer and Internet Expert? Answer questions, earn points and help others
